i am new to platformio, due i want to compile Marlin FW I installed PlatformIO in Atom and VistualStudio (tested both) on my Mac (MacOS Mojave)
Everyting worked fine but until i want to compile:
Processing LPC1768 (platform: https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/master.zip; framework:
arduino; board: nxp_lpc1768)
PackageManager: Installing toolchain-gccarmnoneeabi @ >=1.80201.181221
Downloading...
Unpacking...
toolchain-gccarmnoneeabi @ 1.80201.181221 has been successfully installed!
CONFIGURATION: https://docs.platformio.org/page/boards/nxplpc-arduino-lpc176x/nxp_lpc1768.html
PLATFORM: NXP Arduino LPC176x 0.0.2 > NXP LPC1768
HARDWARE: LPC1768 100MHz, 31.80KB RAM, 464KB Flash
DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink)
PACKAGES: framework-arduino-lpc176x 0.1.3
Converting Marlin.ino
sh: arm-none-eabi-g++: command not found
*** Error 127
AssertionError: :
File "/Users/frank/.platformio/penv/lib/python2.7/site-packages/platformio/builder/main.py", line 126:
I think the issue is that āarm-none-eabi-g++ā can not be found, but this is a part of toolchain-gccarmnoneeabi⦠the installation suceeded and i can see that package in the folter ./platformio/packages/toolchain-gccarmnoneeabi
I already added that path to my system Path environment, without sucess.
Nay hints to make this working? Please not that i am new to platformio
Thank you in advanced
I remember this being a problem for other Arduino stuff in the past. Its working now though. Thanks
