Intellisense VSCODE not giving suggestions
Hello!
The intellisense of platformio builds fine, with no errors and is capable of finding references to different functions. However, it doesn’t offer any suggestions. My cpp properties json file is generated properly and everything works (references) except for the suggestions. Is there anything i can do to solve this?
Could you share your platformio.ini?
[env:nanoatmega328]
board = nanoatmega328
	tockn/MPU6050_tockn@^1.5.2
	adafruit/Adafruit BMP280 Library@^2.6.8
	adafruit/Adafruit Unified Sensor@^1.1.9
	adafruit/Adafruit BusIO@^1.14.1
	SPI
	devinaconley/Plotter@^2.4.1
	adafruit/Adafruit MPU6050@^2.2.4
Do you use the latest VSCode and all extensions are up to date?
Yeah. Everything is up to date and i even reinstalled everything
Can you provide a full screenshot of VSCode with your src/main.cpp open?
cpp properties.json
// !!! WARNING !!! AUTO-GENERATED FILE!
// PLEASE DO NOT MODIFY IT AND USE "platformio.ini":
// https://docs.platformio.org/page/projectconf/section_env_build.html#build-flags
    "configurations": [
            "name": "PlatformIO",
            "includePath": [
                "/Users/vikrant/Documents/PlatformIO/Projects/flight_computer/include",
                "/Users/vikrant/Documents/PlatformIO/Projects/flight_computer/src",
                "/Users/vikrant/Documents/PlatformIO/Projects/flight_computer/.pio/libdeps/nanoatmega328/KalmanFilter/src",
                "/Users/vikrant/Documents/PlatformIO/Projects/flight_computer/.pio/libdeps/nanoatmega328/Adafruit MPU6050",
                "/Users/vikrant/Documents/PlatformIO/Projects/flight_computer/.pio/libdeps/nanoatmega328/Plotter/src",
                "/Users/vikrant/Documents/PlatformIO/Projects/flight_computer/.pio/libdeps/nanoatmega328/Adafruit BMP280 Library",
                "/Users/vikrant/Documents/PlatformIO/Projects/flight_computer/.pio/libdeps/nanoatmega328/Adafruit BusIO",
                "/Users/vikrant/.platformio/packages/framework-arduino-avr/libraries/SPI/src",
                "/Users/vikrant/Documents/PlatformIO/Projects/flight_computer/.pio/libdeps/nanoatmega328/Adafruit Unified Sensor",
                "/Users/vikrant/Documents/PlatformIO/Projects/flight_computer/.pio/libdeps/nanoatmega328/MPU6050_tockn/src",
                "/Users/vikrant/.platformio/packages/framework-arduino-avr/libraries/Wire/src",
                "/Users/vikrant/.platformio/packages/framework-arduino-avr/cores/arduino",
                "/Users/vikrant/.platformio/packages/framework-arduino-avr/variants/eightanaloginputs",
                "/Users/vikrant/Documents/PlatformIO/Projects/flight_computer/.pio/libdeps/nanoatmega328/Adafruit GFX Library",
                "/Users/vikrant/Documents/PlatformIO/Projects/flight_computer/.pio/libdeps/nanoatmega328/Adafruit SSD1306",
                "/Users/vikrant/.platformio/packages/framework-arduino-avr/libraries/EEPROM/src",
                "/Users/vikrant/.platformio/packages/framework-arduino-avr/libraries/HID/src",
                "/Users/vikrant/.platformio/packages/framework-arduino-avr/libraries/SoftwareSerial/src",
            "browse": {
                "limitSymbolsToIncludedHeaders": true,
                "path": [
            "defines": [
                "PLATFORMIO=60110",
                "ARDUINO_AVR_NANO",
                "F_CPU=16000000L",
                "ARDUINO_ARCH_AVR",
                "ARDUINO=10808",
                "__AVR_ATmega328P__",
            "cStandard": "gnu11",
            "cppStandard": "gnu++11",
            "compilerPath": "/Users/vikrant/.platformio/packages/toolchain-atmelavr/bin/avr-gcc",
            "compilerArgs": [
                "-mmcu=atmega328p",
    "version": 4
Looks all fine to me. What are the list of installed extension in the extension sidebar?
Can you deactivate “for this workspace” every extension but C/C++ by Microsoft and PlatformIO?
Still doesn’t work. Only suggestions i get are #endregion and #region
You did restart / reload VSCode after that? If yes, I’d suggest reinstalling VSCode and PlatformIO from scratch that this point (especially delete C:\Users\<user>\.platformio before reinstall)
Do you have any custom settings in VSCode? Maybe you disabled something or changed the keybindings. See Visual Studio Code User and Workspace Settings
For me the problem was this.
C_Cpp: Intelli Sense Engine must be default, not disabled.
This solved it for me as well. Why was this disabled by default? I’ve never touched these settings.
