HI, so moving on from my attempts with the slow FT232R, I have taken delivery of an FT2232H Mini Module and gone through setting it up, tiny problem though and i hope the attached image explains it, essentially the FTDI Mini Module has a USB ID of 0x403 0x6011 rather than the 0x403 0x6010 that the debugger is expecting, I’m pretty sure this should be fixable by changing 0x6010 to 0x6011 in an CFG file somewhere, just not sure where that file is.
C:\Users\[user]\.platformio\packages\tool-openocd-esp32\share\openocd\scripts\interface\ftdi\minimodule.cfg
Cheers all , found it!
Fair bit of electrical configuration required for this particular PCB design namely the FT2232H Mini Module Rev 1.1 (c) 2010 FTDI Ltd.
[Update]
I can confirm this setup is able to debug the ESP32 perfectly at 20Mhz!
NOTE: When correctly wired as below and the WinUSB drivers installed with Zadig onto FT2232H MiniModule (Interface 0 and 1) the device will be detected correctly for the defualt settings in minimodule.cfg
Crib Sheet
Foxa ESP32 MiniModule Debugger Cheat Sheet
FT2232H PIN JTAG ESP32 COLOUR(suggested)
______________________________________
AD1 (10) TDI 12 brown
AD0 (07) TCK 13 orange
AD2 (09) TDO 15 white
AD3 (12) TMS 14 gray
CN3
| 02 04 06 08 10 12 14 16 18 20 22 24 26 |
| 01--03 05 07 09 11 13 15 17 19 21 23 25 |
| CN1 | USB |
CN2 * JTAG Pins |
| 02 04 06 08* 10* 12* 14 16 18 20 22 24 26 | |
| 01--03--05 07* 09* 11 13 15 17 19 21 23 25 | |
Pin Name Description
CN2-01 V3V3 3.3VDC generated from VCC (output)
CN2-02 GND 0V Power pin
CN2-03 V3V3 3.3VDC generated from VCC (output)
CN2-04 GND 0V Power pin
CN2-05 V3V3 3.3VDC generated from VCC (output)
CN2-06 GND 0V Power pin
CN2-07 AD0 FT2232H AD0 pin
CN2-08 RESET# FT2232H RESET# pin
CN2-09 AD2 FT2232H AD2 pin
CN2-10 AD1 FT2232H AD1 pin
CN2-11 VIO Connected to all FT2232H VCCIO pins (input)
CN2-12 AD3 FT2232H AD3 pin
CN2-13 AD5 FT2232H AD5 pin
CN2-14 AD4 FT2232H AD4 pin
CN2-15 AD7 FT2232H AD7 pin
CN2-16 AD6 FT2232H AD6 pin
CN2-17 AC1 FT2232H AC1 pin
CN2-18 AC0 FT2232H AC0 pin
CN2-19 AC3 FT2232H AC3pin
CN2-20 AC2 FT2232H AC2 pin
CN2-21 VIO Connected to all FT2232H VCCIO pins (input)
CN2-22 AC4 FT2232H AC4 pin
CN2-23 AC6 FT2232H AC6 pin
CN2-24 AC5 FT2232H AC5 pin
CN2-25 SUSPEND# FT2232H SUSPEND# pin
CN2-26 AC7 FT2232H AC7 pin
CN3-01 VBUS USB VBUS power pin (output)
CN3-02 GND 0V Power pin
CN3-03 VCC +5V Power pin (input) used to generate V3V3, VPLL and VUSB
CN3-04 GND 0V Power pin
CN3-05 CS FT2232H EECS pin
CN3-06 CLK FT2232H EECLK pin
CN3-07 DATA FT2232H EEDATA pin
CN3-08 PWREN# FT2232H PWREN#
CN3-09 BC7 FT2232H BC7 pin
CN3-10 BC6 FT2232H BC6 pin
CN3-11 BC5 FT2232H BC5 pin
CN3-12 VIO Connected to all FT2232H VCCIO pins (input)
CN3-13 BC4 FT2232H BC4 pin
CN3-14 BC3 FT2232H BC3 pin
CN3-15 BC2 FT2232H BC2 pin
CN3-16 BC1 FT2232H BC1 pin
CN3-17 BC0 FT2232H BC0 pin
CN3-18 BD7 FT2232H BD7 pin
CN3-19 BD6 FT2232H BD6 pin
CN3-20 BD5 FT2232H BD5 pin
CN3-21 BD4 FT2232H BD4 pin
CN3-22 VIO Connected to all FT2232H VCCIO pins (input)
CN3-23 BD3 FT2232H BD3 pin
CN3-24 BD2 FT2232H BD2 pin
CN3-25 BD1 FT2232H BD1 pin
CN3-26 BD0 FT2232H BD0 pin
platformio.ini used
monitor_speed= 115200
debug_tool = minimodule
upload_protocol = minimodule
The CJMCU-2232 board works as a drop-in replacement for the ESP-Prog. All you need to do is add a line to platform.ini:
You can also go with an even cheaper FT232H based board (single channel version of FT2232H). Details can be found in Low-cost ESP32 In-circuit Debugging | by Manuel Bl. | Medium. It’s basically the same problem with the USB product ID (0x6014 instead of 0x6010).
And if you add:
upload_protocol = esp-prog
to platform.ini, you can even upload your program via the JTAG adapter, at 20 Mbit/s…
