Include file not found, but builds anyway
I’ve read other posts about this, but have not found a solution as yet.
I get this message when I build the project:
#include errors detected. Please update your includePath. Squiggles are disabled for this translation unit (/home/mac/Documents/PlatformIO/Projects/MyProjectName/src/MyCode.c). cannot open source file "something.h"
The line in the code is:
#include <something>.h
I have tried having the file in the …/src directory and the in the …/include directory.
same message with “something.h” or <something.h>in the include statement.
Yet, the project builds successfully, and runs on the target hardware.
So, what’s wrong with my setup?
Executing the Rebuild Intellisense does not help? Also what VSCode version are you using? Placing the header in src/ should definitely work.
VSC Version: 1.41.0
I don’t know how to execute rebuild intellisense. And, I see no reference to Intellisense in the URL in your response. I’m probably missing something.
Ok, I found the Rebuild Intellisense Index in the task list.
Executing it produced no change, .h file still not found.
Well I cannot reproduce your problem. I just create a new file, fill it with something and reference it. Following it using Ctrl+Click works.
I’m also using the same VSCode version as you, 1.41.0.
grafik
What extensions do you have installed in which version, and what is your PIO core and home version?
Same 3.0.1 and 4.1.0
I do note, that you did an include Arduino.h, I’m not using any arduino, so did not use it the header file. (I don’t see how that matters…
Ok, so I was tinkering with something completely unrelated in a project.
In order to find the FreeRTOS .h files I had to have this:
rather than:
#include "FreeRTOS.h"
So I looked at the project that prompted this post and yes, it required the same.
:thinking:
So, I tried this:
#include <./dmx.h>
And, it no longer throws the error.
So, what is wrong with my install, defualts, etc.? :roll_eyes:
Can you post the structure of the project and the contents of the .vscode/c_cpp_properties.json?
c_cpp_properties.json:
    "configurations": [
            "name": "!!! WARNING !!! AUTO-GENERATED FILE, PLEASE DO NOT MODIFY IT AND USE https://docs.platformio.org/page/projectconf/section_env_build.html#build-flags"
            "name": "Linux",
            "includePath": [
                "/home/mac/Documents/PlatformIO/Projects/Electrol_New_Brains-7/include",
                "/home/mac/Documents/PlatformIO/Projects/Electrol_New_Brains-7/src",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/btc/profile/esp/blufi/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/btc/profile/esp/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/btc/profile/std/a2dp/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/btc/profile/std/hid/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/btc/profile/std/smp/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/btc/profile/std/battery/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/btc/profile/std/dis/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/btc/profile/std/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/btc/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/bta/gatt/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/bta/ar/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/bta/sdp/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/bta/av/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/bta/jv/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/bta/hf_client/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/bta/dm/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/bta/sys/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/bta/hh/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/bta/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/osi/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/api/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/hci/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/external/sbc/decoder/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/external/sbc/encoder/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/common/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/stack/a2dp/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/stack/gatt/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/stack/avdt/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/stack/gap/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/stack/sdp/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/stack/avct/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/stack/btm/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/stack/smp/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/stack/avrc/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/stack/l2cap/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/stack/rfcomm/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/stack/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/device/include",
                "/home/mac/.platformio/packages/framework-espidf/components/app_trace/include",
                "/home/mac/.platformio/packages/framework-espidf/components/app_update/include",
                "/home/mac/.platformio/packages/framework-espidf/components/asio/asio/asio/include",
