Trying to build firmware for 3D printer. error messages attached. where go from here?
NO “BIGTREE_SKR_2” in “buildroot/share/PlatformIO/boards” This might be root of problem.
“message”: “src_filter configuration option in section [env:include_tree] is deprecated and will be removed in the next release! Please use build_src_filter instead”,
“message”: “src_filter configuration option in section [env:DUE] is deprecated and will be removed in the next release! Please use build_src_filter instead”,
“message”: “src_filter configuration option in section [env:esp32] is deprecated and will be removed in the next release! Please use build_src_filter instead”,
“message”: “src_build_flags configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use build_src_flags instead”,
“message”: “src_filter configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use build_src_filter instead”,
“message”: “src_build_flags configuration option in section [env:simulator_windows] is deprecated and will be removed in the next release! Please use build_src_flags instead”,
“message”: “src_filter configuration option in section [env:SAMD51_grandcentral_m4] is deprecated and will be removed in the next release! Please use build_src_filter instead”,
“message”: "src_filter configuration option in section [env:malyan_M300] is deprecated and will be removed in the next release! Please use
“message”: "src_filter configuration option in section [env:STM32F103CB_malyan] is deprecated and will be removed in the next release!
“message”: “src_filter configuration option in section [env:teensy31] is deprecated and will be removed in the next release! Please use build_src_filter instead”,
“message”: “src_filter configuration option in section [env:teensy35] is deprecated and will be removed in the next release! Please use build_src_filter instead”,
“message”: “src_filter configuration option in section [env:teensy36] is deprecated and will be removed in the next release! Please use build_src_filter instead”,
“message”: “src_filter configuration option in section [env:teensy41] is deprecated and will be removed in the next release! Please use build_src_filter instead”,
