I’ve written some code to play with led’s. Here’s my platformio.ini:
[env:esp32]
mike-matera/ArduinoSTL@^1.3.3
adafruit/Adafruit NeoPixel@^1.12.0
[env:uno]
board = uno
The uno environment compiles, but the esp32 environment doesn’t due to hundreds of errors compiling the ArduinoSTL library. This is a typical example:
.pio/libdeps/esp32/ArduinoSTL/src/cstdlib:27:10: error: ‘::abort’ has not been declared
It seems that platformio is picking up the cstdlib from the ArduinoSTL includes folder, rather than taking the correct one from the board.
Now, I know this can work, because I loaded the code into the ArduinoIDE, and it compiles fine for the esp32. The code still doesn’t work, but that’s more down to my lack of experience with the esp32.
I found this related post while researching the problem, but there’s no solution.
Any advice would be great. I wanna use vscode and platformio, rather than the retarded editor the ArduinoIDE gives you.