                "/home/mac/.platformio/packages/framework-espidf/components/asio/port/include",
                "/home/mac/.platformio/packages/framework-espidf/components/aws_iot/include",
                "/home/mac/.platformio/packages/framework-espidf/components/aws_iot/aws-iot-device-sdk-embedded-C/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bootloader_support/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bootloader_support/include_bootloader",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/include",
                "/home/mac/.platformio/packages/framework-espidf/components/bt/bluedroid/api/include/api",
                "/home/mac/.platformio/packages/framework-espidf/components/coap/port/include",
                "/home/mac/.platformio/packages/framework-espidf/components/coap/port/include/coap",
                "/home/mac/.platformio/packages/framework-espidf/components/coap/libcoap/include",
                "/home/mac/.platformio/packages/framework-espidf/components/coap/libcoap/include/coap",
                "/home/mac/.platformio/packages/framework-espidf/components/console",
                "/home/mac/.platformio/packages/framework-espidf/components/driver/include",
                "/home/mac/.platformio/packages/framework-espidf/components/efuse/include",
                "/home/mac/.platformio/packages/framework-espidf/components/efuse/esp32/include",
                "/home/mac/.platformio/packages/framework-espidf/components/esp-tls",
                "/home/mac/.platformio/packages/framework-espidf/components/esp_adc_cal/include",
                "/home/mac/.platformio/packages/framework-espidf/components/esp_event/include",
                "/home/mac/.platformio/packages/framework-espidf/components/esp_http_client/include",
                "/home/mac/.platformio/packages/framework-espidf/components/esp_http_server/include",
                "/home/mac/.platformio/packages/framework-espidf/components/esp_https_server/include",
                "/home/mac/.platformio/packages/framework-espidf/components/esp_https_ota/include",
                "/home/mac/.platformio/packages/framework-espidf/components/esp_ringbuf/include",
                "/home/mac/.platformio/packages/framework-espidf/components/esp32/include",
                "/home/mac/.platformio/packages/framework-espidf/components/espcoredump/include",
                "/home/mac/.platformio/packages/framework-espidf/components/ethernet/include",
                "/home/mac/.platformio/packages/framework-espidf/components/expat/port/include",
                "/home/mac/.platformio/packages/framework-espidf/components/fatfs/src",
                "/home/mac/.platformio/packages/framework-espidf/components/freemodbus/modbus/include",
                "/home/mac/.platformio/packages/framework-espidf/components/freemodbus/modbus_controller",
                "/home/mac/.platformio/packages/framework-espidf/components/freertos/include",
                "/home/mac/.platformio/packages/framework-espidf/components/heap/include",
                "/home/mac/.platformio/packages/framework-espidf/components/jsmn/include",
                "/home/mac/.platformio/packages/framework-espidf/components/json/cJSON",
                "/home/mac/.platformio/packages/framework-espidf/components/libsodium/libsodium/src/libsodium/include",
                "/home/mac/.platformio/packages/framework-espidf/components/libsodium/port_include",
                "/home/mac/.platformio/packages/framework-espidf/components/log/include",
                "/home/mac/.platformio/packages/framework-espidf/components/lwip/include/apps",
                "/home/mac/.platformio/packages/framework-espidf/components/lwip/lwip/src/include",
                "/home/mac/.platformio/packages/framework-espidf/components/lwip/port/esp32/include",
                "/home/mac/.platformio/packages/framework-espidf/components/lwip/port/esp32/include/arch",
                "/home/mac/.platformio/packages/framework-espidf/components/mbedtls/port/include",
                "/home/mac/.platformio/packages/framework-espidf/components/mbedtls/mbedtls/include",
                "/home/mac/.platformio/packages/framework-espidf/components/mdns/include",
                "/home/mac/.platformio/packages/framework-espidf/components/micro-ecc/micro-ecc",
                "/home/mac/.platformio/packages/framework-espidf/components/mqtt/esp-mqtt/include",
                "/home/mac/.platformio/packages/framework-espidf/components/nghttp/nghttp2/lib/includes",
                "/home/mac/.platformio/packages/framework-espidf/components/nghttp/port/include",
                "/home/mac/.platformio/packages/framework-espidf/components/newlib/platform_include",
                "/home/mac/.platformio/packages/framework-espidf/components/newlib/include",
                "/home/mac/.platformio/packages/framework-espidf/components/nvs_flash/include",
                "/home/mac/.platformio/packages/framework-espidf/components/openssl/include",
                "/home/mac/.platformio/packages/framework-espidf/components/protobuf-c/protobuf-c",
                "/home/mac/.platformio/packages/framework-espidf/components/protocomm/include/common",
                "/home/mac/.platformio/packages/framework-espidf/components/protocomm/include/security",
