lbussy
July 25, 2020, 4:18pm
1
Getting an error that’s really annoying me.
I have a “bootstrap” project I use to start out my projects. Standard stuff for all my projects. So here’s what I did:
Create a new empty GitHub project
Clone to my computer
Copy all files and folders from my bootstrap (except for .pio and .vscode) into the project folder
Open in VSCode/PlatformIO
At this point all seems fine. If I compile, I get the following error:
*** [.pio\build\lolin_d32\firmware.elf] Implicit dependency `C:\Users\xxxxxxxx\.platformio\platforms\espressif32\builder\Warning:' not found, needed by target `.pio\build\lolin_d32\firmware.elf'.
I look in that folder, and there is no firmware.elf being created.
I can completely wipe the source files to something like this
void setup() {;}
void loop() {;}
… and I get the same error.
Keep in mind this is a project which compiles just fine in the original folder.
I did disable my antivirus (Bitdefender) which has caused weird issues before.
I am quite sure I’m doing something wrong but I am not sure what. So confused!
Can you provide the full context:
Full build log
Contents of platformio.ini
Project structure (directory view)
lbussy
July 26, 2020, 1:41pm
3
Thanks for helping @manuelbl !
Build log:
> Executing task: C:\Users\xxxxxxxx\.platformio\penv\Scripts\platformio.exe run <
Processing lolin_d32 (framework: arduino; platform: espressif32; board: lolin_d32)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/lolin_d32.html
PLATFORM: Espressif 32 1.12.4 > WEMOS LOLIN D32
Found 32 compatible libraries
|-- <ArduinoLog> 1.0.3 #13eeea1
|-- <ESP Async WebServer> 1.2.3 #1304662
| |-- <AsyncTCP> 1.1.1 #81c1f43
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <AsyncWiFiManager> 1.0.0 #1f00859
| |-- <DNSServer> 1.1.0
| | |-- <WiFi> 1.0
| | |-- <FS> 1.0
| | |-- <WiFi> 1.0
| |-- <ESPmDNS> 1.0
| | |-- <WiFi> 1.0
| |-- <WebServer> 1.0
| | |-- <WiFi> 1.0
| | |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <asyncHTTPrequest> 1.2.1 #b350f96
|-- <CircularBuffer> 1.3.3 #98e638a
|-- <ESPmDNS> 1.0
| |-- <WiFi> 1.0
|-- <WiFi> 1.0
|-- <Ticker> 1.1
|-- <FS> 1.0
|-- <SPIFFS> 1.0
| |-- <FS> 1.0
Building in debug mode
Compiling .pio\build\lolin_d32\src\main.cpp.o
Compiling .pio\build\lolin_d32\src\mdnshandler.cpp.o
Compiling .pio\build\lolin_d32\src\ntphandler.cpp.o
Compiling .pio\build\lolin_d32\src\serialhandler.cpp.o
Compiling .pio\build\lolin_d32\src\tools.cpp.o
Compiling .pio\build\lolin_d32\src\version.cpp.o
Compiling .pio\build\lolin_d32\src\webpagehandler.cpp.o
Compiling .pio\build\lolin_d32\src\wifihandler.cpp.o
