ESP-Prog debugger issue. No visible error. (Ubuntu)
Oooh right, you’re a mod. Got confused there for a sec! Thanks for bumping me up a step. I edited the above message with the output of the execution.
I’ve bumped up the user level.
Sorry must be two separate commands, the latter on in the GDB shell. First
 ~/.platformio/packages/toolchain-xtensa32/bin/xtensa-esp32-elf-gdb .pio/build/esp-wrover-kit/firmware.elf
and then in GDB
target extended-remote localhost:3333
You can then also try
monitor init
load
monitor reset halt
break setup
continue
Also what exact distributation and version are you using? If this still doesn’t work I’ll try to reproduce it in a VM. It is weird that OpenOCD and GDB seem to work on their own but not in conjuction with PlatformIO and VSCode.
Oh, I’m stupid. Sorry I haven’t slept much xD
Here:
(base) ab@desktop:~/Documents/PlatformIO/Projects/210330-011607-arduino-blink$  ~/.platformio/packages/toolchain-xtensa32/bin/xtensa-esp32-elf-gdb .pio/build/esp-wrover-kit/firmware.elf
GNU gdb (crosstool-NG crosstool-ng-1.22.0-97-gc752ad5) 7.10
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=x86_64-build_pc-linux-gnu --target=xtensa-esp32-elf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from .pio/build/esp-wrover-kit/firmware.elf...done.
(gdb) target extended-remote localhost:3333
localhost:3333: Connection timed out.
(gdb)
Timed out, it seems.
Guessing those other commands are for when it connects, but I ran them anyway.
(gdb) monitor init
"monitor" command not supported by this target.
(gdb) load
You can't do that when your target is `exec'
(gdb) monitor reset halt
(gdb) break setup
ontinueBreakpoint 1 at 0x400d0c5c: file src/Blink.cpp, line 13.
(gdb) continue
The program is not being run.
(gdb)
It’s Kubuntu.
(base) ab@desktop:~$ uname -a
Linux desktop 5.4.0-70-generic #78-Ubuntu SMP Fri Mar 19 13:29:52 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
It doesn’t seem to get a connection to the OpenOCD server. Is the
command running in a seperate shell?
No, I’m running it all in one shell within vscode’s integrated console.
Can open a normal system shell in parallel to start OpenOCD and then GDB in the VSCode shell?
I’ll try
Were I supposed to run
~/.platformio/packages/tool-openocd-esp32/bin/openocd -s ~/.platformio/packages/tool-openocd-esp32/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp32-wrover.cfg -c "adapter_khz 500"
and not
by the way?
Just so I don’t misunderstand.
That seems to have done something:
(base) ab@desktop:~$ ~/.platformio/packages/tool-openocd-esp32/bin/openocd -s ~/.platformio/packages/tool-openocd-esp32/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp32-wrover.cfg -c "adapter_khz 500"
Open On-Chip Debugger  v0.10.0-esp32-20201202 (2020-12-02-17:38)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp32-wrover.cfg is deprecated, and may be removed in a future release.
         If your board is ESP32-WROVER-KIT, use board/esp32-wrover-kit-1.8v.cfg instead.
Info : FreeRTOS creation
adapter speed: 500 kHz
Info : clock speed 500 kHz
Info : esp32.cpu0: Detected debug stubs @ 3ffc09b0
Info : accepting 'gdb' connection on tcp/3333
Warn : No symbols for FreeRTOS!
Info : esp32.cpu0: Target halted, PC=0x400E93EA, debug_reason=00000000
Info : Set GDB target to 'esp32.cpu0'
Info : esp32.cpu1: Target halted, PC=0x400E93EA, debug_reason=00000000
Info : esp32.cpu0: Target halted, PC=0x40091856, debug_reason=00000001
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 49 KB
Info : Flash mapping 1: 0x20018 -> 0x400d0018, 101 KB
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.irom' size 104 KB
Info : Using flash bank 'esp32.cpu0.drom' size 52 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
Warn : negative reply, retrying
Info : dropped 'gdb' connection
(base) ab@desktop:~/Documents/PlatformIO/Projects/210330-011607-arduino-blink$ gdb
GNU gdb (Ubuntu 9.2-0ubuntu1~20.04) 9.2
Copyright (C) 2020 Free Software Foundation, Inc.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Remote debugging using localhost:3333
Ignoring packet error, continuing...
