Hello All,
i have an issue with debugging My ESP32 using the ESP-prog.
This is my setting and config:
1- ESP32 -Wroom - devkit
2- ESP-prog
3- This is my platform.ini :
platform = espressif32 @ 5.0.0
https://github.com/pschatzmann/arduino-libhelix#351a27118629fadaa4ceb448457691b9603ee7cd
moononournation/GFX Library for Arduino @ ^1.2.3
bitbank2/JPEGDEC@^1.2.7
; apechinsky/MemoryFree@^0.3.0
platform_packages =
framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32#master
;upload_port=/dev/cu.usbserial-14330
;upload_protocol = esp-prog
debug_tool = esp-prog
debug_speed = 5000
;board_build.partitions = partitions.csv
and this is my error:
Reading symbols from /Users/imanyazdansepas/Desktop/ZixopasLAB/P18_PixyToy/3_Firmware/Cubipax/.pio/build/esp32dev/firmware.elf...
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.11.0-esp32-20220411 (2022-04-11-08:47)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
DEPRECATED! use 'adapter speed' not 'adapter_khz'
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 5000 kHz
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Warn : target esp32.cpu1 examination failed
Info : starting gdb server for esp32.cpu0 on pipe
Info : esp32.cpu0: Target halted, PC=0x40007BA1, debug_reason=00000000
Info : Set GDB target to 'esp32.cpu0'
Warn : No symbols for FreeRTOS!
Info : esp32.cpu0: Target halted, PC=0x4009260E, debug_reason=00000001
Error: Failed to get flash maps (4294967290)!
Warn : Failed to get flash mappings (-4)!
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.irom' size 0 KB
Info : Using flash bank 'esp32.cpu0.drom' size 0 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
0x40007ba1 in ?? ()
Error: Too large number of threads 1618811068!
Info : esp32.cpu0: Target halted, PC=0x500000CF, debug_reason=00000000
Info : esp32.cpu0: Target halted, PC=0x40000400, debug_reason=00000000
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Info : esp32.cpu1: Target halted, PC=0x40000400, debug_reason=00000000
Info : Auto-detected flash bank 'esp32.cpu1.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu1.flash' size 4096 KB
** Programming Started **
Info : PROF: Data transferred in 105.677 ms @ 189.256 KB/s
** Programming Finished **
** Verify Started **
Error: **** Verification failure! ****
Error: target_hash d88c...a7bb53
Error: file_hash: 10d09b...3e7b68
embedded:startup.tcl:1162: Error: ** Verify Failed **
in procedure 'program_esp'
in procedure 'program_error' called at file "/Users/imanyazdansepas/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp_common.cfg", line 135
at file "embedded:startup.tcl", line 1162
Info : PROF: Data transferred in 30.288 ms @ 132.066 KB/s
Error: target_hash 85a79...213f1d
Error: file_hash: efba44...5cead4
Info : PROF: Data transferred in 44.547 ms @ 179.586 KB/s
Error: target_hash af53cf...ee5d88
Error: file_hash: f94c5d...a17f0
Info : PROF: Data transferred in 4760.03 ms @ 205.041 KB/s
Error: target_hash e874e3...5444d1
Error: file_hash: d0ff59...e3e87
Temporary breakpoint 1 at 0x400d2f0c: file src/main.cpp, line 118.
PlatformIO: Resume the execution to `debug_init_break = tbreak setup`
PlatformIO: More configuration options -> https://bit.ly/pio-debug
Warn : address 0x400d2f0c not writable
Error: esp32.cpu0: Failed to write breakpoint instruction (-4)!
Error: esp32.cpu0: Failed to add SW breakpoint!
Error: can't add breakpoint: unknown reason
Warn : address 0x400d2f15 not writable
Warning:
Cannot insert breakpoint 1.
Cannot access memory at address 0x400d2f0c
Cannot insert breakpoint 2.
Cannot access memory at address 0x400d2f15
Command aborted.
Any help would be apriciated
Thank you
