Still the same result.
What can/should I remove to get it to work again?
At this moment I am even willing to completely wipe the hard drive and do a full re-install + perform a rain-dance.
OK, it seems the bin file is not included in the 2nd esptool.py command.
I just did this from within the terminal and it does do some uploading:
C:\Arduino\ESPeasy\arduino-1.8.3\portable\sketchbook\ESPEasy_Gijs\ESPEasy>"c:\users\gijs\.platformio\penv\scripts\python.exe" "C:\Users\gijs\.platformio\packages\tool-esptoolpy\esptool.py" --chip esp32 --port "COM9" --baud 460800 write_flash 0x00000 .pioenvs\esp32dev\firmware.bin
esptool.py v2.3.1
Connecting........__
Chip is ESP32D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 1109312 bytes to 639989...
Wrote 1109312 bytes (639989 compressed) at 0x00000000 in 15.5 seconds (effective 570.7 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
The compiled file doesn’t do what I expect it to do, but maybe the offset (0x00000) is not correct?
See
Do you use official platform = espressif32
dev/platform?
Hmm looks like I wrote it to the wrong address.
#platform = espressif32@1.0.1
platform = https://github.com/platformio/platform-espressif32.git#feature/stage
Tried both these. The last one is currently active.
Last week it was still @0.12.0
It is this config:
I’ve just tried the latest staging version and it works for me. See
"/Volumes/SOFT/Projects/GitHub/platformio/origin/.tox/develop/bin/python" "/Users/ikravets/.platformio/packages/tool-esptoolpy/esptool.py" --chip esp32 elf2image --flash_mode dio --flash_freq 40m --flash_size 4MB -o .pioenvs/esp32dev/firmware.bin .pioenvs/esp32dev/firmware.elf
esptool.py v2.3.1
Could you also provide an output of pio platform show espressif32
PS C:\Arduino\ESPeasy\arduino-1.8.3\portable\sketchbook\ESPEasy_Gijs\ESPEasy> pio platform show espressif32
espressif32 ~ Espressif 32 (Stage)
Espressif Systems is a privately held fabless semiconductor company. They provide wireless communications and Wi-Fi chips which are widely used in mobile devices and the Internet of Things applications.
Version: 77cb4bc
Home: http://platformio.org/platforms/espressif32
Repository: https://github.com/platformio/platform-espressif32.git
Vendor: https://espressif.com/
License: Apache-2.0
Frameworks: arduino, espidf, pumbaa, simba
Packages
Package toolchain-xtensa32
Type: toolchain
Requirements: ~2.50200.0
Installed: Yes
Version: 2.50200.80
Original version: 5.2.0
Description: GCC for SoC Xtensa L108
Package tool-openocd-esp32
Type: debugger
Requirements: ~1.1000.0
Installed: No (optional)
Package framework-simba
Type: framework
Requirements: >=12.2.0
Package tool-mkspiffs
Type: uploader
Requirements: ~2.230.0
Installed: Yes
Version: 2.230.0
Original version: 2.30
Description: Tool to build and unpack SPIFFS images
Package framework-arduinoespressif32
Type: framework
Requirements: https://github.com/espressif/arduino-esp32.git
Installed: Yes
Version: 89859f7
Original version: None
Description: Arduino Wiring-based Framework (ESP32 Core)
Package framework-pumbaa
Type: framework
Requirements: >=2.3.0
Package tool-espotapy
Type: uploader
Requirements: ~1.1.0
Installed: Yes
Version: 1.1.0
Description: This script will push an OTA update to the ESP
Package framework-espidf
Type: framework
Requirements: ~2.300.0
Package tool-esptoolpy
Type: uploader
Requirements: ~1.20310.0
Installed: Yes
Version: 1.20310.0
Original version: 2.3.10
Description: ESP8266 and ESP32 serial bootloader utility
Boards
ID MCU Frequency Flash RAM Name
esp32-evb ESP32 240MHz 1.25MB 288KB OLIMEX ESP32-EVB
wemosbat ESP32 240MHz 1.25MB 288KB WeMos WiFi & Bluetooth Battery
esp32thing ESP32 240MHz 1.25MB 288KB SparkFun ESP32 Thing
