Greetings,
i just installed the ArduinoSTL library 1.1.0 in order to utilize some of its functions. However, when i build my project i get numerous errors in the following files (Apart from the ArduinoSTL.h file, none of these are included in my project): algorithm, cmath, cstdlib, memory and new.
To be more specific it’s 74 errors, out of which a majority of them are reported as undeclared variables in the library. I could give more detailed info if needed.
My project is for a Due board (SAM).
I have no idea to proceed from here. Any help is appreciated!
Can you provide your platformio.ini
and a simple main.cpp
so we can reproduce the problem?
Thanks for your quick reply.
platformio.ini contains:
[env:due]
platform = atmelsam
board = dueUSB
arduino-libraries/LiquidCrystal@^1.0.7
mike-matera/ArduinoSTL@^1.1.0
monitor_speed = 1200
(I’m using the native USB port, because the programming port needs repairing).
Here’s a minimal reproducible example of main.cpp that yields the errors:
#include <ArduinoSTL.h>
Wow, that’s a hard one.
There is clearly a mixup of header files provides by ArduinoSTL and the compiler itself, e.g. cstdlib
exists both in ArduinoSTL (.pio\libdeps\due\ArduinoSTL\src
) and in the compiler directories (C:\Users\xxx\.platformio\packages\toolchain-gccarmnoneeabi@1.70201.0\arm-none-eabi\include\c++\7.2.1
stdlib.h
(from the compiler directory) then includes cstdlib
and processes the one from ArduinoSTL instead of from the same compiler directory. This is probably wrong.
I’m not sure yet how to resolve it…
I appreciate the feedback, since i couldn’t have figured this out on my own… I also tried the StandardCplusplus library with similar errors, fyi.
If a fix needs time, i’ll have to consider other options since i need some of the stl functions… Are there any alternatives to ArduinoSTL on top of your head?
What exactly is the ARM GCC compiler toolchain missing that you need?