warning: unrecognized item "timeout" in "qSupported" response
Remote replied unexpectedly to 'vMustReplyEmpty': PacketSize=4000;qXfer:memory-map:read+;qXfer:features:read-;qXfer:threads:read+;QStartNoAckMode+;vContSupported+
(gdb)
Ah but you used the system’s GDB here and not the xtensa-esp32-elf-gdb here. Should have been
with the steps
In any case, this already shows that OpenOCD can accept GDB connections and works okay… I’ll try to reproduce this.
Sorry, here’s what I think you meant now.
In vscode:
(gdb)
(gdb)
Bogus trace status reply from target: OK
(gdb)
external shell:
Info : esp32.cpu0: Target halted, PC=0x400E93EA, debug_reason=00000001
And thank you for troubleshooting. I’m obviously a bit oblivious to what is going on here, but these people seem to have stumbled upon something similar debugging problem: unrecognized item "timeout" in "qSupported" response - ESP32 Forum
This usually only appears when the wrong GDB version is used with OpenOCD (or there’s a bug in OpenOCD). But I’ll see if I can try to reproduce that in my Kubuntu virtual machine.
Just for reference, you again open a CLI and execute
pio system info
pio debug
pio debug --interface=gdb -x .pioinit
(per docs) and post the output?
Sorry it took some time
(base) ab@desktop:~/Documents/PlatformIO/Projects/210330-011607-arduino-blink$ pio system info
b -x .pioinit--------------------------  --------------------------------------------
PlatformIO Core             5.2.0a3
Python                      3.8.5-final.0
System Type                 linux_x86_64
Platform                    Linux-5.4.0-70-generic-x86_64-with-glibc2.29
File System Encoding        utf-8
Locale Encoding             UTF-8
PlatformIO Core Directory   /home/ab/.platformio
PlatformIO Core Executable  /home/ab/.platformio/penv/bin/platformio
Python Executable           /home/ab/.platformio/penv/bin/python
Global Libraries            0
Development Platforms       1
Tools & Toolchains          9
(base) ab@desktop:~/Documents/PlatformIO/Projects/210330-011607-arduino-blink$ pio debug
Processing esp-wrover-kit (platform: espressif32; framework: arduino; board: esp-wrover-kit)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp-wrover-kit.html
PLATFORM: Espressif 32 (3.2.0) > Espressif ESP-WROVER-KIT
DEBUG: Current (custom) On-board (ftdi) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
 - framework-arduinoespressif32 3.10006.210326 (1.0.6)
 - tool-esptoolpy 1.30000.201119 (3.0.0)
 - tool-openocd-esp32 2.1000.20201202 (10.0)
 - toolchain-xtensa32 2.50200.97 (5.2.0)
Found 28 compatible libraries
Building in debug mode
Retrieving maximum program size .pio/build/esp-wrover-kit/firmware.elf
Checking size .pio/build/esp-wrover-kit/firmware.elf
RAM:   [          ]   4.1% (used 13480 bytes from 327680 bytes)
Flash: [==        ]  15.9% (used 208334 bytes from 1310720 bytes)
=================================================================================== [SUCCESS] Took 0.73 seconds ===================================================================================
(base) ab@desktop:~/Documents/PlatformIO/Projects/210330-011607-arduino-blink$ pio debug --interface=gdb -x .pioinit
Reading symbols from /home/ab/Documents/PlatformIO/Projects/210330-011607-arduino-blink/.pio/build/esp-wrover-kit/firmware.elf...done.
PlatformIO: debug_tool = custom
My bad, can you for a test, change revert this change
And rerun the last debug command?
Otherwise it will of course run into a timeout because it doesn’t attempt to start OpenOCD.
Do you mean the reverse? I had
debug_tool = custom
debug_port = localhost:3333
already.
If so, here’s the output:
Global Libraries            0
DEBUG: Current (esp-prog) On-board (ftdi) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
Compiling .pio/build/esp-wrover-kit/src/Blink.cpp.o
Generating partitions .pio/build/esp-wrover-kit/partitions.bin
Archiving .pio/build/esp-wrover-kit/libFrameworkArduinoVariant.a
Indexing .pio/build/esp-wrover-kit/libFrameworkArduinoVariant.a
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/Esp.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/IPAddress.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/IPv6Address.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/MD5Builder.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/Print.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/Stream.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/StreamString.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/WMath.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/WString.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/base64.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/cbuf.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-adc.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-bt.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-cpu.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-dac.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-gpio.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-i2c.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-ledc.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-log.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-matrix.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-misc.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-psram.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-rmt.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-sigmadelta.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-spi.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-time.c.o
/home/ab/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-spi.c: In function 'spiTransferBytesNL':
/home/ab/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-spi.c:922:39: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
                 uint8_t * last_out8 = &result[c_longs-1];
/home/ab/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-spi.c:923:40: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
                 uint8_t * last_data8 = &last_data;
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-timer.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-touch.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/esp32-hal-uart.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/libb64/cdecode.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/libb64/cencode.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/main.cpp.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/stdlib_noniso.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/wiring_pulse.c.o
Compiling .pio/build/esp-wrover-kit/FrameworkArduino/wiring_shift.c.o
Archiving .pio/build/esp-wrover-kit/libFrameworkArduino.a
Indexing .pio/build/esp-wrover-kit/libFrameworkArduino.a
Linking .pio/build/esp-wrover-kit/firmware.elf
Building .pio/build/esp-wrover-kit/firmware.bin
esptool.py v3.0
=================================================================================== [SUCCESS] Took 4.65 seconds ===================================================================================
PlatformIO: debug_tool = esp-prog
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 5000 kHz
0x400e93ea in heap_caps_match (heap=0x0, caps=1)
    at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/heap/heap_caps.c:54
54      /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/heap/heap_caps.c: No such file or directory.
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Info : esp32.cpu0: Target halted, PC=0x500000CF, debug_reason=00000000
Info : esp32.cpu0: Target halted, PC=0x40000400, debug_reason=00000000
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Info : esp32.cpu1: Target halted, PC=0x40000400, debug_reason=00000000
** Programming Started **
** Programming Finished **
** Verify Started **
** Verified OK **
** Verified OK **
** Verified OK **
** Verified OK **
** Verified OK **
** Verified OK **
** Verified OK **
** Verified OK **
Temporary breakpoint 1 at 0x400d0c5c: file src/Blink.cpp, line 13.
(gdb) PlatformIO: Resume the execution to `debug_init_break = tbreak setup`
PlatformIO: More configuration options -> http://bit.ly/pio-debug
Continuing.
Note: automatically using hardware breakpoints for read-only addresses.
Info : esp32.cpu0: Target halted, PC=0x400E5B0F, debug_reason=00000000
Info : esp32.cpu1: Target halted, PC=0x400D0C5C, debug_reason=00000001
[New Thread 1073465264]
[New Thread 1073463852]
[New Thread 1073467960]
[New Thread 1073456088]
[New Thread 1073445228]
[New Thread 1073454676]
[New Thread 1073462440]
[Switching to Thread 1073447000]
Temporary breakpoint 1, setup () at src/Blink.cpp:13
13      {
(gdb)
Edit: Oh, I get it. Read your post wrong, but did what you asked for.
I see. Debugging fully works there. It flashes the firmware, sets up breakpoints, lets the chip run, and hits the breakpoint in setup(), then drops you into the GDB shell. You can e.g. type bt for a backtrace, info registers etc.
Now why this doesn’t work in VSCode is mysterious. I’ll hopefully see that in my repro.
Yeah, it steps through the code fine.
Well, I think you narrowed it down pretty well. Probably something with the vscode install or something then? Gonna try and do a clean install of vscode in a bit.
This may be a stupid question but, are you 100% sure you’ve selected your project in the project environment switcher and in the debug configuration selection?
grafik
The “skip Pre-Debug” vs the normal targets also don’t make a difference?
I’ve tried both and read up on the skip pre-debug. Apparently it just skips building stuff and goes straight to debugging.
Just tried this, and it’s doing the same thing.
And here’s what happens if I run the skip one. Just adds it to the dropdown menu on console and doesn’t do anything in terminal.
