Arduino IDE has a simple Serial plotter. I am wondering if VS Code PlatformIO has one provided by default?
I suspect this question has been asked before but I could not find it.
my guess is that, it would be easier to just use the arduino plotter
There’s no bultin serial plotter, but alternatives are listed in pre-existing threads about this topic.
You can always use the Arduino plotter even if you’re using PlatformIO as your editor. Just make sure you don’t have a serial monitor going in PlatformIO (aka, make sure the serial port is available).
Fire up the Arduino plotter. Works like a charm
Someone is currently working on this in serialplotter filter by yhur · Pull Request #4058 · platformio/platformio-core · GitHub.
And there’s GitHub - yhur/arduplot now.
