I am trying to add components from esp-iot-solution to my PlatformIO project (in particular the LCD component) using the espidf framework.
I tried to add the the lcd
component (with the Adafruit-GFX-Library submodule) to the lib folder but #include "iot_lcd.h"
or #include "lcd/iot_lcd.h"
fail.
Apparently, custom components are not supported. Is there a way to repackage it so I can use it?
Outdated information since the ESP-IDF v4 update.
The documentation tells you how to do it.
Hi @maxgerhardt ,
I tried following the documentation, but so far it still can’t find the component header file (Arduino.h).
I tried the ‘components’ optional folder way, and it gives me the missing header file error.
For reference, I am trying to build a simple blink project using framwork=espidf, any help would be appreciated.
This is my components folder:
Thanks!
