i was using esp32 board and wanted to print stuff out and i am getting null as output when there’s a message from esp32
i don’t know what to do
this is my program
#define DELAY 1000
#define LED_BUILTIN 1
Serial.println("inited from setup");
pinMode(LED_BUILTIN, OUTPUT);
Serial.begin(921600);
Serial.println("Hello from the setup");
delay(DELAY);
Serial.println("Hello from the loop");
delay(DELAY);
below is my platform.ini file
[env:denky32]
board = denky32
monitor_rts = 0
monitor_dtr = 0
You are trying to initialize Serial twice!
Remove these lines:
Make sure your platformio.ini has
If you still have issues, please also show the content of your platformio.ini
oh hey there thanks for the reply forgot to add the platform.ini
here it is
[env:denky32]
board = denky32
monitor_rts = 0
monitor_dtr = 0
btw i saw a previous thread (Noob stuck on ESP32-CAM+MB with PIO/vscode )
so therefore added the two lines below but no luck ( still having same issues)
Did you remove the 2nd initialization?
rustedusted:
yes i did remove that
this is the new setup function
oh hey btw i just noticed one more thing
i’m getting an error while doing pio device monitor
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:1184
load:0x40078000,len:13260
load:0x40080400,len:3028
entry 0x400805e4
E (94) psram: PSRAM ID read error: 0xffffffff
in␀␀␀␀␀␀␀␀␀␀␀␀␀␀␀
this is the entire output the null you see at the end is the exact output i’m getting
and above that i’m also getting a read error 0xffff…
rustedusted:
board = denky32
The denky32 board should have psram. Looks like your board don’t. Do you really have a denky32?
Otherwise please use the default:
i have esp32-wroom-32 written on the board i tried the option esp32dev as well
but got it finally working i searched on internet
and found out that the pin 1 is used for serial communication so it was causing issues
i changed the pin to 2 and i’m getting no errors with serial output as of now however i’m not sure which board i’m using
also i’m not sure what do i put in the pio project init --board
i want to get to a point where i can read a datasheet to understand things and test programs out
thanks a lot for helping me throughout the day thanks to you i got the serial communication working
Post a picture or a link to your board
ESP32 Development board is based on the ESP WROOM32 WIFI + BLE Module.It's a low-footprint, minimal system development board powered by the latest ESP-WROOM-32 module and can be easily inserted into a solderless breadboard. It contains the entire...
Est. reading time: 1 minute
this is i believe the exact board that i have
below is an image as well
i took the below image at my house btw
That’s an ESP32-DevKitC-1.
Use board = esp32dev
A good reference for the PIN’s you can use is located here:
Hey thanks a lot for this
platform io does provide using esp-idf
would you say that would be a better option ??
i’m very very new to embedded programming but i saw things like esp_schedule and handle_event these things seem very powerful compared to normal execution of arduino framework programs
do you have any good project idea for esp32
The more professional way is esp-idf because you have more control.
Arduino has some fixed settings and library that cannot be changed easily.
For a better learning, since you said you are new to this, would be Arduino. A lot of libraries are available. There is a great Arduino community out there.
The good thing is, you can use (mostly) all underlying ESP-IDF and FreeRTOS things in an Arduino sketch. There is nothing prevent you to start a new FreeRTOS task in Arduino (xTaskCreate(...)) for example.
There is also a way of mixing ESP-IDF and Arduino: Arduino as ESP-IDF Component (framework = espidf, arduino)
My opinion: If you project is for hobby: use Arduino / if it is for business, use ESP-IDF.
oh i see mostly my projects are hobby based but my programs are quite demanding i mean i’m trying to run an ssh server on esp32
so people told me using esp-idf is the only option will try and test things
i want to create something like ssh terminal.shop interface for my esp32
they’ve used go but i’ll have to use C or C++
so it’ll be pretty fun to make ig idk
i’ve got basic stuff done
do you think i can create this with arduino framework?
There is an ESP32 Arduino ssh server library available:
Libssh SSH client & server port to ESP32 Arduino library
Arduino is C++, ESP-IDF is C / C++
Yes - See the library above.
The discussion has gone off-topic and should be continued elsewhere.
