I handl in the school ardoino ide and we write a code the did work there but it did no work in the platform IO i dont know why can any body help thanks<3
#define T0 34
#define T1 35
#define T2 36
#define LED 2
void setup()
pinMode(LED, OUTPUT);
pinMode(T0, INPUT);
pinMode(T1, INPUT);
pinMode(T2, INPUT);
digitalWrite(LED, HIGH);
attachInterrupt(digitalPinToInterrupt(T0), isr_T0, FALLING);
void loop()
if (digitalRead(T1) == LOW)
if (digitalRead(T2) == LOW)
digitalWrite(LED, LOW);
void isr_T0()
You’ll find the answer here Convert Arduino file to C++ manually — PlatformIO latest documentation
Please use pre-formatted text when posting code or log files.
Also post the error log or at least describe the error you receive.
This will make it easier to help you.
When I try to compile your code in a project, the following error message appears:
src/main.cpp: In function 'void setup()':
src/main.cpp:15:44: error: 'isr_T0' was not declared in this scope
This means the declaration of the function is missing.
#define T0 34
#define T1 35
#define T2 36
#define LED 2
**void isr_T0();**  // <------- that was it
void setup()
pinMode(T0, INPUT);
pinMode(T1, INPUT);
pinMode(T2, INPUT);
void loop()
void isr_T0()
https://learn.microsoft.com/en-us/cpp/cpp/declarations-and-definitions-cpp?view=msvc-170
I didn’t have an ESP board at hand and didn’t test the hardware requirements but if it worked in the Arduino IDE, it should work now :wink:
best regards
Holger
void isr_T0();
of course without the asterisks :slightly_smiling_face:
Why the “bold” font didn’t work here, no idea! :face_with_raised_eyebrow:
Formatting styles cannot be applied within a pre-formatted text block as the text is already formatted.
