"No module named 'intelhex' compile error" - unable to permanently delete the tool-esptoolpy folder
Complete newbie here…
When trying to Upload from PIO to an ESP32 I get same the error others have had:
ModuleNotFoundError: No module named ‘intelhex’
The solution of deleting C:\Users\<user>\.platformio\packages\tool-esptoolpy does not work for me:
Each time I delete the folder, and click Build or Upload, the folder re-appears and the error re-occurs.
I tried re-installing VSC / PIO and to running a simple flashing LED script, and I always get the same error.
Any advice or tips would be greatly appreciated.
Reinstalling VS Code or the plugins won’t help here as they are just the “GUI”.
  • Close VS Code
  • Delete the folders C:\Users\<user>\.platformio\packages\ and C:\Users\<user>\.platformio\frameworks
  • Start VS Code and open your project
  • Wait until PlatformIO installed the missing files
You also might to use a newer platform version which is available by pioarduino’s platform-espressif32:
Thanks for the response Sivar. Unfortunately I followed your suggested steps without success (same error appears). Not sure if it is me being thick or PlatformIO having a bug.
The framework folder ‘framework-arduinoespressif32’ (the one I believe you told me to delete) is within the ‘packages’ folder’. I tried deleting both, without success and I also downloaded and saved the pioarduino’s ‘platform-espressif32-main’ folder into the ‘packages’ folder whilst deleting the tool-esptoolpy and framework-arduinoespressif32 folders, but this did not work either.
When re-opening VS Code it did the following, and then “an unexpected error occurred”:
Resolving esp32 dependencies…
Tool Manager: Installing platformio/framework-arduinoespressif32 @ ~3.20017.0
Unpacking 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100%
Tool Manager: framework-arduinoespressif32@3.20017.241212+sha.dcc1105b has been installed!
Tool Manager: Installing platformio/tool-esptoolpy @ ~2.40900.0
‘C:\Users\Andy’ is not recognized as an internal or external command,
operable program or batch file.
CalledProcessError: Traceback (most recent call last):
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\platformio\_main_.py”, line 103, in main
cli()  # pylint: disable=no-value-for-parameter
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\click\core.py”, line 1157, in _call_
return self.main(\*args, \*\*kwargs)
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\click\core.py”, line 1078, in main
rv = self.invoke(ctx)
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\platformio\cli.py”, line 85, in invoke
return super().invoke(ctx)
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\click\core.py”, line 1688, in invoke
return \_process_result(sub_ctx.command.invoke(sub_ctx))
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\click\core.py”, line 1434, in invoke
return ctx.invoke(self.callback, \*\*ctx.params)
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\click\core.py”, line 783, in invoke
return \__callback(\*args, \*\*kwargs)
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\platformio\project\commands\init.py”, line 106, in project_init_cmd
install_project_dependencies(
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\platformio\package\commands\install.py”, line 107, in install_project_dependencies
already_up_to_date = not install_project_env_dependencies(env, options)
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\platformio\package\commands\install.py”, line 132, in install_project_env_dependencies
\_install_project_env_platform(project_env, options),
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\platformio\package\commands\install.py”, line 149, in _install_project_env_platform
PlatformPackageManager().install(
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\platformio\package\manager\platform.py”, line 62, in install
p.install_required_packages(force=force)
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\platformio\platform\_packages.py”, line 76, in install_required_packages
self.install_package(name, force=force)
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\platformio\platform\_packages.py”, line 70, in install_package
return self.pm.install(spec or self.get_package_spec(name), force=force)
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\platformio\package\manager\_install.py”, line 47, in install
pkg = self.\_install(spec, skip_dependencies=skip_dependencies, force=force)
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\platformio\package\manager\_install.py”, line 116, in _install
self.call_pkg_script(pkg, "postinstall")
File “C:\Users\Andy Bentham\.platformio\penv\Lib\site-packages\platformio\package\manager\base.py”, line 339, in call_pkg_script
subprocess.run(
File “C:\Users\Andy Bentham\.platformio\python3\Lib\subprocess.py”, line 571, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command ‘C:\Users\Andy Bentham\.platformio\penv\Scripts\python.exe package-postinstall.py’ returned non-zero exit status 1.
Does that show the problem?
Apologies for my lack of basic understanding…
This isn’t “basic” stuff. This is the “most advanced stuff” :wink:
If this doesn’t help, try reinstalling platformio completely by deleting the whole .platformio folder.
Thanks Sivar, this solution worked. I had to get someone to explain how to input those commands, and there was an issue with the space in my Users account name, but using quotation marks fixed that.
Oh yeah…space in username is a “bad thing” :wink:
In this case another option is to change PlatformIO’s core directory to different location (path without a space) by setting the (Windows) environment variable PLATFORMIO_CORE_DIR before (re)installing PlatformIO
