Libraries just don't work
I have a program from the internet, and this has been my experience with everything I try to upload with libraries. The errors are first, then the code.
What am I doing that’s causing so many things that are definitely in the library, things that work fine over in Arduino, why are they all failing? How am I not getting libraries right?
I’m pasting them into the lib folder, linking them in .ini, but the commands aren’t declared.
Compiling .pio\build\esp32doit-devkit-v1\libb21\WiFi\WiFiMulti.cpp.o
src\main.cpp: In function 'void setup()':
src\main.cpp:41:18: error: 'handle_OnConnect' was not declared in this scope
   server.on("/", handle_OnConnect);
src\main.cpp:42:21: error: 'handle_NotFound' was not declared in this scope
   server.onNotFound(handle_NotFound);
src\main.cpp: In function 'void handle_OnConnect()':
src\main.cpp:57:80: error: 'SendHTML' was not declared in this scope
   server.send(200, "text/html", SendHTML(temperature,humidity,pressure,altitude));
*** [.pio\build\esp32doit-devkit-v1\src\main.cpp.o] Error 1
Code:
#include <WiFi.h>
#include <WebServer.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme;
float temperature, humidity, pressure, altitude;
/*Put your SSID & Password*/
const char* ssid = "YourNetworkName";  // Enter SSID here
const char* password = "YourPassword";  //Enter Password here
WebServer server(80);
  delay(100);
  bme.begin(0x76);
  Serial.println("Connecting to ");
  Serial.println(ssid);
  //connect to your local wi-fi network
  WiFi.begin(ssid, password);
  //check wi-fi is connected to wi-fi network
  delay(1000);
  Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected..!");
  Serial.print("Got IP: ");  Serial.println(WiFi.localIP());
  server.begin();
  Serial.println("HTTP server started");
  server.handleClient();
void handle_OnConnect() {
  temperature = bme.readTemperature();
  humidity = bme.readHumidity();
  pressure = bme.readPressure() / 100.0F;
  altitude = bme.readAltitude(SEALEVELPRESSURE_HPA);
void handle_NotFound(){
  server.send(404, "text/plain", "Not found");
String SendHTML(float temperature,float humidity,float pressure,float altitude){
  String ptr = "<!DOCTYPE html> <html>\n";
  ptr +="<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=no\">\n";
  ptr +="<title>ESP32 Weather Station</title>\n";
  ptr +="<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}\n";
  ptr +="body{margin-top: 50px;} h1 {color: #444444;margin: 50px auto 30px;}\n";
  ptr +="p {font-size: 24px;color: #444444;margin-bottom: 10px;}\n";
  ptr +="</style>\n";
  ptr +="</head>\n";
  ptr +="<body>\n";
  ptr +="<div id=\"webpage\">\n";
  ptr +="<h1>ESP32 Weather Station</h1>\n";
  ptr +="<p>Temperature: ";
  ptr +=temperature;
  ptr +="&deg;C</p>";
  ptr +="<p>Humidity: ";
  ptr +=humidity;
  ptr +="%</p>";
  ptr +="<p>Pressure: ";
  ptr +=pressure;
  ptr +="hPa</p>";
  ptr +="<p>Altitude: ";
  ptr +=altitude;
  ptr +="m</p>";
  ptr +="</div>\n";
  ptr +="</body>\n";
  ptr +="</html>\n";
  return ptr;
Hi @monsterthews,
remember that PlatformIO IDE is just not Arduino IDE.
PlatformIO on top of vscode works like a “normal” text editor, and upon compilation it does not pre-scan file contents for class or function headers as the Arduino IDE does.
You don’t have a problem with the libs, it’s your code…
Problem is that your functions are declared “after” you try to use them:
void handle_OnConnect() is the perfect example, you’re using it in setup() but declaring it further down.
Solution: Define functions ON TOP of object creation before setup() like so:
// Function prototypes
void handle_OnConnect(void);
void handle_NotFound(void);
etc.
so that the compiler can find them.
I propose you read PlatformIO onboarding and browse some tutorials before doing stuff, it will save you quite some frustration.
Next time, please use markdown formatting to mark it as code. Put ``` before and after your code, or the forum will mangle it.
The compile errors …
src\main.cpp:44:18: error: 'handle_OnConnect' was not declared in this scope
src\main.cpp:46:21: error: 'handle_NotFound' was not declared in this scope
src\main.cpp:65:85: error: 'SendHTML' was not declared in this scope
   server.send(200, "text / html", SendHTML(temperature, humidity, pressure, altitude));
… are due to the fact that we’re not in Arduino land any more, and there is no fancy pre-processing happening. Which @schallbert just explained :slight_smile:
