Hey. I am new to VSC and PIO, but getting used to them quickly and loving it.
PIO has worked fine for me so far, now I got a FT2232H board to start hardware debugging.
This is the board: GitHub - arm8686/FT2232HL-Board: USB to dual UART / SPI / I2C / JTAG / FIFO / Bit-Bang... - well built, has a case and all pins are broken out.
It was possible to upload a compile after some trial + error (turns out that only worked when I power-cycled the ESP32 and not just put it in BOOT mode via RST → GPIO01).
Trying to debug yields an Error how the board named “minimodule” is not found.
Turns out my FT2232H has a different name, so I changed that via FPROG.exe and also tried to get as close as possible to FTDI’s config of the minimodule as possible (most stuff is in the datasheet).
But still the real debugging-phase never starts…
I get the “progress-beam/line” in the debugging tab, I get the little hovering debugger palette (only active button is STOP tho), the debugging tab is empty, that’s it.
No timeout seems to happen, OSX Console only spits out this about 6 to 9 times, but it does that also when I open up any file, so I guess it is unrelated:
08.12.18 13:03:13,000 kernel[0]: CODE SIGNING: cs_invalid_page(0x108a82000): p=4206[python] final status 0x0, allowing (remove VALID) page
I did deinstall OSX’s stock FTDI drivers btw.
The board I use it a mhetesp32minikit with no further attached hardware.
Things that might help me:
#1 - an EEP dump from a genuine minimodule so I can set mine up 100% correctly (serial number doesn’t matter, just make it 123 in the .XML)
#2 - cables are double-checked, but do I need to connect the ESP32’s RST pin? I read somewhere that it is not needed, the official help page lists it as “to be connected”
#3 - is there some sort of extended logging I can activate for the connection process?
Currently it’s really messy, I get this on upload:
Error: libusb_claim_interface() failed with LIBUSB_ERROR_ACCESS Error: unable to open ftdi device with vid 0403, pid 6010, description 'FT2232H MiniModule', serial '*' at bus location '*' ** OpenOCD init failed ** shutdown command invoked
But a ls /dev/cu.*
in bash returns the expected ports: /dev/cu.usbserial-13303DRXA
and /dev/cu.usbserial-13303DRXB
ioreg -p IOUSB -w0 -l
returns this info:
FT2232H MiniModule@fd120000 <class IOUSBDevice, id 0x100000c93, registered, matched, active, busy 0 (213 ms), retain 10>
“sessionID” = 9793361451502
“idProduct” = 24592
“bNumConfigurations” = 1
“iManufacturer” = 1
“bcdDevice” = 1792
“Bus Power Available” = 250
“bMaxPacketSize0” = 64
“USB Product Name” = “FT2232H MiniModule”
“iProduct” = 2
“iSerialNumber” = 3
“bDeviceClass” = 0
“IOUserClientClass” = “IOUSBDeviceUserClientV2”
“bDeviceSubClass” = 0
“USB Address” = 4
“bcdUSB” = 512
“locationID” = 18446744073660399616
“PortNum” = 2
“IOCFPlugInTypes” = {“9dc7b780-9ec0-11d4-a54f-000a27052861”=“IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle”}
“bDeviceProtocol” = 0
“USB Vendor Name” = “FTDI”
“Device Speed” = 2
“idVendor” = 1027
“USB Serial Number” = “13303DRX”
“Requested Power” = 250
“IOGeneralInterest” = “IOCommand is not serializable”
“Low Power Displayed” = No
my platformio.ini
for the hello world example I made:
[env:mhetesp32minikit]
board = mhetesp32minikit
framework = arduinomonitor_speed = 2000000
monitor_port = /dev/cu.SLAB_USBtoUARTupload_port = /dev/cu.usbserial-13303DRXB
upload_protocol = minimoduledebug_port = /dev/cu.usbserial-13303DRXB
debug_tool = minimodule
