HowTo: Raspberry Pi 3 as remote agent (Oct. 2020)
I finally managed to set up a raspberry pi 3 as a remote agent. Since I had some difficulty on the road, I’ll share my setup script here to help others with this setup.
Comments
  • I’m using a system wide installation of platformio instead of the virtualenv installation, because a) it’s the only way I could get it to work and b) I’m not using the raspi for anything else.
  • Some of the insallation steps can take quite a while on the raspi, be patient!
Prerequisites
  1. Raspberry Pi 3
  2. SD card with at least 4GB space (2GB is not enough)
  3. rpi-imager installed
Steps
  1. Use rpi-imager to prepare the sd card
  • Select “Raspberry Pi OS (32-bit) Lite”
  • This guide was created using Version: August 2020
  1. Mount the sd card and open the boot partition
  2. Setup wifi (if needed)
  • in the boot partition, create ẁpa_supplicant.conf file with the wlan config:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
country=<Insert 2 letter ISO 3166-1 country code here>
network={
 ssid="<Name of your wireless LAN>"
 psk="<Password for your wireless LAN>"
  1. In the boot partition, create an empty file called ssh to enable ssh on boot.
  2. Insert the card into the raspberry pi and connect the power. The raspi will boot up and do the initial setup.
  3. Connect via ssh
ssh pi@raspberrypi
  • the initial password is raspberry
  1. Set a new password
passwd
  1. Install platformio
# update system
sudo apt update
sudo apt upgrade -y
# install required packages
sudo apt install python3-pip libffi-dev libssl-dev
# install platformio
sudo pip3 install platformio
# install required libraries for the remote agent
pio remote agent
  1. Get the platformio auth token (you can do this on any computer)
# login to platformio
pio account login
# get the auth token
pio account token
  • save the token for the next step
  1. Install the remote agent as a service
  • create a file /etc/systemd/system/pio-remote.service:
[Unit]
Description=pio remote agent
Requires=network-online.target
After=network-online.target
[Service]
Type=simple
User=pi
Group=pi
Environment="PLATFORMIO_AUTH_TOKEN=<insert your auth token from last step>"
WorkingDirectory=/home/pi
ExecStart=/usr/local/bin/platformio remote agent start
Restart=always
[Install]
WantedBy=multi-user.target
  1. Start the service
sudo systemctl start pio-remote
  1. Check that the service is running
systemctl status pio-remote
  • In case of errors, check the error log
journalctl -e -t platformio
Done!
The service should be running and you can access the remote agent from any platformio installation by logging in to your account.
Let me know if you have any questions or issues regarding this guide.
Thanks for that tutorial, helped me to install the remote agents without errors.
Great tutorial, just one misspelling here “sudo apt install pyhton3-pip libffi-dev libssl-dev” should be “python3-pip” :frowning:
Rainer
Oh, right, thanks!
I actually have to fix that in my script :sweat_smile:
Fixed in the post.
no Problem, but perhaps can you help me, Starting the service following your tutorial, I get errors. Just did cut an paste from your tutorial and added the key I generated.
error:
● pio-remote.service - pio remote agent
   Loaded: error (Reason: Unit pio-remote.service failed to load properly: Invalid argument.)
   Active: inactive (dead)
Oct 24 16:40:57 CAN-B systemd[1]: /etc/systemd/system/pio-remote.service:9: Invalid environment assignment, ignoring: PLATFORMIO_AUTH_T
Oct 24 16:40:57 CAN-B systemd[1]: /etc/systemd/system/pio-remote.service:15: Missing '='.
Oct 24 16:41:09 CAN-B systemd[1]: /etc/systemd/system/pio-remote.service:9: Invalid environment assignment, ignoring: PLATFORMIO_AUTH_T
Oct 24 16:41:09 CAN-B systemd[1]: /etc/systemd/system/pio-remote.service:15: Missing '='.
Service config
[Unit]
[Service]
Type=simple
User=pi
Group=pi
Environment="PLATFORMIO_AUTH_TOKEN mq2[censored]"
Restart=always
[Install]
Thanks for Help Rainer
Missing ‘=’ perhaps? Try:
Environment="PLATFORMIO_AUTH_TOKEN=mq2UsWq...."
From the above:
Cheers,
Norm.
Yes thanks, but f* there was a second problem, a single double quote in the last line. Removing ist fixed it,
Thanks again Rainer
Solved, there was a douple quote in the last line, I removes it.
Thanks Rainer
How do I adjust my platformio.ini so that the build is automatically happening on my remote Raspberry Pi?
