I’ve only been using PlatformIO for about a week now, so I’m sorry if I’m doing something dumb, but following an update to the C/C++ Extension on VSCode, I’m now getting error squiggles show in the IDE which wern’t there before.
These appear at various points in the codebase, but I don’t think there are any actual errors with my code, as it builds and uploads just fine.
If it helps, my entire codebase is here, but I don’t think it’s an issue with my code itself.
I think it’s related to the C/C++ extension, as I remember opening the extensions tab of the IDE, seeing an update install, and immediately seeing the squiggles after restarting the IDE. I think a second update to the C/C++ extension has been released since, which also auto installed, but as you can see, didn’t solve the issue.
I hope someone can help. Thanks.
I’ve just tried all of that, it didn’t make any difference.
Is this issue similar with?
I started to make the changes as suggested on the link, but it didn’t make any difference.
I decided, instead, to copy the AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS); line from the config.h file into the main.ino file, and that seemed to fix it…
(…other than the fact it’s now complaining that IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS are all undefined.)
This is making me think that the editor is ignoring the code inside the config.h file (which is being included right at the top via #include "config.h"), something it wasn’t doing before.
This is my main.ino file as it exists right this second, along with my config.h file.
Thanks.
It seems like a bug of VSCode C++ extension. I’ve just seen the same errors. How did I resolve them?
- Remove
.vscode folder from a project
- Restart VSCode
It works now
I tried that, but it didn’t work. Oh well. Thanks anyway
Have you resolved this issue? I’ve just downloaded your project and don’t see any issues.
VSCode just updated itself, and I’ve just pulled down the latest PlatformIO update, and yes, I still have the issue.
It’s still only the IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS constants it’s complaining about, since I made these changes, but they’re still complaining about them being missing.