                "/home/mac/.platformio/packages/framework-espidf/components/protocomm/include/transports",
                "/home/mac/.platformio/packages/framework-espidf/components/pthread/include",
                "/home/mac/.platformio/packages/framework-espidf/components/sdmmc/include",
                "/home/mac/.platformio/packages/framework-espidf/components/smartconfig_ack/include",
                "/home/mac/.platformio/packages/framework-espidf/components/soc/esp32/include",
                "/home/mac/.platformio/packages/framework-espidf/components/soc/include",
                "/home/mac/.platformio/packages/framework-espidf/components/spi_flash/include",
                "/home/mac/.platformio/packages/framework-espidf/components/spiffs/include",
                "/home/mac/.platformio/packages/framework-espidf/components/tcp_transport/include",
                "/home/mac/.platformio/packages/framework-espidf/components/tcpip_adapter/include",
                "/home/mac/.platformio/packages/framework-espidf/components/unity/include",
                "/home/mac/.platformio/packages/framework-espidf/components/unity/unity/src",
                "/home/mac/.platformio/packages/framework-espidf/components/ulp/include",
                "/home/mac/.platformio/packages/framework-espidf/components/vfs/include",
                "/home/mac/.platformio/packages/framework-espidf/components/wear_levelling/include",
                "/home/mac/.platformio/packages/framework-espidf/components/wifi_provisioning/include",
                "/home/mac/.platformio/packages/framework-espidf/components/wpa_supplicant/include",
                "/home/mac/.platformio/packages/framework-espidf/components/wpa_supplicant/port/include",
                "/home/mac/.platformio/packages/framework-espidf/components/xtensa-debug-module/include",
                "/home/mac/.platformio/packages/tool-unity",
            "browse": {
                "limitSymbolsToIncludedHeaders": true,
                "path": [
            "defines": [
                "WITH_POSIX",
                "UNITY_INCLUDE_CONFIG_H",
                "IDF_VER=\"3.30300.190916\"",
                "PLATFORMIO=40100",
                "ARDUINO_FEATHER_ESP32",
                "ESP32",
                "ESP_PLATFORM",
                "F_CPU=240000000L",
                "HAVE_CONFIG_H",
                "MBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"",
                "GCC_NOT_5_2_0=0",
                "PROJECT_NAME=\"Electrol_New_Brains-7\"",
                "PROJECT_VER=\"1.0.0\"",
            "intelliSenseMode": "clang-x64",
            "cStandard": "c99",
            "cppStandard": "c++11",
            "compilerPath": "\"/home/mac/.platformio/packages/toolchain-xtensa32/bin/xtensa-esp32-elf-gcc\" -mlongcalls"
    "version": 4
Project structure:
~/Documents/PlatformIO/Projects/Electrol_New_Brains-2$ ls -la -r
total 68
drwxrwxr-x  2 mac mac  4096 Sep 11 14:18 .vscode
-rw-rw-r--  1 mac mac  1557 Sep 11 14:18 .travis.yml
drwxrwxr-x  2 mac mac  4096 Sep 11 14:18 test
drwxrwxr-x  2 mac mac  4096 Sep 11 14:20 src
-rw-rw-r--  1 mac mac   501 Nov 24 10:44 platformio.ini
drwxrwxr-x  4 mac mac  4096 Nov 24 10:44 .pio
drwxrwxr-x  2 mac mac  4096 Sep 11 14:18 lib
-rw-rw-r--  1 mac mac 21324 Dec  8 09:17 Journal.odt
drwxrwxr-x  2 mac mac  4096 Sep 11 14:18 include
-rw-rw-r--  1 mac mac    94 Sep 11 14:18 .gitignore
drwxrwxr-x 30 mac mac  4096 Dec 18 09:30 ..
drwxrwxr-x  8 mac mac  4096 Dec 11 15:08 .
This doesn’t show all files. Can you do a tree command or show the file structure in VSCode? Also the contents of the platformio.ini and any source or header files please.
├── include
│ ├── dmx.h
│ └── README
├── lib
│ └── README
├── platformio.ini
├── src
│ ├── dmx.c
│ ├── Electrol_New_Brains.c
│ ├── sdkconfig
│ └── sdkconfig.h
└── test
└── README
platformio.ini:
monitor_port=/dev/ttyUSB0
monitor_speed=115200
[env:featheresp32]
board = featheresp32
framework = espidf
Well the folder is right there in the includes so dmx.h should be found.
Can you show
  • the contents of the source files
  • list of installed VSCode extension
This produces no error:
#include <stdint.h>
#include <string.h>
#include <./dmx.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "esp_attr.h"
#include "soc/rtc.h"
#include "driver/mcpwm.h"
#include "driver/timer.h"
#include "driver/gpio.h"
This does:
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#include <dmx.h>
extensions
I apparently don’t know how to include images in a post…:thinking:
I took an image of the extensions…
But the list of enabled:
  • C/C++
  • C++ Intellisense
  • PlatformIO IDE
Also installed:
  • openHAB
  • Python
Can you please disable the “C++ Intellisense” plugin from austin and restart VSCode. No special Intellisense plugin is needed which not provided by the C/C++ extension.
I have no idea when that was installed.
I disabled it.
restart VSC.
Now:
Not found:
#include <dmx.h>
And, not found:
#include <./dmx.h>
No change after the Rebuild Intellisense Task is executed?
Tried that and Update project libraries. In both cases (<dmx.h> and <./dmx.h>)
Does uninstalling instead of disabling the extension make a difference?
Uninstalled, restarted, no difference.
But, it does now recomend that I install C++ Intellisense austin
:wink:
