I have been looking for two days on forums at potential interaction between USB CDC and UART0 on an ESP32-S2. All I could find indicate that once USB_CDC_ON_BOOT is enabled the Serial Monitor is using CDC instead of the UART0 and UART0 is available for other use.
I must have missed something - any clue about what I could be doing wrong?
I am using an ESP32-S2-DevKitM-1 to validate some code before moving to a custom board with ESP32-S2-SOLO module.
USB CDC: serial monitor (USB_CDC_ON_BOOT = 1) with monitor speed = 115200
UART0: RS485 / Modbus Slave with speed = 19200
My issue is: When I start the Modbus slave communication stack then the monitor starts displaying garbage (it seems to be a problem of communication speed as all is fine if Monitor and Modbus slave are both set at the same speed).
platformio.ini
[env]
-DARDUINO_USB_CDC_ON_BOOT=1
-DCONFIG_ARDUHAL_LOG_COLORS=1
-DCORE_DEBUG_LEVEL=5
monitor_filters = direct, esp32_exception_decoder
board_build.partitions = partitions.csv
[env:ESP32-S2-DevKitM-1]
board = esp32-s2-saola-1
Modbus slave setup:
#define GPIO_MB_SLAVE_TX GPIO_NUM_43
#define GPIO_MB_SLAVE_RX GPIO_NUM_44
#define GPIO_MB_485_SHDN GPIO_NUM_15 // GPIO to shutdown RS485 (drive high for normal operation)
#define MB_SLAVE_UART UART_NUM_0
#define MB_SLAVE_ADDR 1
#define MB_SLAVE_SPEED 19200
//#define MB_SLAVE_SPEED 115200
The code to setup the Modbus slave:
esp_err_t mbSlaveSetup()
log_v("Setup RS485 port and Modbus slave driver");
pinMode(GPIO_MB_485_SHDN, OUTPUT);
digitalWrite(GPIO_MB_485_SHDN, HIGH);
esp_err_t err = ESP_OK;
mb_slave_setup.mode = MB_MODE_RTU;
mb_slave_setup.slave_addr = MB_SLAVE_ADDR;
mb_slave_setup.port = MB_SLAVE_UART;
mb_slave_setup.baudrate = MB_SLAVE_SPEED;
mb_slave_setup.parity = MB_PARITY_NONE;
reg_area.type = MB_PARAM_HOLDING;
reg_area.address = ®
reg_area.start_offset = 0;
reg_area.size = REG_NUM * 2;
log_v("Initialize Modbus slave controller");
err = mbc_slave_init(MB_PORT_SERIAL_SLAVE, &mb_slave_handler);
if (err != ESP_OK) {
log_e("Error initializing the serial port for Modbus: %i", err);
return err;
log_v("setup Modbus slave");
err = mbc_slave_setup((void*)&mb_slave_setup);
log_e("Error Modbus slave setup: %i", err);
return err;
log_v("Set Modbus slave registers structure");
err = mbc_slave_set_descriptor(reg_area);
log_e("Error setting Modbus slave registers structure: %i", err);
return err;
log_v("Initialize Modbus communication stack");
delay(100);
err = mbc_slave_start();
log_e("Error starting Modbus communication stack: %i", err);
return err;
log_v("Set Modbus / RS485 UART pins - UART: %i / TX: %i / RX: %i", MB_SLAVE_UART, GPIO_MB_SLAVE_TX, GPIO_MB_SLAVE_RX);
err = uart_set_pin(MB_SLAVE_UART, GPIO_MB_SLAVE_TX, GPIO_MB_SLAVE_RX, -1, -1);
log_e("Error setting Modbus / RS485 UART pins: %i", err);
return err;
log_v("Set RS485 UART mode");
delay(100);
err = uart_set_mode(MB_SLAVE_UART, UART_MODE_RS485_HALF_DUPLEX);
log_e("Error setting Modbus UART mode: %i", err);
return err;
return ESP_OK;
Output:
[ 2075][V][mb_slave.cpp:11] mbSlaveSetup(): Setup RS485 port and Modbus slave driver
[ 2076][V][mb_slave.cpp:26] mbSlaveSetup(): Initialize Modbus slave controller
[ 2081][V][mb_slave.cpp:33] mbSlaveSetup(): setup Modbus slave
[ 2087][V][mb_slave.cpp:40] mbSlaveSetup(): Set Modbus slave registers structure
[ 2096][V][mb_slave.cpp:47] mbSlaveSetup(): Initialize Modbus communication stack
if I set the MB_SLAVE_SPEED = 115200 the output is fine:
[ 2074][V][mb_slave.cpp:11] mbSlaveSetup(): Setup RS485 port and Modbus slave driver
[ 2075][V][mb_slave.cpp:26] mbSlaveSetup(): Initialize Modbus slave controller
[ 2080][V][mb_slave.cpp:33] mbSlaveSetup(): setup Modbus slave
[ 2086][V][mb_slave.cpp:40] mbSlaveSetup(): Set Modbus slave registers structure
[ 2094][V][mb_slave.cpp:47] mbSlaveSetup(): Initialize Modbus communication stack
[ 2203][V][mb_slave.cpp:55] mbSlaveSetup(): Set Modbus / RS485 UART pins - UART: 0 / TX: 43 / RX: 44
[ 2203][V][mb_slave.cpp:62] mbSlaveSetup(): Set RS485 UART mode
