ESP32-C6 DevKit M-1 error about Arduino not supported
I am trying to move an existing project form an ESP8266 to the ESP32-C6. According to Espressif, their Arduino core supports the C6 (GitHub - espressif/arduino-esp32: Arduino core for the ESP32) however when I try to compile with Platform IO I get an error:
Error: This board doesn’t support arduino framework!
My ini file has this set of options for this board:
board = esp32-c6-devkitm-1
Am I missing something obvious here? Here is the ‘full’ but rather short build log:
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32-c6-devkitm-1.html
PLATFORM: Espressif 32 (6.6.0) > Espressif ESP32-C6-DevKitM-1
HARDWARE: ESP32C6 160MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
 - framework-arduinoespressif32 @ 3.20014.231204 (2.0.14)
 - tool-mkfatfs @ 2.0.1
Error: This board doesn't support arduino framework!
The only supported framework seems to be espidf - not arduino - see here
Right but it sounds like Espressif has a different opinion on that :sweat_smile: so it does seem to be possible?
Obviously pio has an opposite opinion :wink:. May be that shows an alternative
The ESP32-C6 requires the Arduino core 3.x which is unfortunately not officially available for PlatformIO and may never be available - See Support Arduino ESP32 v3.0 based on ESP-IDF v5.1 · Issue #1225 · platformio/platform-espressif32 · GitHub
But there is the community platform “pioarduino” to fill this gap.
Give it a try.
Huh, I’m trying to parse what that means. Is Espressif saying they pull PlatformIO support in general, or only for Arduino? Would be a bummer if their ESP IDF platform does not support PlatformIO either. That might actually mean that for future projects I’d switch to a different microprocessor.
Thanks for the info though. I will look through my dependencies and check how many of them actually have ESP IDF version / support that. I wanted to look into switching over to that for a while now but never wanted to spend the time. Maybe this is a good incentive.
If it turns out to be too complicated, I will look into pioarduino.
Thanks!
—Michael
I had the same issue. Then I found this: XIAO ESP32C6 with PlatformIO | Seeed Studio Wiki
This solved the issue for me and I am able to build and deploy to my SEEED XIAO ESP32-C6 board. My platformio.ini looks like this (sorry for the image, but I am allowed to have only 2 links in a post :expressionless:
