Hello there!
I’m trying to log data from ESP32 to Google Sheets via Google App Script. If I only use wifi.begin() via DHCP IP then there is no problem. But when I set static IP for ESP32 for uploading the code to ESP32, then use wifi.begin() to send data to Sheets, I get the problem of connection failure. I guess the problem maybe that I set the static IP wrong. Below is my code:
//Include required libraries
#include "WiFi.h"
#include <HTTPClient.h>
#include "time.h"
#include <WiFiClient.h>
#include <Update.h>
const char* ntpServer = "pool.ntp.org";
const long gmtOffset_sec = 19800;
const int daylightOffset_sec = 0;
IPAddress local_ip(192, 168, 1, 4);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
// WiFi credentials
const char* ssid = ""; // change SSID
const char* password = ""; // change password
// Google script ID and required credentials
String GOOGLE_SCRIPT_ID = ""; // change Gscript ID
int count = 0;
delay(1000);
delay(1000);
// connect to WiFi
Serial.println();
Serial.print("Connecting to wifi: ");
Serial.println(ssid);
Serial.flush();
WiFi.config(local_ip, gateway, subnet);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
// Init and get the time
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
if (WiFi.status() == WL_CONNECTED) {
static bool flag = false;
struct tm timeinfo;
if (!getLocalTime(&timeinfo)) {
Serial.println("Failed to obtain time");
return;
char timeStringBuff[50]; //50 chars should be enough
strftime(timeStringBuff, sizeof(timeStringBuff), "%A, %B %d %Y %H:%M:%S", &timeinfo);
String asString(timeStringBuff);
asString.replace(" ", "-");
Serial.print("Time:");
Serial.println(asString);
String urlFinal = "https://script.google.com/macros/s/"+GOOGLE_SCRIPT_ID+"/exec?"+"date=" + asString + "&lan_1=" + "100"
+"&lan_2=" + "200"+"&lan_3=" + "300"+"&trung_binh=" + "250";
Serial.print("POST data to spreadsheet:");
Serial.println(urlFinal);
HTTPClient http;
http.begin(urlFinal.c_str());
http.setFollowRedirects(HTTPC_STRICT_FOLLOW_REDIRECTS);
int httpCode = http.GET();
Serial.print("HTTP Status Code: ");
Serial.println(httpCode);
//getting response from google sheet
String payload;
if (httpCode > 0) {
payload = http.getString();
Serial.println("Payload: "+payload);
http.end();
count++;
delay(1000);
I have read this post and tried but it did not work.
What do you think the problem is?
