TD-er
May 31, 2018, 7:31pm
#1
This is the last part of the output with --verbose:
"c:\python27\python.exe" "C:\Users\gijs\.platformio\packages\tool-esptoolpy@1.20100.0\esptool.py" --chip esp32 elf2image --flash_mode dio --flash_freq 40m --flash_size 4MB -o .pioenvs\esp32dev\firmware.bin .pioenvs\esp32dev\firmware.elf
esptool.py v2.1
MethodWrapper(["upload"], [".pioenvs\esp32dev\firmware.bin"])
Auto-detected: COM9
"c:\python27\python.exe" "C:\Users\gijs\.platformio\packages\framework-arduinoespressif32\tools\esptool.py" --before default_reset --after hard_reset --chip esp32 --port "COM9" --baud 460800
usage: esptool [-h] [--chip {auto,esp8266,esp32}] [--port PORT] [--baud BAUD]
[--before {default_reset,no_reset}]
[--after {hard_reset,soft_reset,no_reset}] [--no-stub]
{load_ram,dump_mem,read_mem,write_mem,write_flash,run,image_info,make_image,elf2image,read_mac,chip_id,flash_id,read_flash_status,write_flash_status,read_flash,verify_flash,erase_flash,erase_region,version}
esptool: error: too few arguments
*** [upload] Error 2
I already uninstalled and reinstalled PlatformIO and all related plugins from Atom.
Any idea what’s going on here?
I cannot reproduce this.
Could you provide the output of pio --version
and do a pio platform update
(and maybe a pio upgrade --dev
When I build the blink example :
text data bss dec hex filename
125749 38280 2400 166429 28a1d .pioenvs\esp32dev\firmware.elf
"c:\python27\python.exe" "C:\Users\Maxi\.platformio\packages\tool-esptoolpy\esptool.py" --chip esp32 elf2image --flash_mode dio --flash_freq 40m --flash_size 4MB -o .pioenvs\esp32dev\firmware.bin .pioenvs\esp32dev\firmware.elf
esptool.py v2.3.1
AVAILABLE: esptool, minimodule, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h
Auto-detected: COM8
"c:\python27\python.exe" "C:\Users\Maxi\.platformio\packages\tool-esptoolpy\esptool.py" --chip esp32 --port "COM8" --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 C:\Users\Maxi\.platformio\packages\framework-arduinoespressif32\tools\sdk\bin\bootloader_dio_40m.bin 0x8000 C:\Users\Maxi\.platformio\platforms\espressif32\examples\arduino-blink\.pioenvs\esp32dev\partitions.bin 0xe000 C:\Users\Maxi\.platformio\packages\framework-arduinoespressif32\tools\partitions\boot_app0.bin 0x10000 .pioenvs\esp32dev\firmware.bin
esptool.py v2.3.1
Connecting........_
Chip is ESP32D0WDQ6 (revision 0)
Features: WiFi, BT, Dual Core
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 12496 bytes to 8282...
Wrote 12496 bytes (8282 compressed) at 0x00001000 in 0.7 seconds (effective 135.8 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 144...
Wrote 3072 bytes (144 compressed) at 0x00008000 in 0.0 seconds (effective 1228.8 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 5957.9 kbit/s)...
Compressed 164160 bytes to 83853...
Wrote 164160 bytes (83853 compressed) at 0x00010000 in 7.4 seconds (effective 177.3 kbit/s)...
Leaving...
Hard resetting via RTS pin...
============================================ [SUCCESS] Took 24.43 seconds ============================================
TD-er
May 31, 2018, 8:00pm
#3
PS C:\Arduino\ESPeasy\arduino-1.8.3\portable\sketchbook\ESPEasy_Gijs\ESPEasy> pio --version
PlatformIO, version 3.5.3rc2
pio platform update:
PS C:\Arduino\ESPeasy\arduino-1.8.3\portable\sketchbook\ESPEasy_Gijs\ESPEasy> pio platform update
Platform Atmel AVR
Updating atmelavr @ 1.8.2 [Up-to-date]
Updating toolchain-atmelavr @ 1.40902.1 [Up-to-date]
Updating framework-arduinoavr @ 1.10620.2 [Up-to-date]
Platform Espressif 32
Updating espressif32 @ 1.0.1 [Up-to-date]
Updating tool-esptoolpy @ 1.20310.0 [Up-to-date]
Updating tool-espotapy @ 1.1.0 [Up-to-date]
Updating toolchain-xtensa32 @ 2.50200.80 [Up-to-date]
Updating framework-arduinoespressif32 @ 1.5.3 [Up-to-date]
Updating tool-mkspiffs @ 2.230.0 [Up-to-date]
Updating espressif32 @ 0.12.0 [Fixed]
Updating tool-esptoolpy @ 1.20100.0 [Up-to-date]
Updating toolchain-xtensa32 @ 1.50200.2 [Up-to-date]
Updating framework-arduinoespressif32 @ 1.4.0 [Up-to-date]
Platform Espressif 32 (Stage)
