How do you set up a new board ESP32-S3 N16R8
Really helpful post Richard, I can upload and debug my S3 dev kit module. Three problems remain: if I add debug_init_break = tbreak setup to the .ini file the debugger fails to start and without this command the debugger starts, but in an arbitrary place in the file C:\Users\Steven.platformio\packages\framework-arduinoespressif32\cores\esp32\main.cpp, which is not my source file, that is located at E:\Users\Steven\Documents\GitHub\PlatformIO\N16R8V\src\main.cpp. I can click continue and execution will stop in my code if I have set a breakpoint. Also the debugger always stops two lines after where the breakpoint is set. Have you managed to overcome any of these issues?
The connector marked USB produces two interfaces, one is a JTAG port the other is a COM port e.g. COM3 on my PC. The other connector marked COM is just the usual USB to serial chip, which again produces a COM port e.g. COM4 on my PC. Unless overridden in the .ini file the PIO upload uses COM3, but you could change it using e.g. upload_port = COM4. I connect both USB-C connectors to my PC and leave it to PIO to do its thing.
Hi, Wanted to say thanks, setting my code to use serial0 enabled my serial coms to function via the CH343p
thank you very much!
Maybe this’ll help other folks like me that aren’t interested in long form answers to simple questions:
Assumes you’ve managed to get esptool to work with your device.
Ask chatgpt to look for boards here: platform-espressif32/boards at develop · platformio/platform-espressif32 · GitHub
that match the data output by esptool. It found a match almost immediately.
Exercise due diligence of course.
Unfortunately chatgpt did not tell you that there is no suitable board manifest for the asked ESP32-S3-N16R8!
Either you use a suitable boards manifest with the right settings like this or you use the default esp32-s3-devkitc-1 and make the necessary settings in platformio.ini:
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
board_build.arduino.memory_type = qio_opi
board_build.flash_mode = qio
board_build.prsam_type = opi
board_upload.flash_size = 16MB
board_upload.maximum_size = 16777216
board_build.extra_flags =
  -DBOARD_HAS_PSRAM
Please do not rely on chatgpt!
Good advice, but they (LLM’s) do quickly help me narrow things down and get me going in the right direction, hence the “Exercise due diligence of course.” in my previous post
Good evening,
did anybody successfully ran this board with the tft_espi library with the GC9A01-display?
many thanks in advance!
Please create a new topic for that, along with your current try.
Thanks to help by sivar2311 the root cause could be identified:
An Arduino version change was the problem.
As sivar2311 pointed me to: Until version 6.6.0 (Arduino 2.0.14) everything seems running well. Of Version 6.7.0 (Arduino 2.0.16) chrashes occurred.
The solution: Additional build flag “USE_HSPI_PORT ” solves the problem.
Many, many thanks to all contributors in this forum!
Hi sivar2311,
I am also playing around with this board and the esp32-s3-devkitc1-n16r8.json works quite good. But as we use an automatic build process on github, I have to use the esp32-s3-devkitc1.sjon defintion and to define the board parameters within the platformIO.ini file.
Also this works, except to use the complete flash. Within my platformIO.ini file I have set board_build.arduino.partitions = default_16MB.csv similiar to the n16r8.json file. But unfortenutely the ESP32-S3 crashes with this, while using the esp32-s3-devkitc1-n16r8.json the complete flash can be used.
For now I do not know the reason, do you (or anybody else) have an idea?
Thanks and regards
Ralf
Hi @elral !
Fortunately, I have collected appropriate settings for almost all ESP32-S3 modules based on the ESP32-S3-DevKitC in a repository: ESP32-S3 PlatformIO Flash and PSRAM configurations
ESP32-S3-WROOM-1 N16R8
ESP32-S3-WROOM-2 N16R8V
I hope this will help you.
Hi @sivar2311 ,
thanks for the great overview!
These are exactly the build parameters I use.
But the ESP32 crashes if board_build.arduino.partitions = default_16MB.csv is set.