m5stack-core-esp32 ESP32 240MHz 1.25MB 288KB M5Stack Core ESP32
nano32 ESP32 240MHz 1.25MB 288KB MakerAsia Nano32
espectro32 ESP32 240MHz 1.25MB 288KB ESPectro32
pocket_32 ESP32 240MHz 1.25MB 288KB Dongsen Tech Pocket 32
quantum ESP32 240MHz 1.25MB 288KB Noduino Quantum
node32s ESP32 240MHz 1.25MB 288KB Node32s
heltec_wifi_kit_32 ESP32 240MHz 1.25MB 288KB Heltec WIFI Kit 32
esp32doit-devkit-v1 ESP32 240MHz 1.25MB 288KB DOIT ESP32 DEVKIT V1
espea32 ESP32 240MHz 1.25MB 288KB April Brother ESPea32
esp32dev ESP32 240MHz 1.25MB 288KB Espressif ESP32 Dev Module
lolin32 ESP32 240MHz 1.25MB 288KB WEMOS LOLIN32
onehorse32dev ESP32 240MHz 1.25MB 288KB Onehorse ESP32 Dev Module
nodemcu-32s ESP32 240MHz 1.25MB 288KB NodeMCU-32S
esp-wrover-kit ESP32 240MHz 1.25MB 4MB Espressif ESP-WROVER-KIT
esp32-gateway ESP32 240MHz 1.25MB 288KB OLIMEX ESP32-GATEWAY
hornbill32minima ESP32 240MHz 1.25MB 288KB Hornbill ESP32 Minima
esp320 ESP32 240MHz 1.25MB 288KB Electronic SweetPeas ESP320
heltec_wifi_lora_32 ESP32 240MHz 1.25MB 288KB Heltec WIFI LoRa 32
intorobot ESP32 240MHz 1.25MB 288KB IntoRobot Fig
hornbill32dev ESP32 240MHz 1.25MB 288KB Hornbill ESP32 Dev
nina_w10 ESP32 240MHz 1.25MB 288KB u-blox NINA-W10 series
widora-air ESP32 240MHz 1.25MB 288KB Widora AIR
esp32vn-iot-uno ESP32 240MHz 1.25MB 288KB ESP32vn IoT Uno
mhetesp32devkit ESP32 240MHz 1.25MB 288KB MH ET LIVE ESP32DevKIT
pico32 ESP32 240MHz 1.25MB 288KB ESP32 Pico Kit
microduino-core-esp32 ESP32 240MHz 1.25MB 288KB Microduino Core ESP32
featheresp32 ESP32 240MHz 1.25MB 288KB Adafruit ESP32 Feather
firebeetle32 ESP32 240MHz 1.25MB 288KB FireBeetle-ESP32
mhetesp32minikit ESP32 240MHz 1.25MB 288KB MH ET LIVE ESP32MiniKit
espino32 ESP32 240MHz 1.25MB 288KB ESPino32
Oh and the problem is not into building it, that’s fine.
It is the upload that’s failing.
Where in the PlatformIO should these parameters for ESPtool flash upload be set?
I find it really odd that my system is apparently so messed-up right now that I cannot upload to ESP32 anymore from PlatformIO.
I tested on Atom and VScode, but both refuse to work.
So is there anything I can set in the .ini file to make it work again?
Finally I was able to do manual flash of my own compiled ESP32 binary again.
Run in terminal:
esptool --before default_reset --after hard_reset --chip esp32 --port "COM9" --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 C:\Users\gijs\.platformio\packages\framework-arduinoespressif32@1.4.0\tools\sdk\bin\bootloader_dio_40m.bin 0x8000 C:\Users\gijs\.platformio\packages\framework-arduinoespressif32@1.4.0\tools\partitions\default.bin 0xe000 C:\Users\gijs\.platformio\packages\framework-arduinoespressif32@1.4.0\tools\partitions\boot_app0.bin 0x10000 .pioenvs\esp32dev\firmware.bin
But now the big question:
How to make PlatformIO generate this line automatically again?
And what is changed with the 1.0.1 version? The 0.12.0 version worked fine with the line above, but the 1.0.1 does not work with that line.
C:\.platformio
and HOME_DIR/.platformio
foldersIt seems that you have broken build scripts for esp32 dev/platform.
I double (triple) checked and made sure all platformio related folders are removed.
Python was already uninstalled and before uninstalling that it was stripped of any platformio installed package.
There are no platformio related settings in the environment.
I just tested with platform = espressif32@1.0.2 and @0.12.0 and last night I tested with GitHub - platformio/platform-espressif32: Espressif 32: development platform for PlatformIO
Atom has been re-installed, PlatformIO has been reinstalled many, many times.
All MS-related dev tools are removed from my system.
Latest updates are installed, just to make sure.