Generating partitions .pio\build\lolin_d32\partitions.bin
Compiling .pio\build\lolin_d32\lib076\ArduinoLog\ArduinoLog.cpp.o
Compiling .pio\build\lolin_d32\libe43\AsyncTCP\AsyncTCP.cpp.o
Compiling .pio\build\lolin_d32\lib6c2\FS\FS.cpp.o
Compiling .pio\build\lolin_d32\lib6c2\FS\vfs_api.cpp.o
Compiling .pio\build\lolin_d32\libaeb\WiFi\ETH.cpp.o
Compiling .pio\build\lolin_d32\libaeb\WiFi\WiFi.cpp.o
Compiling .pio\build\lolin_d32\libaeb\WiFi\WiFiAP.cpp.o
Compiling .pio\build\lolin_d32\libaeb\WiFi\WiFiClient.cpp.o
Compiling .pio\build\lolin_d32\libaeb\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\lolin_d32\libaeb\WiFi\WiFiMulti.cpp.o
Archiving .pio\build\lolin_d32\lib076\libArduinoLog.a
Compiling .pio\build\lolin_d32\libaeb\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\lolin_d32\libaeb\WiFi\WiFiScan.cpp.o
Archiving .pio\build\lolin_d32\libe43\libAsyncTCP.a
Compiling .pio\build\lolin_d32\libaeb\WiFi\WiFiServer.cpp.o
Archiving .pio\build\lolin_d32\lib6c2\libFS.a
Compiling .pio\build\lolin_d32\libaeb\WiFi\WiFiUdp.cpp.o
Compiling .pio\build\lolin_d32\lib70d\ESP Async WebServer\AsyncEventSource.cpp.o
Compiling .pio\build\lolin_d32\lib70d\ESP Async WebServer\AsyncWebSocket.cpp.o
Compiling .pio\build\lolin_d32\lib70d\ESP Async WebServer\SPIFFSEditor.cpp.o
Compiling .pio\build\lolin_d32\lib70d\ESP Async WebServer\WebAuthentication.cpp.o
Compiling .pio\build\lolin_d32\lib70d\ESP Async WebServer\WebHandlers.cpp.o
Compiling .pio\build\lolin_d32\lib70d\ESP Async WebServer\WebRequest.cpp.o
Compiling .pio\build\lolin_d32\lib70d\ESP Async WebServer\WebResponses.cpp.o
Compiling .pio\build\lolin_d32\lib70d\ESP Async WebServer\WebServer.cpp.o
Compiling .pio\build\lolin_d32\lib92e\DNSServer\DNSServer.cpp.o
Compiling .pio\build\lolin_d32\lib005\ESPmDNS\ESPmDNS.cpp.o
Compiling .pio\build\lolin_d32\lib667\WebServer\Parsing.cpp.o
Archiving .pio\build\lolin_d32\libaeb\libWiFi.a
Compiling .pio\build\lolin_d32\lib667\WebServer\WebServer.cpp.o
Compiling .pio\build\lolin_d32\lib667\WebServer\detail\mimetable.cpp.o
Compiling .pio\build\lolin_d32\lib38f\AsyncWiFiManager\AsyncWiFiManager.cpp.o
Compiling .pio\build\lolin_d32\lib42a\asyncHTTPrequest\asyncHTTPrequest.cpp.o
Compiling .pio\build\lolin_d32\lib42a\asyncHTTPrequest\xbuf.cpp.o
Archiving .pio\build\lolin_d32\lib6ac\libCircularBuffer.a
Compiling .pio\build\lolin_d32\lib28a\Ticker\Ticker.cpp.o
Compiling .pio\build\lolin_d32\libc5f\SPIFFS\SPIFFS.cpp.o
Archiving .pio\build\lolin_d32\lib92e\libDNSServer.a
Archiving .pio\build\lolin_d32\lib70d\libESP Async WebServer.a
