How to debug the basic blink program on a Rapsberry Pi Pico using PlatformIO and Picoprobe?
I have two Rapsberry Pi Pico connected with SWD and one running picoprobe, following the instructions in the official Rapsberry Pi Docs: Getting started with Raspberry Pi Pico, Appendix A: Using Picoprobe
I have found these previous questions on the forum:
But after reading them it is still not clear how to use actual use PlatformIO to debug a program.
Do I need to edit platformio.ini so it knows about the picoprobe?
What values to I use?
How to I tell PlatformIO to debug and upload the firmware using via the picoprobe connection? Is this possible?
What buttons do I need to press in the VSCode UI?
I support this in my platform extension at Arduino-Pico (Earlephilhower) support, PicoProbe Debugging by maxgerhardt · Pull Request #36 · platformio/platform-raspberrypi · GitHub, documentation is available at Using this core with PlatformIO — Arduino-Pico 2.7.1 documentation.
I personally use this to debug my Pico with my second Pico, and it works nicely, can debug both Cortex-M0+ cores even :).
Note If you already have written your program for ArduinoCore-mbed (default for framework = arduino and platform = raspberrypi), then you should not change the core to the Arduino-Pico one (done through board_build.core = earlephilhower), but just use the platformio.ini
[pico]
platform = https://github.com/maxgerhardt/platform-raspberrypi.git
board = pico
upload_protocol = picoprobe
debug_tool = picoprobe
Thanks Max,
Yeah, this does not quite work yet :slight_smile: I just deleted my .platformio directory and re-installed everything, created a fresh project using your platformio.ini above. Build works! But upload failed with the error below.
I can see it download your repo. but ended up failing with a “dyld: Library not loaded:” error. I think this is a maybe a conflict with something in my file system?
Not too sure how to continue.
I would follow any instructions that work! So maybe will try your platform extension if you say it works.
rocessing pico (platform: https://github.com/maxgerhardt/platform-raspberrypi.git; board: pico; framework: arduino)
Tool Manager: Installing earlephilhower/tool-openocd-rp2040-earlephilhower @ ~5.100300.0
Downloading  [####################################]  100%
Unpacking  [####################################]  100%
Tool Manager: tool-openocd-rp2040-earlephilhower@5.100300.220714 has been installed!
Tool Manager: Installing earlephilhower/tool-mklittlefs-rp2040-earlephilhower @ ~5.100300.0
Tool Manager: tool-mklittlefs-rp2040-earlephilhower@5.100300.220714 has been installed!
CONFIGURATION: https://docs.platformio.org/page/boards/raspberrypi/pico.html
PLATFORM: Raspberry Pi RP2040 (1.7.0+sha.5677d9b) > Raspberry Pi Pico
HARDWARE: RP2040 133MHz, 264KB RAM, 2MB Flash
DEBUG: Current (picoprobe) External (cmsis-dap, jlink, picoprobe, raspberrypi-swd)
 - framework-arduino-mbed @ 3.1.1
 - tool-mklittlefs-rp2040-earlephilhower @ 5.100300.220714 (10.3.0)
 - tool-openocd-rp2040-earlephilhower @ 5.100300.220714 (10.3.0)
 - tool-rp2040tools @ 1.0.2
 - toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
Found 37 compatible libraries
Retrieving maximum program size .pio/build/pico/firmware.elf
Flash size: 2.00MB
Sketch size: 2.00MB
Filesystem size: 0.00MB
Maximium Sketch size: 2093056 EEPROM start: 0x101ff000 Filesystem start: 0x101ff000 Filesystem end: 0x101ff000
Checking size .pio/build/pico/firmware.elf
RAM:   [==        ]  15.1% (used 40696 bytes from 270336 bytes)
Flash: [          ]   0.2% (used 4034 bytes from 2093056 bytes)
AVAILABLE: cmsis-dap, jlink, picoprobe, picotool, raspberrypi-swd
CURRENT: upload_protocol = picoprobe
Uploading .pio/build/pico/firmware.elf
dyld: Library not loaded: /usr/local/opt/hidapi/lib/libhidapi.0.dylib
  Referenced from: /Users/daniel/.platformio/packages/tool-openocd-rp2040-earlephilhower/bin/openocd
  Reason: image not found
*** [upload] Error -6
Your Mac M1 is special: There is currently indeed a bug in the packaged OpenOCD version for Mac, which is compiled for Mac x64. So for your ARM M1 1.) you need Rosetta installed 2.) You currently have to manually install the libhid dependency. This is tracked in M1 OpenOCD Upload Issues · Issue #703 · earlephilhower/arduino-pico · GitHub
That’s odd, I have a 10 year old MacBook Pro (Retina, Mid 2012), MacBook Pro 2.6 GHz Quad-Core Intel Core i7 :woozy_face:
Then I’m afraid our OpenOCD Mac packages are in general broken with regards to missing dependencies. The fix should be the same: Manually install libhid (and possibly others as they show up?) dependencies as linked.
Thanks Max,
Do you recommend using brew or build from source?
If building from source, should I do everything with gcc?
Thanks!
Dan
Try the easy way from brew first like suggested by Earle (arch -x86_64 brew install libhidapi), since it’s a dynamic library I hope that works out… If that’s not working, you can still uninstall it and compile GitHub - raspberrypi/openocd from source, especially per openocd/README.macOS at rp2040 · raspberrypi/openocd · GitHub.
Thanks Max!
That worked. It just needed,
arch -x86_64 brew install hidapi
