Incorrect documentation, build_flags -DTEXT_CONST="Some string of text"
This page documents build_flags options, specifically regarding to strings with embedded spaces.
However, none of the examples actually work.
https://docs.platformio.org/en/latest/projectconf/section_env_build.html
What is the proper, current method for defining a constant expression for text?
e.g.
platformio.ini
build_flags = -DWIFI_PASS="My\ pass'word"
results in error
arm-none-eabi-g++.exe: error: pass’word": Invalid argument
‘-DWIFI_PASS=“My password”’
results in error
arm-none-eabi-g++.exe: error: password": Invalid argument
See How could the main.cpp read the parameters at platformio.ini? - #3 by maxgerhardt and Inject Board Name into Code - #2 by maxgerhardt for the correct string escaping technique.
For the documentation bug: I think I remember that that this is also OS-dependent and it works under Linux, but not universally. In any case, you should open an issue at Issues · platformio/platformio-docs · GitHub.