Without using it I have Flash: [==========] 99.6% (used 3327833 bytes from 3342336 bytes).
If I use the above mentioned esp32-s3-devkitc1-n16r8.json I get Flash: [===== ] 50.8% (used 3327833 bytes from 6553600 bytes). And as far as I see the only difference is "partitions": "default_16MB.csv" inside the json file which does not work if set in the platformio.ini file…
I had no issues with default_16MB partition layout.
Strange, strange.
Does not work for me…
Hi guys,
even if I am late to the party, I have a smilier issue.
I built a custom board based on the esp32-s3-devkit-c, but with the ESP32-WROOM-1-N16R8.
So I followed the instructions here and added
board_build.psram_type = opi
  -DBOARD_HAS_PSRAM
Thanks to @sivar2311 for this list :slight_smile:
I can build and flash my firmware, but I see this error via UART:
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x8 (TG1WDT_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x40377f5d
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x44c
load:0x403c9700,len:0xbd8
load:0x403cc700,len:0x2a80
entry 0x403c98d0
I started commenting these lines, as it is working with the plain esp32-s3-devkitc-1.
I found out that this line causes the issue
Though I am not aware of what this exactly does.
Can I just remove this line? Can you explain me the problem, as I do not understand what exactly the problem is.
Is there a better fix?
This line
This line declares the connection type for the Flash-Chip and PSRAM-Chip (dual, quad, octal).
The ESP32-S3 WROOM 1 is using quad mode for the Flash chip and octal mode for the PSRAM - See WROOM 1 Configurations
Maybe your board has an ESP32-S3 WROOM 2 Module which is using octal connections to both chips - See WROOM 2 Configurations?
thanks for your quick reply :slight_smile:
Is it a problem, when I remove this line? Can I access the 16MB flash anyways?
Hmm, I would I know if it’s WROOM 2 Module?
This is the manufacturer parts, I am using: ESP32-S3-WROOM-1-N16R8
I was thinking the WROOM-1 part is clarifying this, isn’t it?
It’s only connected via UART and not with native USB.
Could this be a problem?
I don’t know your sketch.
What platform version do you use and have you tested different versions?
I don’t think so as you’re getting a Watchdog reset (TG1WDT_SYS_RST).
The very same sketch is working when using esp32-devkit-c-1
This is my configuration
board = my_custom_board
I moved the configuration of the board to the boards/my_custom_board.json
  "build": {
    "arduino":{
      "ldscript": "esp32s3_out.ld",
    "core": "esp32",
    "extra_flags": [
      "-DARDUINO_ESP32S3_DEV",
      "-DBOARD_HAS_PSRAM",
      "-DARDUINO_USB_MODE=1",
      "-DARDUINO_USB_CDC_ON_BOOT=1"
    "f_cpu": "240000000L",
    "f_flash": "80000000L",
    "flash_mode": "qio",
    "psram_type": "opi",
    "hwids": [
        "0x303A",
        "0x1001"
    "mcu": "esp32s3",
    "variant": "esp32s3"
  "connectivity": [
    "wifi",
    "bluetooth"
  "debug": {
    "default_tool": "esp-builtin",
    "onboard_tools": [
      "esp-builtin"
    "openocd_target": "esp32s3.cfg"
  "frameworks": [
    "arduino",
    "espidf"
  "name": "Espressif ESP32-S3-DevKitC-1-N16R8V (16 MB QD, 8MB PSRAM)",
  "upload": {
    "flash_size": "16MB",
    "maximum_ram_size": 327680,
    "maximum_size": 16777216,
    "require_upload_port": true,
    "speed": 921600
  "url": "https://docs.espressif.com/projects/esp-idf/en/latest/esp32s3/hw-reference/esp32s3/user-guide-devkitc-1.html",
  "vendor": "Espressif"
I also removed the memory_type here.
It is working like this, but I was wondering if it’s a good idea to remove that line.
