Here are the errors
> Executing task: C:\Users\sthga\.platformio\penv\Scripts\platformio.exe run <
Processing LPC1768 (platform: ://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/0.1.2.zip; framework: arduino; board: nxp_lpc1768)
CONFIGURATION: ://docs.platformio.org/page/boards/nxplpc-arduino-lpc176x/nxp_lpc1768.html
PLATFORM: NXP Arduino LPC176x 0.1.1 > NXP LPC1768
HARDWARE: LPC1768 100MHz, 31.97KB RAM, 464KB Flash
DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink)
PACKAGES: toolchain-gccarmnoneeabi 1.80201.190214 (8.2.1), framework-arduino-lpc176x 0.2.2
Converting Marlin.ino
LDF Modes: Finder ~ off, Compatibility ~ strict
Found 6 compatible libraries
|-- <Servo> 1.0.0
|-- <LiquidCrystal> 1.0.0
|-- <U8glib-HAL> 0.4.1
|-- <TMCStepper> 0.6.1
|-- <Adafruit NeoPixel> 1.3.0
|-- <SailfishLCD>
Unable to find destination disk (Autodetect Error)
Please select it in platformio.ini using the upload_port keyword (://docs.platformio.org/en/latest/projectconf/section_env_upload.html) or copy the firmware (.pio/build/LPC1768/firmware.bin) manually to the appropriate disk
Compiling .pio\build\LPC1768\src\src\HAL\HAL_LPC1768\DebugMonitor.cpp.o
cc1plus.exe: fatal error: Marlin\src\HAL\HAL_LPC1768\DebugMonitor.cpp: Permission denied
compilation terminated.
Compiling .pio\build\LPC1768\src\src\HAL\HAL_LPC1768\HAL.cpp.o
cc1plus.exe: fatal error: Marlin\src\HAL\HAL_LPC1768\HAL.cpp: Permission denied
Compiling .pio\build\LPC1768\src\src\HAL\HAL_LPC1768\HAL_SPI.cpp.o
cc1plus.exe: fatal error: Marlin\src\HAL\HAL_LPC1768\HAL_SPI.cpp: Permission denied
Compiling .pio\build\LPC1768\src\src\HAL\HAL_LPC1768\MarlinSerial.cpp.o
Compiling .pio\build\LPC1768\src\src\HAL\HAL_LPC1768\fast_pwm.cpp.o
cc1plus.exe: fatal error: Marlin\src\HAL\HAL_LPC1768\MarlinSerial.cpp: Permission denied
Compiling .pio\build\LPC1768\src\src\HAL\HAL_LPC1768\include\digipot_mcp4451_I2C_routines.c.o
cc1plus.exe: fatal error: Marlin\src\HAL\HAL_LPC1768\fast_pwm.cpp: Permission denied
cc1.exe: fatal error: Marlin\src\HAL\HAL_LPC1768\include\digipot_mcp4451_I2C_routines.c: Permission denied
Compiling .pio\build\LPC1768\src\src\HAL\HAL_LPC1768\main.cpp.o
cc1plus.exe: fatal error: Marlin\src\HAL\HAL_LPC1768\main.cpp: Permission denied
Compiling .pio\build\LPC1768\src\src\HAL\HAL_LPC1768\persistent_store_flash.cpp.o
*** [.pio\build\LPC1768\src\src\HAL\HAL_LPC1768\DebugMonitor.cpp.o] Error 1
*** [.pio\build\LPC1768\src\src\HAL\HAL_LPC1768\HAL.cpp.o] Error 1
*** [.pio\build\LPC1768\src\src\HAL\HAL_LPC1768\HAL_SPI.cpp.o] Error 1
*** [.pio\build\LPC1768\src\src\HAL\HAL_LPC1768\MarlinSerial.cpp.o] Error 1
*** [.pio\build\LPC1768\src\src\HAL\HAL_LPC1768\fast_pwm.cpp.o] Error 1
*** [.pio\build\LPC1768\src\src\HAL\HAL_LPC1768\include\digipot_mcp4451_I2C_routines.c.o] Error 1
*** [.pio\build\LPC1768\src\src\HAL\HAL_LPC1768\main.cpp.o] Error 1
cc1plus.exe: fatal error: Marlin\src\HAL\HAL_LPC1768\persistent_store_flash.cpp: Permission denied
*** [.pio\build\LPC1768\src\src\HAL\HAL_LPC1768\persistent_store_flash.cpp.o] Error 1
========================================================================================= [FAILED] Took 10.53 seconds =========================================================================================
Environment Status Duration
megaatmega2560 IGNORED
megaatmega1280 IGNORED
at90usb1286_cdc IGNORED
at90usb1286_dfu IGNORED
DUE IGNORED
DUE_USB IGNORED
DUE_debug IGNORED
LPC1768 FAILED 00:00:10.528
LPC1769 IGNORED
sanguino_atmega644p IGNORED
sanguino_atmega1284p IGNORED
melzi IGNORED
melzi_optiboot IGNORED
rambo IGNORED
STM32F103RE IGNORED
STM32F103RC_fysetc IGNORED
STM32F103RC_bigtree IGNORED
STM32F103RC_bigtree_USB IGNORED
STM32F103RC_bigtree_512K IGNORED
STM32F103RC_bigtree_512K_USB IGNORED
STM32F103RE_bigtree IGNORED
STM32F103RE_bigtree_USB IGNORED
STM32F4 IGNORED
FYSETC_S6 IGNORED
STM32F7 IGNORED
ARMED IGNORED
STM32F103VE_longer IGNORED
mks_robin IGNORED
mks_robin_lite IGNORED
mks_robin_mini IGNORED
mks_robin_nano IGNORED
jgaurora_a5s_a1 IGNORED
STM32F407VE_black IGNORED
BIGTREE_SKR_PRO IGNORED
BIGTREE_BTT002 IGNORED
teensy31 IGNORED
STM32F103CB_malyan IGNORED
chitu_f103 IGNORED
teensy35 IGNORED
esp32 IGNORED
fysetc_f6_13 IGNORED
linux_native IGNORED
SAMD51_grandcentral_m4 IGNORED
include_tree IGNORED
==================================================================================== 1 failed, 0 succeeded in 00:00:10.528 ====================================================================================
Here it is after clean:
> Executing task: C:\Users\sthga\.platformio\penv\Scripts\platformio.exe run --target clean <
Build environment is clean
========================================================================================= [SUCCESS] Took 2.60 seconds =========================================================================================
DUE IGNORED
DUE_USB IGNORED
DUE_debug IGNORED
LPC1768 SUCCESS 00:00:02.599
LPC1769 IGNORED
melzi IGNORED
rambo IGNORED
STM32F103RE IGNORED
STM32F4 IGNORED
FYSETC_S6 IGNORED
STM32F7 IGNORED
ARMED IGNORED
mks_robin IGNORED
teensy31 IGNORED
chitu_f103 IGNORED
teensy35 IGNORED
esp32 IGNORED
I had to delete the http from lines to post (new user)
Windows 10, deleted and dowloaded latest Marlin 2.x , all libraries up to date,
driving me crazy. Same errors on my other laptop.
If I run
