Hi
A couple of us using UM_ProS3 boards are trying to get into ESP-IDF on PIO.
We are able to build the example ‘espidf-aws-iot’ ok with the esp32dev, but when adding an environment for any ESP32-S3 we get the same error message:
C:/Users/mick/.platformio/packages/toolchain-xtensa-esp32s3/bin/xtensa-esp32s3-elf-gcc.exe
version 12.2.0 is not the supported version 8.4.0. Check Getting Started
documentation or proceed at own risk.
yet in plaformio.ini we have:
framework = espidf
monitor_filters = colorize
board_build.embed_txtfiles =
src/certs/private.pem.key
src/certs/certificate.pem.crt
src/certs/aws-root-ca.pem
platform_packages =
framework-espidf @ ~3.40403.0
toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
[env:um_pros3]
board = um_pros3
framework = espidf
platform_packages =
Both specifically require
Yet we get the following pass and fail messages:
Building .pio\build\esp32dev\bootloader.bin
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Linking .pio\build\esp32dev\firmware.elf
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [= ] 9.3% (used 30488 bytes from 327680 bytes)
Flash: [======= ] 70.5% (used 738977 bytes from 1048576 bytes)
Building .pio\build\esp32dev\firmware.bin
esptool.py v4.5.1
Merged 25 ELF sections
============================================================================================================================================================================= [SUCCESS] Took 608.58 seconds =============================================================================================================================================================================
Processing um_pros3 (platform: espressif32; board: um_pros3; framework: espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/um_pros3.html
PLATFORM: Espressif 32 (6.5.0) > Unexpected Maker PROS3
HARDWARE: ESP32S3 240MHz, 320KB RAM, 16MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-espidf @ 3.40403.0 (4.4.3)
- tool-cmake @ 3.16.4
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-ninja @ 1.9.0
- tool-riscv32-esp-elf-gdb @ 11.2.0+20220823
- tool-xtensa-esp-elf-gdb @ 11.2.0+20230208
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
- toolchain-riscv32-esp @ 12.2.0+20230208
- toolchain-xtensa-esp32s3 @ 12.2.0+20230208
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32s3
-- Project sdkconfig file C:/Users/mick/Documents/PlatformIO/Projects/240317-153505-espidf-aws-iot/sdkconfig.um_pros3
Loading defaults file C:/Users/mick/Documents/PlatformIO/Projects/240317-153505-espidf-aws-iot/sdkconfig.defaults...
-- Configuring incomplete, errors occurred!
See also "C:/Users/mick/Documents/PlatformIO/Projects/240317-153505-espidf-aws-iot/.pio/build/um_pros3/CMakeFiles/CMakeOutput.log".
fatal: not a git repository (or any of the parent directories): .git
CMake Warning at C:/Users/mick/.platformio/packages/framework-espidf@3.40403.0/tools/cmake/crosstool_version_check.cmake:8 (message):
Toolchain
C:/Users/mick/.platformio/packages/framework-espidf@3.40403.0/components/esp_common/project_include.cmake:6 (gcc_version_check)
C:/Users/mick/.platformio/packages/framework-espidf@3.40403.0/tools/cmake/build.cmake:325 (include)
C:/Users/mick/.platformio/packages/framework-espidf@3.40403.0/tools/cmake/build.cmake:532 (__build_process_project_includes)
C:/Users/mick/.platformio/packages/framework-espidf@3.40403.0/tools/cmake/project.cmake:384 (idf_build_process)
CMakeLists.txt:6 (project)
CMake Error at C:/Users/mick/.platformio/packages/framework-espidf@3.40403.0/tools/cmake/crosstool_version_check.cmake:37 (message):
Toolchain:
C:/Users/mick/.platformio/packages/toolchain-xtensa-esp32s3/bin/xtensa-esp32s3-elf-gcc.exe,
crosstool-ng version esp-12.2.0_20230208 doesn't match supported version
esp-2021r2-patch5
Please try to run 'idf.py fullclean' to solve it quickly.
Check Getting Started documentation if the error continues.
You can override this error and proceed with build by defining the
IDF_MAINTAINER environment variable.
C:/Users/mick/.platformio/packages/framework-espidf@3.40403.0/components/esp_common/project_include.cmake:7 (crosstool_version_check)
============================================================================================================================================================================== [FAILED] Took 27.98 seconds ==============================================================================================================================================================================
Environment Status Duration
esp32dev SUCCESS 00:10:08.585
um_pros3 FAILED 00:00:27.983
I have deleted and reloaded ESP32 packages and done clean builds with no improvement