Updating espressif32 @ 4dfeae1 [Up-to-date]
Updating framework-arduinoespressif32 @ 89859f7 [Up-to-date]
Platform Espressif 8266
Updating espressif8266 @ 1.7.0 [Up-to-date]
Updating tool-mkspiffs @ 1.200.0 [Up-to-date]
Updating tool-esptool @ 1.413.0 [Up-to-date]
Updating framework-arduinoespressif8266 @ 1.20401.2 [Up-to-date]
Updating toolchain-xtensa @ 1.40802.0 [Up-to-date]
Updating espressif8266 @ 1.5.0 [Fixed]
Updating tool-mkspiffs @ 1.102.0 [Up-to-date]
Updating tool-esptool @ 1.409.0 [Up-to-date]
Updating tool-espotapy @ 1.0.0 [Up-to-date]
Updating framework-arduinoespressif8266 @ 1.20300.1 [Up-to-date]
Updating espressif8266 @ 1.6.0 [Fixed]
Updating framework-arduinoespressif8266 @ 1.20400.3 [Up-to-date]
Platform Espressif 8266 (Stage)
Updating espressif8266 @ 98da8ea [Up-to-date]
Updating framework-arduinoespressif8266 @ ab7e109 [Up-to-date]
Upgrade --dev:
PS C:\Arduino\ESPeasy\arduino-1.8.3\portable\sketchbook\ESPEasy_Gijs\ESPEasy> pio upgrade --dev
Please wait while upgrading PlatformIO ...
PlatformIO has been successfully upgraded to 3.5.3rc2
Release notes: http://docs.platformio.org/en/latest/history.html
And still same result.
Our used esptool.py
is different (esptool.py v2.1
vs esptool.py v2.3.1
). Did you get the newer version after updating? Is still using the one from tool-esptoolpy@1.20100.0\esptool
instead of the newest version 1.20310.0
Also you have multiple versions of the ESP32 platform packages installed, some fixed version and a staging version? What’s your platformio.ini
TD-er
May 31, 2018, 8:06pm
#5
This is my platform.ini:
It used to work fine, until one of the last updates last week. (not sure if it is one of the last updates, I installed it last week)
That file uses a fixed-version platform = espressif32@0.12.0
at line 63. Comment that line out and uncomment line 64. Does that work now?
Otherwise try if you can reproduce this with a simple blink example, that platformio.ini
file has 594 lines. The fixed version is probably the problem. combined that is uses a different esptool.py
version, suddenly.
TD-er
May 31, 2018, 8:16pm
#7
Still the same when using the staged version.
I will try to locate the Blink test version.
It was linked above (platform-espressif32/examples/arduino-blink at master · platformio/platform-espressif32 · GitHub ). Does it upload normally with an unmodified platformio.ini
? What if you put platform = espressif32@0.12.0
? (BTW, when multiple enviroments are defined, you can use pio run -t upload -e esp32dev
to use a specific environment)
TD-er
May 31, 2018, 8:26pm
#9
I built the blink example.
[05/31/18 22:22:21] Processing esp32dev (platform: espressif32; board: esp32dev; framework: arduino)
Collected 23 compatible libraries
Looking for dependencies...
AttributeError: 'PlatformBoardConfig' object has no attribute 'update':
File "C: \python27\lib\site-packages\platformio\builder\main.py", line 158:
File "C: \Users\gijs\.platformio\packages\tool-scons\script\..\engine\SCons\Script\SConscript.py", line 541:
File "C: \Users\gijs\.platformio\packages\tool-scons\script\..\engine\SCons\Script\SConscript.py", line 250:
exec _file_ in call_stack[-1].globals
File "C: \Users\gijs\.platformio\platforms\espressif32 @src-9112e7894fcfd1325e3c29a50a2b0d5d\builder\main.py", line 249:
_update_max_upload_size(env)
File "C: \Users\gijs\.platformio\platforms\espressif32 @src-9112e7894fcfd1325e3c29a50a2b0d5d\builder\main.py", line 89:
env.BoardConfig().update("upload.maximum_size", max(sizes))
============================================== [ERROR] Took 1.16 seconds ==============================================
====================================================== [SUMMARY] ======================================================
Environment esp32dev [ERROR]
Environment esp-wrover-kit [SKIP]
Environment quantum [SKIP]
Environment lolin32 [SKIP]
============================================== [ERROR] Took 1.17 seconds ==============================================
I’ve seen that error also in my quest to solve this issue the past 3 evenings.
