ESP32 Debug is OK for simple program but fails for complex program
Hi, i have a strange Debugging problem with Debug ESP32 board, ESP-Prog & PlatformIO.
The wiring are OK and I can debug a simple led program,
when i debug complex program (without to use GPPIO 12,13,14 & 15) the debug fail.
Hardware & platformio.ini are the same
Can you help me?
Thanks
Hardware Wiring
Board: az-delivery-devkit-v4
Board link to usb PC via usb COM9
ESP-Prog link to usb PC via usb COM11
None Vcc link
TEST LED PROGRAM
  1. Power on DevKitC-v4 board via usb
  2. Power on Esp-prog board via usb
  3. Run VSC with PlatformIO
  4. Upload code to DevKiC board
  5. Start Debuggin
  6. Debug is OK
Simple led program
pinMode(2, OUTPUT);
while (!Serial);
digitalWrite(2, HIGH);
delay(1000);
digitalWrite(2, LOW);
delay(1000);
Serial.print(".");
platformio.ino led program
[env:az-delivery-devkit-v4]
board = az-delivery-devkit-v4
board_build.partitions = partitions_OTA_1.9MB-APP_190KB-SPIF.csv
monitor_port = COM9
upload_port = COM9
upload_protocol = esptool
debug_tool = esp-prog
On monitor COM9
ets Jun 8 2016 00:22:57
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13104
load:0x40080400,len:3036
entry 0x400805e4
E (147) esp_core_dump_flash: No core Äf~mp partition found!
E (147) esp_core_dump_flash: No core dump partition found!
On debug console
undefinedD:\Users\nicola.platformio\packages\toolchain-xtensa-esp32@8.4.0+2021r2-patch5\bin\xtensa-esp32-elf-gdb.exe: warning: Couldn’t determine a path for the index cache directory.
Reading symbols from d:_IoT\Platformio\Led1.pio\build\az-delivery-devkit-v4\firmware.elf…
PlatformIO Unified Debugger → bit.ly/pio-debug
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read openocdorg /doc/doxygen/bugs.html
adapter speed: 20000 kHz
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : clock speed 5000 kHz
Info : [esp32.cpu0] Debug controller was reset.
Info : [esp32.cpu0] Core was reset.
Info : [esp32.cpu1] Debug controller was reset.
Info : [esp32.cpu1] Core was reset.
Info : starting gdb server for esp32.cpu0 on pipe
Info : accepting ‘gdb’ connection from pipe
Info : [esp32.cpu0] Target halted, PC=0x400F0A9E, debug_reason=00000000
Info : Set GDB target to ‘esp32.cpu0’
Info : [esp32.cpu1] Target halted, PC=0x400F0A9E, debug_reason=00000000
Warn : No symbols for FreeRTOS!
Info : [esp32.cpu0] Target halted, PC=0x40092612, debug_reason=00000001
Info : Flash mapping 0: 0x10020 → 0x3f400020, 49 KB
Info : Flash mapping 1: 0x20020 → 0x400d0020, 133 KB
Info : Auto-detected flash bank ‘esp32.cpu0.flash’ size 4096 KB
Info : Using flash bank ‘esp32.cpu0.flash’ size 4096 KB
Info : Using flash bank ‘esp32.cpu0.irom’ size 136 KB
Info : Using flash bank ‘esp32.cpu0.drom’ size 52 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (1030 ms). Workaround: increase “set remotetimeout” in GDB
0x400f0a9e in esp_pm_impl_waiti () at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/hal/esp32/include/hal/cpu_ll.h:183
183 /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/hal/esp32/include/hal/cpu_ll.h: No such file or directory.
Info : [esp32.cpu0] requesting target halt and executing a soft reset
Info : [esp32.cpu0] Target halted, PC=0x500000CF, debug_reason=00000000
Info : [esp32.cpu1] requesting target halt and executing a soft reset
Info : [esp32.cpu0] Target halted, PC=0x40000400, debug_reason=00000000
Info : [esp32.cpu1] Target halted, PC=0x40000400, debug_reason=00000000
Temporary breakpoint 1 at 0x400d1343: file src/main.cpp, line 8.
PlatformIO: Resume the execution to debug_init_break = tbreak setup
PlatformIO: More configuration options → bit.ly/pio-debug
Note: automatically using hardware breakpoints for read-only addresses.
Info : [esp3
2.cpu0] Target halted, PC=0x400D9004, debug_reason=00000000
[esp32.cpu0] Target halted, PC=0x400D9004, debug_reason=00000000
Info : [esp32.cpu1] Target halted, PC=0x400D1343, debug_reason=00000001
[New Thread 1073468596]
[New Thread 1073494628]
[New Thread 1073446332]
[New Thread 1073461528]
[New Thread 1073445672]
[New Thread 1073467196]
[Switching to Thread 1073449076]
Thread 1 “loopTask” hit Temporary breakpoint 1, setup () at src/main.cpp:8
8 pinMode(LED_BUILTIN, OUTPUT); // initialize LED digital pin as an output.
TEST OTHER PROGRAM
  5. Start Debuggin
  6. Debug Failure
Upload program
Writing at 0x001a9ca3… (98 %)
Writing at 0x001af1e3… (100 %)
Wrote 1718496 bytes (1093906 compressed) at 0x00010000 in 28.3 seconds (effective 485.7 kbit/s)…
Hash of data verified.
Leaving…
Hard resetting via RTS pin…
[SUCCESS] Took 99.25 seconds
platformio.ino other program
monitor_port = COM9
upload_port = COM9
debug_speed = 500
Visual Studio Code
Failed to launch GDB: .pioinit:11 Error in sourced command file:
Remote communication error. Target disconnected.: Success. (from interpreter-exec console
“source.pioinit”)
Open ‘launch.json’ button
Cancel button
launch.json
“version”: “0.2.0”,
“configurations”: [
“type”: “platformio-debug”,
“request”: “launch”,
“name”: “PIO Debug”,
“executable”: “d:/_IoT/YAHAS/Code/ESP/platformio/NodeAgent/.pio/build/az-delivery-devkit-v4/firmware.elf”,
“projectEnvName”: “az-delivery-devkit-v4”,
“toolchainBinDir”: “D:/Users/nicola/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/bin”,
“internalConsoleOptions”: “openOnSessionStart”,
“preLaunchTask”: {
“type”: “PlatformIO”,
“task”: “Pre-Debug”
“name”: “PIO Debug (skip Pre-Debug)”,
“name”: “PIO Debug (without uploading)”,
“loadMode”: “manual”
Debug console
Reading symbols from d:_IoT_YAHAS_\Code\ESP\platformio\NodeAgent.pio\build\az-delivery-devkit-v4\firmware.elf…
adapter speed: 500 kHz
Info : clock speed 500 kHz
Error: JTAG scan chain interrogation failed: all zeroes
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway…
Error: esp32.cpu0: IR capture error; saw 0x00 not 0x01
Warn : Bypassing JTAG setup events due to errors
Error: Unexpected OCD_ID = 00000000
Warn : target esp32.cpu0 examination failed
Warn : target esp32.cpu1 examination failed
Error: Target not examined yet
Error executing event gdb-attach on target esp32.cpu0:
Error: Target not halted
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use ‘gdb_memory_map disable’.
Error: attempted ‘gdb’ connection rejected
Error: error during select: Unknown error
Hello. I got the same problem. Debug start and function with a simple blink program. It fails with more complex program.
Same issue for me. Simple code works, with higher complexity it fails.
Could you solve the issue?
Same problem here!!
And it is being reported several times …
Anyone has any hint?
