I bought a STM32F103C8T6 “Bluepill” board from Amazon.
I am using a 2017 Intel Mac, running Ventura 13.2.1.
I would like to do the following:
- Upload “sketches” (firmware) via USB
- Do serial send and receive via USB
I assume both things are possible.
Please see my question at the end of the post.
Board image
Background
I do understand that there may be obstacles:
- R10 on the board may be of wrong value — R10 has 1.5 kiloohms
- STM processor may be a forgery — has official STM markings
- USB cable may be power only
— my cable also has data lines
I understand these points to be necessary
What is not working:
- when I press upload, the upload seemingly begins, then fails. The PC13 LED starts to blink quickly and never stops.
AVAILABLE: blackmagic, cmsis-dap, dfu, jlink, serial, stlink
CURRENT: upload_protocol = dfu
Looking for upload port...
Auto-detected: /dev/cu.usbmodem14301
Uploading .pio/build/genericSTM32F103C8/firmware.bin
*** [upload] Error 1
- I even temporarily connected PC14 to GND to enter “perpetual bootloader” mode (source missing). This did not help to upload, though.
- I should say that uploading “sketches” via ST-Link works, but is not practical in the expected use scenario.
- Regarding suuitable [env]s, I am wondering which one is the best one (
bluepill_f103c8, genericSTM32F103C8, bluepill_f103c8_128k). Looked them up via pio boards |grep STM32F103C8T6 .
Question
What can I do? I searched the interwebs for many hours, to no avail. I am happy to hear from you. Thank you so much.
I’m away from my kit etc, but there are lots of Bluepill docs here: Search — PlatformIO latest documentation
Cheers,
Norm.
I think it does a reset here which puts your already in bootloader mode board into “run application” mode. You might want to try and set
board_upload.require_upload_port = no
board_upload.use_1200bps_touch = no
for the very first upload.
Thank you for the quick reply. For now, this did not work.
I was wondering if I should look more in the “do I have the right bootloader” side, or on the USB configuration side
Maybe it fails at something else completely. Execute the project task Advanced → Verbose Upload. What are the logs?
Can I post the logs here? Or is that bad form and I should pastebin or similar?
Well the last few lines where it tries to invoke the uploader command (mape_upload.bat I think in this case) suffice.
NB: I am on a Mac, so no batch files, but that should be OK
I ran verbose upload:
MethodWrapper(["upload"], [".pio/build/genericSTM32F103C8/firmware.bin"])
maple_upload cu.usbmodem14301 2 1EAF:0003 "[snip]/230310-bluepill-general-test/.pio/build/genericSTM32F103C8/firmware.bin"
=== [FAILED] Took 3.11 seconds
Environment Status Duration
bluepill_f103c8 IGNORED
genericSTM32F103C8 FAILED 00:00:03.106
=== 1 failed, 0 succeeded in 00:00:03.106 =====
Okay, getting closer. Can you modify the upload script at
/User/<user>/.platformio/packages/tool-stm32duino/maple_upload
so that the second line is
set -o xtrace
then upload again and post new logs.
Here you go
maple_upload cu.usbmodem14301 2 1EAF:0003 "/Users/<user>/Documents/PlatformIO/Projects/xxx-tests/230310-bluepill-general-test/.pio/build/genericSTM32F103C8/firmware.bin"
+ set -e
+ '[' 4 -lt 4 ']'
+ dummy_port=cu.usbmodem14301
+ altID=2
+ usbID=1EAF:0003
+ binfile=/Users/<user>/Documents/PlatformIO/Projects/xxx-tests/230310-bluepill-general-test/.pio/build/genericSTM32F103C8/firmware.bin
+ dummy_port_fullpath=/dev/cu.usbmodem14301
+++ dirname /Users/<user>/.platformio/packages/tool-stm32duino/maple_upload
++ cd /Users/<user>/.platformio/packages/tool-stm32duino
++ pwd
+ DIR=/Users/<user>/.platformio/packages/tool-stm32duino
+ /Users/<user>/.platformio/packages/tool-stm32duino/upload-reset /dev/cu.usbmodem14301 750
==== [FAILED] Took 13.39 seconds ====
genericSTM32F103C8 FAILED 00:00:13.386
bluepill_f103c8_128k IGNORED
Note: Regarding the [env]s, I am wondering which one is the best one (bluepill_f103c8, genericSTM32F103C8, bluepill_f103c8_128k). Looked them up via pio boards |grep STM32F103C8T6.