Not sure about the platformio.ini but does this help? Visual Studio Code Remote Development over SSH to a Raspberry Pi is butter - Scott Hanselman's Blog – that’s what process I followed.
Cheers,
Norm.
Mhm, remote development via SSH is not really what I want. I want to work locally and build all platforms, not only the Pi but also other ones. The Pi platform has to be built remote, the other ones can be built locally.
As far as I know there is no platformio.ini configuration for that – you must either pio remote run on the CLI or use the “Remote” tasks in VSCode.
Feature requests can be filed at https://github.com/platformio/platformio-core/issues
Ah, okay. Thank you! I misunderstood the docs first, did setup a PR for clarification: Clarify remote run docs by pfink · Pull Request #168 · platformio/platformio-docs · GitHub
There is a new dependency for getting this install to work:
apt install rustc
It would be really nice if the required dependencies were listed in the official install guide
Thanks, original post has been updated!
What, where does PlatformIO require Rust? That would be big news to me.
We don’t require Rust, Python’s cryptography package now needs Rust to compile itself :frowning:
Please note this issue only happens when pre-built cryptography package does not work
I’ve just locked cryptography to the Rust-less version. No need to install Rust now.
UPDATE:
I’ve updated my remote pi, and in principle it still works. I just made a few adjustments to the install script. I added instructions to update platformio and pip python packages, so the same script can be used to update the installation. pip upgrade is required to make sure requirements can be compiled successfully.
# update system
sudo apt update
sudo apt upgrade -y
sudo pip3 install -U platformio pip
pio remote agent
I’m using a fresh install of raspbian lite on raspberry pi 3 and I installed PlatformIO successfully on the pi, also I installed the pio remote agent succefully, but wheen I try to start the agent I get the following erro, it seems to be something related to openssl/crypto…
is there a workaround or a solution for this issue?
bayrem@raspberrypi:~/workspace/bilal-fw $ pio remote agent start
ImportError: Traceback (most recent call last):
  File "/home/bayrem/.platformio/penv/lib/python3.11/site-packages/platformio/__main__.py", line 103, in main
    cli()  # pylint: disable=no-value-for-parameter
  File "/home/bayrem/.platformio/penv/lib/python3.11/site-packages/click/core.py", line 1157, in __call__
  File "/home/bayrem/.platformio/penv/lib/python3.11/site-packages/click/core.py", line 1078, in main
    rv = self.invoke(ctx)
  File "/home/bayrem/.platformio/penv/lib/python3.11/site-packages/platformio/cli.py", line 85, in invoke
    return super().invoke(ctx)
  File "/home/bayrem/.platformio/penv/lib/python3.11/site-packages/click/core.py", line 1688, in invoke
  File "/home/bayrem/.platformio/penv/lib/python3.11/site-packages/click/core.py", line 1434, in invoke
  File "/home/bayrem/.platformio/penv/lib/python3.11/site-packages/click/core.py", line 783, in invoke
  File "/home/bayrem/.platformio/penv/lib/python3.11/site-packages/platformio/remote/cli.py", line 68, in remote_agent_start
    from platformio.remote.client.agent_service import RemoteAgentService
  File "/home/bayrem/.platformio/penv/lib/python3.11/site-packages/platformio/remote/client/agent_service.py", line 27, in <module>
    from platformio.remote.client.base import RemoteClientBase
  File "/home/bayrem/.platformio/penv/lib/python3.11/site-packages/platformio/remote/client/base.py", line 30, in <module>
    from platformio.remote.factory.ssl import SSLContextFactory
  File "/home/bayrem/.platformio/penv/lib/python3.11/site-packages/platformio/remote/factory/ssl.py", line 16, in <module>
    from OpenSSL import SSL  # pylint: disable=import-error
  File "/home/bayrem/.platformio/packages/contrib-pioremote/OpenSSL/__init__.py", line 8, in <module>
    from OpenSSL import crypto, SSL
  File "/home/bayrem/.platformio/packages/contrib-pioremote/OpenSSL/crypto.py", line 17, in <module>
    from OpenSSL._util import (
  File "/home/bayrem/.platformio/packages/contrib-pioremote/OpenSSL/_util.py", line 6, in <module>
    from cryptography.hazmat.bindings.openssl.binding import Binding
  File "/home/bayrem/.platformio/packages/contrib-pioremote/cryptography/hazmat/bindings/openssl/binding.py", line 14, in <module>
    from cryptography.hazmat.bindings._openssl import ffi, lib
ImportError: /home/bayrem/.platformio/packages/contrib-pioremote/cryptography/hazmat/bindings/_openssl.abi3.so: undefined symbol: FIPS_mode
  `python -m pip install -U platformio` command
