But CH0 can upload via JTAG - I just got that working now.
I can clearly spot the JTAG commands here.
But starting debugging still does not work. Although now it just tries for 10 seconds, then stops. Before it kept trying.
Executing task: platformio run --target upload <
Processing mhetesp32minikit (framework: arduino; platform: espressif32; board: mhetesp32minikit)
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 > MH ET LIVE ESP32MiniKit
HARDWARE: ESP32 240MHz 320KB RAM (4MB Flash)
DEBUG: CURRENT(minimodule) EXTERNAL(esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
Collected 32 compatible libraries
Scanning dependencies…
Retrieving maximum program size .pioenvs/mhetesp32minikit/firmware.elf
Checking size .pioenvs/mhetesp32minikit/firmware.elf
Memory Usage → Redirecting...
DATA: [ ] 4.3% (used 14052 bytes from 327680 bytes)
PROGRAM: [== ] 15.6% (used 204843 bytes from 1310720 bytes)
Configuring upload protocol…
AVAILABLE: esp-prog, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = minimodule
Uploading .pioenvs/mhetesp32minikit/firmware.bin
Open On-Chip Debugger 0.10.0-dev (2018-11-05-04:08)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
WARNING!
This file was not tested with real interface, it is based on code in ft2232.c.
Please report your experience with this file to openocd-devel mailing list,
so it could be marked as working or fixed.
adapter speed: 20000 kHz
esp32 interrupt mask on
Info : ftdi: if you experience problems at higher adapter clocks, try the command “ftdi_tdo_sample_edge falling”
Info : clock speed 20000 kHz
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : Detected debug stubs @ 3ffc32bc on core0 of target ‘esp32’
Info : Target halted. PRO_CPU: PC=0x400E9ED6 (active) APP_CPU: PC=0x400E9ED6
Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
Info : esp32: Core 0 was reset (pwrstat=0x1F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
** Programming Started **
auto erase enabled
Info : Target halted. PRO_CPU: PC=0x4009171A (active) APP_CPU: PC=0x40000400
Info : Flash mapping 0: 0x10020 → 0x3f400020, 43 KB
Info : Flash mapping 1: 0x20018 → 0x400d0018, 105 KB
Info : Auto-detected flash size 4096 KB
Info : Using flash size 4096 KB
wrote 208896 bytes from file .pioenvs/mhetesp32minikit/firmware.bin in 2.936409s (69.473 KiB/s)
** Programming Finished **
** Verify Started **
read 204976 bytes from file .pioenvs/mhetesp32minikit/firmware.bin and flash bank 0 at offset 0x00010000 in 0.884574s (226.292 KiB/s)
contents match
** Verified OK **
auto erase enabled
wrote 16384 bytes from file /Users/macmaster2/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin in 0.756462s (21.151 KiB/s)
read 15088 bytes from file /Users/macmaster2/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin and flash bank 0 at offset 0x00001000 in 0.276250s (53.337 KiB/s)
contents match
** Verified OK **
auto erase enabled
wrote 4096 bytes from file /Users/macmaster2/Documents/PlatformIO/Projects/debugger_3/.pioenvs/mhetesp32minikit/partitions.bin in 0.545739s (7.330 KiB/s)
read 3072 bytes from file /Users/macmaster2/Documents/PlatformIO/Projects/debugger_3/.pioenvs/mhetesp32minikit/partitions.bin and flash bank 0 at offset 0x00008000 in 0.244253s (12.282 KiB/s)
contents match
** Verified OK **
auto erase enabled
wrote 8192 bytes from file /Users/macmaster2/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin in 0.599838s (13.337 KiB/s)
read 8192 bytes from file /Users/macmaster2/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin and flash bank 0 at offset 0x0000e000 in 0.256499s (31.189 KiB/s)
contents match
** Verified OK **
shutdown command invoked