Curren PlatformIO version reported is: Home 0.9.6·Core 3.6.0a1
And still the same error when flashing.
With my own command to flash, I cannot flash anything built newer than @0.12.0, but that may have something to do with used offsets, partition layouts, or one of the many other new features perhaps.
It will flash, but the resulting firmware is unusable.
I’m very close to calling a format-C and reinstall my entire laptop (which will take a lot of time to setup like it should be).
Do you have a custom partition table? Could you try to create new/clean simple project and try to flash it? Do you have extra scripts in project?
We don’t use extra scripts in the project.
And as far as I know, it is just the default partition table.
We’re just in the process of including ESP32 in the same project (ESPeasy, see platformio.ini)
So we can still change everything if there are bad choices made regarding ESP32.
I was planning to get to bed a bit early today, so testing a new clean/simple project I’d rather do tomorrow, since it is already close to 23h30.
Same deal with my setup. esptool: error: too few arguments
Do you use Windows too?
Yes, Windows 10 here.
cmd.exe
(not in IDE) and type pip list
. Please share an output hereplatformio.ini
.Don’t forget to run in PIO IDE Terminal: pio update
and pio upgrade --dev
P.S: I’ve just tried to build “arduino-blink” project from example on my VM Win10 and can’t reproduce this issue.
1:
pip 10.0.1
setuptools 39.0.1
2:
https://www.dropbox.com/s/qwuzktx8kzbgrdo/platformio.ini?dl=1
I also did the updates. But I got other software with dependencies using 2.7 and some use 3.6… different locations each one. Only C:\Users\Jimmy.platformio\python27\ is found in PATH though.
So I still get the same error.
Just some feedback. My build log state that esptool 2.1 is used, not 2.3.1. Could that be of importance?
Something is wrong with your installation. Please remove C:\Users\Jimmy\.platformio
folder and build project again.
Also, please use the latest esp32 dev platform.
Today I updated PlatformIO to Core 3.6.0a2 and now I cannot even run my “magic line” anymore to flash it by hand.
So now my test system can only build ESP32 code and I see no way anymore to flash it to the node
PS C:\Arduino\ESPeasy\arduino-1.8.3\portable\sketchbook\ESPEasy_Gijs\ESPEasy> esptool --before default_reset --after hard_reset --chip esp32 --port "COM9" --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flas
esptool : The term 'esptool' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:1
+ esptool --before default_reset --after hard_reset --chip esp32 --port ...
+ CategoryInfo : ObjectNotFound: (esptool:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
PS C:\Arduino\ESPeasy\arduino-1.8.3\portable\sketchbook\ESPEasy_Gijs\ESPEasy> "c:\users\gijs\.platformio\penv\scripts\python.exe" "C:\Users\gijs\.platformio\packages\tool-esptoolpy\esptool.py" --before default_reset --after hard_reset --chip esp32 -
re.bin
At line:1 char:53
+ ... python.exe" "C:\Users\gijs\.platformio\packages\tool-esptoolpy\esptoo ...
Unexpected token '"C:\Users\gijs\.platformio\packages\tool-esptoolpy\esptool.py"' in expression or statement.
At line:1 char:118
+ ... gijs\.platformio\packages\tool-esptoolpy\esptool.py" --before default ...
Unexpected token 'before' in expression or statement.
At line:1 char:53
The '--' operator works only on variables or on properties.
+ CategoryInfo : ParserError: (:) [], ParentContainsErrorRecordException
+ FullyQualifiedErrorId : UnexpectedToken
Edit:
Running this in a command shell finally worked (running ESP32@0.12.0 by the way)
C:\Users\gijs\.platformio\penv\Scripts\activate.bat
"c:\users\gijs\.platformio\penv\scripts\python.exe" "C:\Users\gijs\.platformio\packages\tool-esptoolpy\esptool.py" --chip esp32 --port "COM9" --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 C:\Users\gijs\.platformio\packages\framework-arduinoespressif32@1.4.0\tools\sdk\bin\bootloader_dio_40m.bin 0x8000 C:\Users\gijs\.platformio\packages\framework-arduinoespressif32@1.4.0\tools\partitions\default.bin 0xe000 C:\Users\gijs\.platformio\packages\framework-arduinoespressif32@1.4.0\tools\partitions\boot_app0.bin 0x10000 C:\Arduino\ESPeasy\arduino-1.8.3\portable\sketchbook\ESPEasy_Gijs\ESPEasy\.pioenvs\esp32dev\firmware.bin
