Mac OS - v.10.14.5 Mojave - Error downloading to board - Library not loaded: /usr/local/opt/libusb-compat/lib/libusb-0.1.4.dylib
This just started occurring - was downloading fine - but now I have this error:
verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/protrinket5ftdi.html
PLATFORM: Atmel AVR > Adafruit Pro Trinket 5V/16MHz (FTDI)
HARDWARE: ATMEGA328P 16MHz 2KB RAM (28KB Flash)
Collected 5 compatible libraries
Checking size .pioenvs/protrinket5ftdi/firmware.elf
DATA:    [=         ]  11.6% (used 237 bytes from 2048 bytes)
PROGRAM: [=         ]  12.1% (used 3470 bytes from 28672 bytes)
AVAILABLE: arduino
Looking for upload port...
Auto-detected: /dev/cu.usbserial-AI055WAW
Uploading .pioenvs/protrinket5ftdi/firmware.hex
dyld: Library not loaded: /usr/local/opt/libusb-compat/lib/libusb-0.1.4.dylib
Referenced from: /Users/craigdetter/.platformio/packages/tool-avrdude/bin/avrdude
Reason: image not found
*** [upload] Error -6
=============================================================== [ERROR] Took 0.95 seconds ===============================================================
++++ END LOGS +++++++++++++++++++++++++++++++++++++++++++++++++
When I check my drive, there is no (/usr/local/opt/libusb-compat/lib/libusb-0.1.4.dylib), however there is this:
$ ls -al  /usr/local/opt/libusb
lrwxr-xr-x  1 craigdetter  admin  23 Jun  7 11:07 /usr/local/opt/libusb -> ../Cellar/libusb/1.0.22
I fixed it by:
brew reinstall openocd
Thank you so much for sharing your solution, this finally fixed my libusb issue
Fixed for me too, thank you very much.
Hello everyone. Please can somebody explain me what exactly should I do to reinstall openocd on my mac… I’m trying to solve the same problem with *** [upload] Error -6 when uploading to my Arduino Nano board…
Ok, I’d found how to reinstall openocd, and this solved the problem, thanks for this solution!
Please open PlatformIO IDE Terminal and update all packages via pio update.