Archiving .pio\build\lolin_d32\libFrameworkArduinoVariant.a
Archiving .pio\build\lolin_d32\lib005\libESPmDNS.a
Compiling .pio\build\lolin_d32\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\lolin_d32\FrameworkArduino\FunctionalInterrupt.cpp.o
Archiving .pio\build\lolin_d32\lib667\libWebServer.a
Compiling .pio\build\lolin_d32\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\lolin_d32\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\lolin_d32\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\lolin_d32\FrameworkArduino\MD5Builder.cpp.o
Archiving .pio\build\lolin_d32\lib42a\libasyncHTTPrequest.a
Compiling .pio\build\lolin_d32\FrameworkArduino\Print.cpp.o
Archiving .pio\build\lolin_d32\lib28a\libTicker.a
Archiving .pio\build\lolin_d32\libc5f\libSPIFFS.a
Archiving .pio\build\lolin_d32\lib38f\libAsyncWiFiManager.a
Compiling .pio\build\lolin_d32\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\lolin_d32\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\lolin_d32\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\lolin_d32\FrameworkArduino\WString.cpp.o
Compiling .pio\build\lolin_d32\FrameworkArduino\base64.cpp.o
Compiling .pio\build\lolin_d32\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\main.cpp.o
Compiling .pio\build\lolin_d32\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\lolin_d32\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\lolin_d32\libFrameworkArduino.a
============================================================================================= [FAILED] Took 30.50 seconds =============================================================================================
Environment Status Duration
d1_mini IGNORED
lolin_d32 FAILED 00:00:30.496
heltec_wifi_kit_32 IGNORED
======================================================================================== 1 failed, 0 succeeded in 00:00:30.496 ========================================================================================
The terminal process "C:\Users\xxxxxxxx\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
Contents of platformio.ini:
[platformio]
; default_envs = heltec_wifi_kit_32
; default_envs = d1_mini
default_envs = lolin_d32
[common_env_data]
upload_speed = 921600
build_unflags =
!python tools\git_rev.py
-DBAUD=${common_env_data.monitor_speed}
https://github.com/lbussy/Arduino-Log.git
https://github.com/lbussy/ESPAsyncWebServer.git
https://github.com/lbussy/AsyncWiFiManager.git
https://github.com/lbussy/asyncHTTPrequest.git
https://github.com/lbussy/CircularBuffer.git
extra_scripts =
build_type = debug
monitor_filters =
log2file
