Hardware:
Board: ESP32 DEVKIT1
Core Installation version: 1.0.1-git this one
IDE name: PlatformIO IDE
Flash Frequency: 80Mhz
PSRAM enabled: no
Upload Speed: 921600
Computer OS: Linux Mint 19.1 Mate
Hello there !
I’m having troubles receiving the response from a URL when using Static IP. All works perfectly fine using DHCP IP.
I assume the ESP32 connects to the internet because I can access the webpage (which has a HTML input form where one can enter the URL) using the Static IP.
Long story short I am reading lines from a SPIFFS file and storing them in an String array x[].
void setup () {
if(x[0] != NULL && // SSID
x[0].length() != 0 &&
x[1] != NULL && // Password
x[1].length() != 0 &&
x[2] != NULL && //Local IP
x[2].length() != 0 &&
x[3] != NULL && // Gateway
x[3].length() != 0 &&
x[4] != NULL && // Subnet
x[4].length() != 0) {
IPAddress local_IP_STA, gateway_STA, subnet_STA;
local_IP_STA.fromString(x[2]);
gateway_STA.fromString(x[3]);
subnet_STA.fromString(x[4]);
IPAddress primaryDNS(8, 8, 8, 8);
IPAddress secondaryDNS(8, 8, 4, 4);
WiFi.begin(x[0].c_str(),x[1].c_str());
delay(50);
if(!WiFi.config(local_IP_STA, gateway_STA, subnet_STA, primaryDNS))
Serial.println("Couldn't configure STATIC IP ! Starting DHCP IP !");
delay(50);
if ((WiFi.status() == WL_CONNECTED)) {
HTTPClient http;
http.begin(URL);
int httpCode = http.GET(); //Make the request
if (httpCode > 0) { //Check for the returning code
Serial.printf("[HTTP] GET... code: %d\n", httpCode);
if(httpCode == HTTP_CODE_OK) {
String payload = http.getString();
Serial.println(payload);
} else {
Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
} // while
delay(10000);
WiFi.config(local_IP_STA, gateway_STA, subnet_STA, primaryDNS) or
WiFi.config(local_IP_STA, gateway_STA, subnet_STA, primaryDNS, secondaryDNS) returns
[E][WiFiGeneric.cpp:658] hostByName(): DNS Failed for jsonplaceholder.typicode.com
[HTTP] GET... failed, error: connection refused
I’ve also moved WiFi.config() before and after the WiFi.begin() but nothing changed.
What do you think the problem is ?
Yeah, that looks more like it!
