Failing to use 'Arduino as ISP' to program breadboard ATmega328P
Hello!
I’ve been using PlatformIO for half a year now, and in my last project I wanted to go a little bit further and to not need a bootloader. So I want to program an ATmega328P on a breadboard with a simple blink sketch, but I’m failing to do so. This is my setup:
1.-Arduino Mega 2560 has been programmed as “Arduino as ISP” using ArduinoIDE
2.- Wired this:
Arduino Mega // ATmega328P
Digital pin 51 (MOSI) // pin 17 (MOSI. Equivalent to Arduino UNO Digital pin 11)
Digital pin 50 (MISO) // pin 18 (MISO. Equivalent to Arduino UNO Digital pin 12)
Digital pin 52 (SCK) // pin 19 (SCK Equivalent to Arduino UNO Digital pin 13)
Of course I’ve fed the arduino Mega 2560 5V and ground to the breadboard
2.- I checked that it worked by programming the Blink example skectch using Arduino UNO with this setup (idk if it’s important but you can notice that I selected “Arduino UNO” as the board because Atmega328p is the microcontroller that UNO uses):
It successfully worked, so ‘Arduino as ISP’ is working properly
3.- Tried to do the same in PlatformIO, I read the documentation on ‘Upload using programmer’ (sorry, I can’t put more than 2 links bc I’m a new user), tried, failed, googled, searched in this forums, found a few topics talking about this:
Topic 1
Topic 2
I’ve tried all sorts of combinations of my platform.ini file, but it never works. This is part of the message I get when I click on the “upload” icon, Ithink it’s programming the Arduino Mega itself (every try I make I reprogram it as “arduino as ISP” using the Arduino IDE just in case):
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: reading input file ".pio\build\megaatmega2560\firmware.hex"
avrdude: writing flash (4592 bytes):
Writing | ################################################## | 100% 0.74s
avrdude: 4592 bytes of flash written
avrdude: verifying flash memory against .pio\build\megaatmega2560\firmware.hex:
avrdude: load data flash data from input file .pio\build\megaatmega2560\firmware.hex:
avrdude: input file .pio\build\megaatmega2560\firmware.hex contains 4592 bytes
Currently my “platformio.ini” file looks like this:
[env:ATmega328P]
board = ATmega328P
upload_protocol = custom
upload_port = COM3
upload_speed = 19200
upload_flags =
    -C
    ; use "tool-avrdude-megaavr" for the atmelmegaavr platform
    -p
    $BOARD_MCU
    -P
    $UPLOAD_PORT
    -b
    $UPLOAD_SPEED
    -c
    stk500v1
What am I doing wrong?
You’re still uploading your old project for the Mega, not the project for your ATmega328P. Select the active project correctly, per documentation and this.
Damn you’re right, I’ve had this happen before, I sometimes forget that it doesn’t auto-detect the project by the file opened and in focus! Thank you!
