Hello guys Im having problem with Building this basic program:
// put function declarations here:
int myFunction(int, int);
int result = myFunction(2, 3);
// put function definitions here:
int myFunction(int x, int y) {
return x + y;
And when I try to build it I get this error:
- Looking for pins_arduino.h dependency? Check our library registry!
- CLI > platformio lib search “header:pins_arduino.h”
- Web > PlatformIO Registry
#include “pins_arduino.h”
compilation terminated.
*** [.pio\build\esp32dev\FrameworkArduino\FunctionalInterrupt.cpp.o] Error 1
============================ [FAILED] Took 13.30 seconds ============================
Please help me how to solve this!
Many thanks in advance
Please share the content of your platformio.ini as preformatted-text.
Okay
; Redirecting...
must exist or when custom json board require be variant of existed board
There is nothing unusual in your platformio.ini
It looks like your platform / framework installation has been broken.
- Close VS Code
- delete
C:\Users\<username>\.platformio\platforms\espressif32
- delete
C:\Users\<username>\.platformio\packages\framework-arduinoespressif32
- Start VS Code
- Wait until PlatformIO finished all tasks (reinstalling the platform / framework)
- Try to build the project again