[env:d1_mini]
upload_speed = ${common_env_data.upload_speed}
monitor_speed = ${common_env_data.monitor_speed}
framework = ${common_env_data.framework}
build_unflags = ${common_env_data.build_unflags}
build_flags = ${common_env_data.build_flags}
extra_scripts = ${common_env_data.extra_scripts}
lib_deps = ${common_env_data.lib_deps}
build_type = ${common_env_data.build_type}
monitor_filters = ${common_env_data.monitor_filters}
platform = espressif8266
board = d1_mini
[env:lolin_d32]
monitor_filters =
esp32_exception_decoder
board = lolin_d32
[env:heltec_wifi_kit_32]
monitor_filters =
board = heltec_wifi_kit_32
Project Structure:
C:.
├───.pio
│ ├───build
│ └───libdeps
│ └───lolin_d32
│ ├───ArduinoLog
│ │ ├───.git
│ │ │ ├───hooks
│ │ │ ├───info
│ │ │ ├───logs
│ │ │ │ └───refs
│ │ │ │ ├───heads
│ │ │ │ └───remotes
│ │ │ │ └───origin
│ │ │ ├───objects
│ │ │ │ ├───13
│ │ │ │ ├───16
│ │ │ │ ├───23
│ │ │ │ ├───4d
│ │ │ │ ├───6c
│ │ │ │ ├───7b
│ │ │ │ ├───8c
│ │ │ │ ├───94
│ │ │ │ ├───a2
│ │ │ │ ├───b4
│ │ │ │ ├───e0
│ │ │ │ ├───e7
│ │ │ │ ├───f3
│ │ │ │ ├───info
│ │ │ │ └───pack
│ │ │ └───refs
│ │ │ ├───heads
│ │ │ ├───remotes
│ │ │ │ └───origin
│ │ │ └───tags
│ │ └───examples
│ │ └───Log
│ ├───asyncHTTPrequest
│ │ ├───.git
│ │ │ ├───hooks
│ │ │ ├───info
│ │ │ ├───logs
│ │ │ │ └───refs
│ │ │ │ ├───heads
│ │ │ │ └───remotes
│ │ │ │ └───origin
│ │ │ ├───objects
│ │ │ │ ├───27
│ │ │ │ ├───37
│ │ │ │ ├───4d
│ │ │ │ ├───52
│ │ │ │ ├───58
│ │ │ │ ├───63
│ │ │ │ ├───64
│ │ │ │ ├───70
│ │ │ │ ├───77
│ │ │ │ ├───94
│ │ │ │ ├───9e
│ │ │ │ ├───a3
│ │ │ │ ├───a9
│ │ │ │ ├───b3
│ │ │ │ ├───bf
│ │ │ │ ├───c8
│ │ │ │ ├───ce
│ │ │ │ ├───db
│ │ │ │ ├───e6
│ │ │ │ ├───eb
│ │ │ │ ├───ed
│ │ │ │ ├───f4
│ │ │ │ ├───info
│ │ │ │ └───pack
│ │ │ └───refs
│ │ │ ├───heads
│ │ │ ├───remotes
│ │ │ │ └───origin
│ │ │ └───tags
│ │ ├───.pio
│ │ │ └───build
│ │ ├───.vscode
│ │ ├───lib
│ │ ├───sample
│ │ └───src
│ ├───AsyncTCP
│ │ ├───.git
│ │ │ ├───hooks
│ │ │ ├───info
│ │ │ ├───logs
│ │ │ │ └───refs
│ │ │ │ ├───heads
│ │ │ │ └───remotes
│ │ │ │ └───origin
│ │ │ ├───objects
│ │ │ │ ├───15
│ │ │ │ ├───17
│ │ │ │ ├───36
│ │ │ │ ├───37
│ │ │ │ ├───5c
│ │ │ │ ├───61
│ │ │ │ ├───65
│ │ │ │ ├───6e
│ │ │ │ ├───7e
│ │ │ │ ├───81
│ │ │ │ ├───89
│ │ │ │ ├───97
│ │ │ │ ├───9b
│ │ │ │ ├───a4
│ │ │ │ ├───ac
│ │ │ │ ├───b7
│ │ │ │ ├───bb
│ │ │ │ ├───ce
│ │ │ │ ├───cf
│ │ │ │ ├───d5
│ │ │ │ ├───d9
│ │ │ │ ├───ec
│ │ │ │ ├───f5
│ │ │ │ ├───info
│ │ │ │ └───pack
│ │ │ └───refs
│ │ │ ├───heads
│ │ │ ├───remotes
│ │ │ │ └───origin
│ │ │ └───tags
│ │ ├───.github
│ │ │ ├───scripts
│ │ │ └───workflows
│ │ └───src
│ ├───AsyncWiFiManager
│ │ ├───.git
│ │ │ ├───hooks
│ │ │ ├───info
│ │ │ ├───logs
│ │ │ │ └───refs
│ │ │ │ ├───heads
│ │ │ │ └───remotes
│ │ │ │ └───origin
│ │ │ ├───objects
│ │ │ │ ├───07
│ │ │ │ ├───0f
│ │ │ │ ├───12
│ │ │ │ ├───16
│ │ │ │ ├───19
│ │ │ │ ├───1d
│ │ │ │ ├───1f
│ │ │ │ ├───28
│ │ │ │ ├───34
│ │ │ │ ├───3b
│ │ │ │ ├───45
│ │ │ │ ├───4b
│ │ │ │ ├───51
│ │ │ │ ├───57
│ │ │ │ ├───5a
│ │ │ │ ├───60
│ │ │ │ ├───67
│ │ │ │ ├───6a
│ │ │ │ ├───71
│ │ │ │ ├───72
│ │ │ │ ├───7b
│ │ │ │ ├───7c
│ │ │ │ ├───80
│ │ │ │ ├───81
│ │ │ │ ├───86
│ │ │ │ ├───8c
│ │ │ │ ├───90
│ │ │ │ ├───9a
│ │ │ │ ├───9c
│ │ │ │ ├───9d
│ │ │ │ ├───9e
│ │ │ │ ├───9f
│ │ │ │ ├───a2
│ │ │ │ ├───a3
│ │ │ │ ├───ac
│ │ │ │ ├───af
│ │ │ │ ├───b6
│ │ │ │ ├───b7
│ │ │ │ ├───b8
│ │ │ │ ├───bd
│ │ │ │ ├───bf
│ │ │ │ ├───c0
│ │ │ │ ├───c2
│ │ │ │ ├───c6
│ │ │ │ ├───cf
│ │ │ │ ├───d3
│ │ │ │ ├───d5
│ │ │ │ ├───d6
│ │ │ │ ├───e2
│ │ │ │ ├───e5
│ │ │ │ ├───e8
│ │ │ │ ├───e9
│ │ │ │ ├───ea
│ │ │ │ ├───ed
│ │ │ │ ├───f0
│ │ │ │ ├───fa
│ │ │ │ ├───fb
│ │ │ │ ├───fc
│ │ │ │ ├───info
│ │ │ │ └───pack
│ │ │ └───refs
│ │ │ ├───heads
│ │ │ ├───remotes
│ │ │ │ └───origin
│ │ │ └───tags
│ │ ├───.github
│ │ ├───.vscode
│ │ ├───examples
│ │ │ ├───Advanced
│ │ │ ├───AutoConnect
│ │ │ │ ├───AutoConnectWithFeedbackLED
│ │ │ │ ├───AutoConnectWithFSParameters
│ │ │ │ └───AutoConnectWithFSParametersAndCustomIP
│ │ │ ├───Basic
│ │ │ ├───DEV
│ │ │ │ └───OnDemandConfigPortal
│ │ │ ├───NonBlocking
│ │ │ │ ├───AutoConnectNonBlocking
│ │ │ │ ├───AutoConnectNonBlockingwParams
│ │ │ │ └───OnDemandNonBlocking
│ │ │ ├───Old_examples
│ │ │ │ ├───AutoConnectWithReset
│ │ │ │ ├───AutoConnectWithStaticIP
│ │ │ │ └───AutoConnectWithTimeout
│ │ │ ├───OnDemand
│ │ │ │ ├───OnDemandConfigPortal
│ │ │ │ └───OnDemandWebPortal
│ │ │ └───ParamsChildClass
│ │ ├───extras
│ │ ├───include
│ │ ├───src
│ │ └───travis
│ ├───CircularBuffer
│ │ ├───.git
│ │ │ ├───hooks
│ │ │ ├───info
│ │ │ ├───logs
│ │ │ │ └───refs
│ │ │ │ ├───heads
│ │ │ │ └───remotes
│ │ │ │ └───origin
│ │ │ ├───objects
│ │ │ │ ├───01
│ │ │ │ ├───02
│ │ │ │ ├───0a
│ │ │ │ ├───0d
│ │ │ │ ├───2a
│ │ │ │ ├───2b
│ │ │ │ ├───38
│ │ │ │ ├───56
│ │ │ │ ├───62
│ │ │ │ ├───66
│ │ │ │ ├───68
│ │ │ │ ├───82
│ │ │ │ ├───8c
│ │ │ │ ├───8f
│ │ │ │ ├───90
│ │ │ │ ├───98
│ │ │ │ ├───9b
│ │ │ │ ├───9f
│ │ │ │ ├───a0
│ │ │ │ ├───ab
│ │ │ │ ├───b1
│ │ │ │ ├───bd
│ │ │ │ ├───c5
│ │ │ │ ├───d9
│ │ │ │ ├───dd
│ │ │ │ ├───e1
│ │ │ │ ├───e8
│ │ │ │ ├───info
│ │ │ │ └───pack
│ │ │ └───refs
│ │ │ ├───heads
│ │ │ ├───remotes
│ │ │ │ └───origin
