Hello my name is Scott I am new to the community. I am trying to compile Marlin on VSCode for my Ender 3 with a BLTouch. I think I have all the proper extensions installed. When I compile it gets to the end then throws the following errors. Google has not been helpful the past couple of hours I am hoping I may find an answer here. Let me know what information you need from me. Thank you.
There is an inc folder at BIGTREETECH-SKR-mini-E3-master\firmware\V1.2\Marlin-2.0.7.2-SKR-mini-E3-V1.2\Marlin\src\inc
BIGTREETECH-SKR-mini-E3-master is the project workspace folder that was imported
In file included from Marlin\src\gcode\bedlevel\abl\../../../module/stepper/../../feature/../lcd/ultralcd.h:61:0,
from Marlin\src\gcode\bedlevel\abl\../../../module/stepper/../../feature/tmc_util.h:25,
from Marlin\src\gcode\bedlevel\abl\../../../module/stepper/trinamic.h:35,
from Marlin\src\gcode\bedlevel\abl\../../../module/stepper/indirection.h:44,
from Marlin\src\gcode\bedlevel\abl\../../../module/stepper.h:47,
from Marlin\src\gcode\bedlevel\abl\G29.cpp:35:
Marlin\src\gcode\bedlevel\abl\../../../module/stepper/../../feature/../lcd/../feature/pause.h:33:10: fatal error: ../inc/MarlinConfigPre.h: No such file or directory
#include "../inc/MarlinConfigPre.h"
compilation terminated.
In file included from Marlin\src\gcode\calibrate\../../module/stepper/../../feature/../lcd/../feature/pause.h:37:0,
from Marlin\src\gcode\calibrate\../../module/stepper/../../feature/../lcd/ultralcd.h:61,
from Marlin\src\gcode\calibrate\../../module/stepper/../../feature/tmc_util.h:25,
from Marlin\src\gcode\calibrate\../../module/stepper/trinamic.h:35,
from Marlin\src\gcode\calibrate\../../module/stepper/indirection.h:44,
from Marlin\src\gcode\calibrate\../../module/stepper.h:47,
from Marlin\src\gcode\calibrate\G28.cpp:27:
Marlin\src\gcode\calibrate\../../module/stepper/../../feature/../lcd/../feature/../libs/nozzle.h:24:10: fatal error: ../inc/MarlinConfig.h: No such file or directory
#include "../inc/MarlinConfig.h"
*** [.pio\build\STM32F103RC_btt_512K\src\src\gcode\bedlevel\abl\G29.cpp.o] Error 1
*** [.pio\build\STM32F103RC_btt_512K\src\src\gcode\calibrate\G28.cpp.o] Error 1
=========================================================================== [FAILED] Took 24.09 seconds ===========================================================================
Environment Status Duration
STM32F103RC_btt_512K FAILED 00:00:24.085
====================================================================== 1 failed, 0 succeeded in 00:00:24.085 ======================================================================The terminal process "C:\Users\scott\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
