I’m working on a project building many firmwares on different boards sharing some common libs.
I will manage different main functions (call them sub projects), I’m a bit confused on what could be the best solution:
- multiple environments, one for each firmware: in this case I need some tips on how to filter sources per sub project
- multiple projects sharing a common library: in this case I need some tips on how to make libraries shared by multiple projects
thank you