│ │ │ └───tags
│ │ └───examples
│ │ ├───CircularBuffer
│ │ ├───EventLogging
│ │ ├───Interrupts
│ │ ├───Object
│ │ ├───Queue
│ │ ├───Stack
│ │ ├───Struct
│ │ └───Test
│ ├───ESP Async WebServer
│ │ ├───.git
│ │ │ ├───hooks
│ │ │ ├───info
│ │ │ ├───logs
│ │ │ │ └───refs
│ │ │ │ ├───heads
│ │ │ │ └───remotes
│ │ │ │ └───origin
│ │ │ ├───objects
│ │ │ │ ├───04
│ │ │ │ ├───09
│ │ │ │ ├───11
│ │ │ │ ├───13
│ │ │ │ ├───1f
│ │ │ │ ├───26
│ │ │ │ ├───27
│ │ │ │ ├───28
│ │ │ │ ├───2f
│ │ │ │ ├───31
│ │ │ │ ├───34
│ │ │ │ ├───35
│ │ │ │ ├───43
│ │ │ │ ├───4c
│ │ │ │ ├───52
│ │ │ │ ├───59
│ │ │ │ ├───5a
│ │ │ │ ├───5b
│ │ │ │ ├───64
│ │ │ │ ├───68
│ │ │ │ ├───6c
│ │ │ │ ├───71
│ │ │ │ ├───75
│ │ │ │ ├───7b
│ │ │ │ ├───7c
│ │ │ │ ├───92
│ │ │ │ ├───95
│ │ │ │ ├───96
│ │ │ │ ├───9a
│ │ │ │ ├───9e
│ │ │ │ ├───a0
│ │ │ │ ├───a2
│ │ │ │ ├───a8
│ │ │ │ ├───a9
│ │ │ │ ├───ab
│ │ │ │ ├───b0
│ │ │ │ ├───bb
│ │ │ │ ├───bd
│ │ │ │ ├───bf
│ │ │ │ ├───c0
│ │ │ │ ├───c3
│ │ │ │ ├───c4
│ │ │ │ ├───ce
│ │ │ │ ├───cf
│ │ │ │ ├───d1
│ │ │ │ ├───d6
│ │ │ │ ├───da
│ │ │ │ ├───e1
│ │ │ │ ├───e7
│ │ │ │ ├───eb
│ │ │ │ ├───ec
│ │ │ │ ├───f2
│ │ │ │ ├───f3
│ │ │ │ ├───fb
│ │ │ │ ├───ff
│ │ │ │ ├───info
│ │ │ │ └───pack
│ │ │ └───refs
│ │ │ ├───heads
│ │ │ ├───remotes
│ │ │ │ └───origin
│ │ │ └───tags
│ │ ├───.github
│ │ │ ├───scripts
│ │ │ └───workflows
│ │ ├───examples
│ │ │ ├───CaptivePortal
│ │ │ ├───ESP_AsyncFSBrowser
│ │ │ │ └───data
│ │ │ ├───regex_patterns
│ │ │ └───simple_server
│ │ └───src
│ └───ESPAsyncTCP
│ ├───.git
│ │ ├───hooks
│ │ ├───info
│ │ ├───logs
│ │ │ └───refs
│ │ │ ├───heads
│ │ │ └───remotes
│ │ │ └───origin
│ │ ├───objects
│ │ │ ├───04
│ │ │ ├───08
│ │ │ ├───0e
│ │ │ ├───11
│ │ │ ├───15
│ │ │ ├───1b
│ │ │ ├───29
│ │ │ ├───2d
│ │ │ ├───35
│ │ │ ├───39
│ │ │ ├───3a
│ │ │ ├───5a
│ │ │ ├───5e
│ │ │ ├───61
│ │ │ ├───63
│ │ │ ├───65
│ │ │ ├───66
│ │ │ ├───6b
│ │ │ ├───6e
│ │ │ ├───71
│ │ │ ├───7a
│ │ │ ├───7b
│ │ │ ├───7c
│ │ │ ├───7e
│ │ │ ├───83
│ │ │ ├───87
│ │ │ ├───8a
│ │ │ ├───97
│ │ │ ├───9b
│ │ │ ├───b3
│ │ │ ├───b5
│ │ │ ├───c3
│ │ │ ├───c8
│ │ │ ├───ca
│ │ │ ├───cb
│ │ │ ├───cd
│ │ │ ├───ce
│ │ │ ├───cf
│ │ │ ├───d2
│ │ │ ├───d8
│ │ │ ├───e6
│ │ │ ├───fd
│ │ │ ├───info
│ │ │ └───pack
│ │ └───refs
│ │ ├───heads
│ │ ├───remotes
│ │ │ └───origin
│ │ └───tags
│ ├───.github
│ │ ├───scripts
│ │ └───workflows
│ ├───examples
│ │ ├───ClientServer
│ │ │ ├───Client
│ │ │ └───Server
│ │ └───SyncClient
│ ├───src
│ └───ssl
├───data
├───include
├───lib
├───src
├───test
└───tools
I don’t know what the python script git_rev.py does but it’s likely the problem.