(I added some spaces, since I got a report I could not have more than 2 links in a post as a new user, but there were no links)
For me the blink example compiles and uploads fine with both
and
With the @0.12.0
it outputs
MethodWrapper([".pioenvs\esp32dev\firmware.elf"], [".pioenvs\esp32dev\src\Blink.cpp.o"])
124161 35144 2400 161705 277a9 .pioenvs\esp32dev\firmware.elf
"c:\python27\python.exe" "C:\Users\Maxi\.platformio\packages\tool-esptoolpy@1.20100.0\esptool.py" --chip esp32 elf2image --flash_mode dio --flash_freq 40m --flash_size 4MB -o .pioenvs\esp32dev\firmware.bin .pioenvs\esp32dev\firmware.elf
esptool.py v2.1
Auto-detected: COM8
"c:\python27\python.exe" "C:\Users\Maxi\.platformio\packages\framework-arduinoespressif32@1.4.0\tools\esptool.py" --before default_reset --after hard_reset --chip esp32 --port "COM8" --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 C:\Users\Maxi\.platformio\packages\framework-arduinoespressif32@1.4.0\tools\sdk\bin\bootloader_dio_40m.bin 0x8000 C:\Users\Maxi\.platformio\platforms\espressif32\examples\arduino-blink\.pioenvs\esp32dev\partitions.bin 0xe000 C:\Users\Maxi\.platformio\packages\framework-arduinoespressif32@1.4.0\tools\partitions\boot_app0.bin 0x10000 .pioenvs\esp32dev\firmware.bin
esptool.py v2.1
Connecting........_
Uploading stub...
Where it correctly uses framework-arduinoespressif32@1.4.0\tools\esptool.py
(yours shows framework-arduinoespressif32\tools\esptool.py
Weird. I suggest purging your entire PIO installation and starting from scratch. At first make sure you uninstall everything ESP32 related (pio platform uninstall espressif32
). Uninstall the plugin, search for your .platformio
folder, delete everything in it, and re-install the plugin.
TD-er
May 31, 2018, 8:42pm
#11
Would it be a good idea to also install everything in another folder?
And what is all PlatformIO related?
Is it also somewhere configured in Atom or VScode in another location other than the path of my Github location?
It should be good enough if every PIO was purged completly. If you installed it from CLI I’d to pip uninstall platformio
(as admin), then delete the entire C:\Users\gijs\.platformio
folder. If your IDE has a built-in core, you need to uninstall the plugin and search for the .platformio
folder with the Windows Explorer. (Redirecting... )
TD-er
May 31, 2018, 9:54pm
#13
Took a while, I removed everything related to PlatformIO, but still the same issues.
I guess I will go to sleep now and try to think about what to do next.
I’ve already been trying to get this to work for 4 evenings now.
I’m close to the point of format C: and reinstall everything on my laptop, which will probably take another 4 days to get it all working again.
Maybe I will try to get some other PC to install this and see if that will work with the latest PlatformIO.
TD-er
June 1, 2018, 7:22pm
#15
I just feel so stupid. Tried to upgrade to 3.5.3, but it keeps reporting
You’re up-to-date!
PlatformIO 3.5.4a1 is currently the newest version available.
And (ofcourse?) it still does report:
Uploading .pioenvs\esp32dev\firmware.bin
[--trace]
[ERROR] Took 117.89 seconds
[ERROR] Took 117.90 seconds
Apparently I’m doing something wrong, but I have no idea what.
And I’m stuck for way longer than I would like to admit to myself.
TD-er
June 1, 2018, 7:48pm
#17
All updated, same result.
All removed and reinstalled (platformIO plugins + config directories) and performed update as suggested:
827745 281216 41248 1150209 118d01 .pioenvs\esp32dev\firmware.elf
Building .pioenvs\esp32dev\firmware.bin
esptool.py v2.3.1
Looking for upload port...
Auto-detected: COM9
[--trace]
[ERROR] Took 104.63 seconds
Linked file looks about 30% bigger by the way, but someone else already created an issue about that.
Could you run with pio run -v -t upload
? You will see the full command.
TD-er
June 1, 2018, 8:01pm
#19
ivankravets:
Had already done that (verbose) run:
827833 281360 41248 1150441 118de9 .pioenvs\esp32dev\firmware.elf
"c:\users\gijs\.platformio\penv\scripts\python.exe" "C:\Users\gijs\.platformio\packages\tool-esptoolpy\esptool.py" --chip esp32 elf2image --flash_mode dio --flash_freq 40m --flash_size 4MB -o .pioenvs\esp32dev\firmware.bin .pioenvs\esp32dev\firmware.elf
esptool.py v2.3.1
Auto-detected: COM9
"c:\users\gijs\.platformio\penv\scripts\python.exe" "C:\Users\gijs\.platformio\packages\tool-esptoolpy\esptool.py" --chip esp32 --port "COM9" --baud 460800
[--trace]
Edit:
Just to be complete, this is what’s being set in the pip in that venv:
C:\>cd Users\gijs\.platformio
C:\Users\gijs\.platformio>penv\Scripts\activate.bat
(penv) C:\Users\gijs\.platformio>pip freeze
bottle==0.12.13
certifi==2018.4.16
chardet==3.0.4
click==5.1
colorama==0.3.9
idna==2.6
lockfile==0.12.2
platformio==3.5.4a1
pyserial==3.4
requests==2.18.4
semantic-version==2.6.0
urllib3==1.22