This is a native compiled binary. Perhaps it fails on an M1 Mac because Rosetta 2 is not installed. But let me not judge prematurely.
Open a new PlatformIO CLI and execute the same command.
what is the output?
If there is none, execute echo $? after the command.
Linefeed for convenience:
upload-reset /dev/cu.usbmodem14301 750; echo $?
> 1
(LED jumps into quick blink loop)
The src/upload-reset.c code looks weird. The main() function has no declared return value type and on success there is no explicit return 0;.
Let’s do a very simple test and ignore the return value of upload-reset. In maple_upload, find the
${DIR}/upload-reset ${dummy_port_fullpath} 750
line and change it to
${DIR}/upload-reset ${dummy_port_fullpath} 750 || true
What does uploading output now?
This is amazing.
Thank you so much. How do you do it? How is it possible? (I really mean it).
I also would like to add that incidentally, the serial comm via USB now also works.
+ set -e
+ '[' 4 -lt 4 ']'
+ altID=2
+ usbID=1EAF:0003
++ pwd
+ true
+ '[' 4 -eq 5 ']'
+ dfuse_addr=
+ DFU_UTIL=/Users/<user>/.platformio/packages/tool-stm32duino/dfu-util/dfu-util
+ '[' '!' -x /Users/<user>/.platformio/packages/tool-stm32duino/dfu-util/dfu-util ']'
+ /Users/<user>/.platformio/packages/tool-stm32duino/dfu-util/dfu-util -d 1EAF:0003 -a 2 -D /Users/<user>/Documents/PlatformIO/Projects/xxx-tests/230310-bluepill-general-test/.pio/build/genericSTM32F103C8/firmware.bin -R -R
dfu-util 0.8
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2014 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
Opening DFU capable USB device...
ID 1eaf:0003
Run-time device DFU version 0110
Claiming USB DFU Interface...
Setting Alternate Setting #2 ...
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 0110
Device returned transfer size 1024
Copying data from PC to DFU device
[DOWNLOADING]
Download done.
state(8) = dfuMANIFEST-WAIT-RESET, status(0) = No error condition is present
Done!
Resetting USB to switch back to runtime mode
+ echo -n Waiting for /dev/cu.usbmodem14301 serial...
+ COUNTER=0
+ '[' '!' -c /dev/cu.usbmodem14301 ']'
+ echo Done
Waiting for /dev/cu.usbmodem14301 serial...Done
[SUCCESS] Took 6.12 seconds =====
genericSTM32F103C8 SUCCESS 00:00:06.123
Okay so it was just the return value of 1 from upload-reset keeping it from working.
Yeah the error (and I firmly believe not declaring int main and doing return 0; is a bug) was also already visible in Upload-reset: No such file or directory - #5 by pfeerick.
Maybe this only occurs on some systems or maybe it doesn’t even persist accross reboots when the memory layout is different.
Could you do one final test: Backup the original upload-reset binary somewhere.
Download the new source code at upload-reset.c · GitHub and save it somewhere.
Recompile the binary using clang or gcc or whatever native compiler you have on your system
gcc -o /Users/<user>/.platformio/packages/tool-stm32duino/upload-reset -Os <path to new source code>
Then revert the || true quickfix. Does it still work?
I reverted the quickfix and compiled the updated binary you posted (I had to download Command Line Tools for Xcode 14.2 (YMMV) from developer.apple.com (Free account required).
It still works!