I’ve created a simple python script and saved it in tools/git_rev.py:
print("Warning: watch out")
Without !python tools\git_rev.py, your platformio.ini file works. With it, I get almost the same error message like you. In fact, the word Warning is from the python script. If I change it in the script, the error message changes as well.
*** [.pio/build/lolin_d32/firmware.elf] Implicit dependency `/Users/me/.platformio/platforms/espressif32/builder/Warning:' not found, needed by target `.pio/build/lolin_d32/firmware.elf'.
lbussy
July 26, 2020, 2:28pm
5
That is the strangest thing!
I use that to give me git information for versioning and such within my programs:
import subprocess
import os
if os.name == "nt":
null = "nul"
else:
null = "/dev/null"
# Get Git project name (directory name)
try:
projcmd = "git rev-parse --show-toplevel 2> " + null
project = subprocess.check_output(projcmd, shell=True).decode().strip()
project = project.split("/")
project = project[len(project)-1]
except:
project = os.path.split(os.getcwd())[1]
print("Warning: Unable to determine git project name, using '" + project + "' as version.")
# Get 0.0.0 version from latest Git tag
try:
tagcmd = "git describe --tags --abbrev=0 2> " + null
version = subprocess.check_output(tagcmd, shell=True).decode().strip()
except:
print("Warning: Unable to determine git tags, using '0.0.0' as version.")
version = "0.0.0"
# Get latest commit short from Git
try:
revcmd = "git log --pretty=format:'%h' -n 1 2> " + null
commit = subprocess.check_output(revcmd, shell=True).decode().strip()
except:
print("Warning: Unable to determine git commit, using 'abcdef0' as commit.")
commit = "'abcdef0'"
# Get branch name from Git
try:
branchcmd = "git rev-parse --abbrev-ref HEAD 2> " + null
branch = subprocess.check_output(branchcmd, shell=True).decode().strip()
except:
print("Warning: Unable to determine git branch, using 'master' as branch.")
branch = "master"
# Make all available for use in the macros
print("-DPIO_SRC_NAM={0}".format(project))
print("-DPIO_SRC_TAG={0}".format(version))
print("-DPIO_SRC_REV={0}".format(commit))
print("-DPIO_SRC_BRH={0}".format(branch))
It works elsewhere (I use it in nearly every project,) I wonder why it’s not working here. So weird.
yml0305
December 27, 2021, 11:08am
6
I had exactly the same problem, I finally found the reason: I added the wrong space。
wrong:
build_flags = DMENABLED = 0
write:
build_flags = DMENABLED=0
you saved my day, bad C habbit #define don’t need = and in the ini you need it
-D NEOPIXEL_LEDS 3
-D NEOPIXEL_DATA 4
This works
-D NEOPIXEL_LEDS=3
-D NEOPIXEL_DATA=4
It is amazing how a simple space can be a problem, an easy fix, when you know . Thank you I had the same problem. It is working fine now
Claudio
Yes, the -D statement behaves slightly differently than a #define within the code.
Especially when it comes to strings.
Then you have to enclose the whole line with ' like so:
'-D HELLO="WORLD"'.
Although this is also stated in the documentation, it can easily be overlooked.
