I installed latest version of PlatformIO in Termux through pip install platformio. Everything goes well and I install platform atmelavr. But when I type pio run it gives me this error in the screenshot
Please can anyone help me fix the issue?
I’ve encountered a similar issue:
system: Manjaro ARM on aarch64
IDE: vscode insiders
platform: titiva
board: lptm4c1294ncpdt
framework: none (same error with libopencm3)
I’ve reinstalled gcc and verified that it exists but the error persists.
[rumlyne@pbp embsys]$ pio platform install titiva --with-package tool-openocd
Platform Manager: Installing titiva
Platform Manager: titiva @ 3.0.0 has been installed!
Tool Manager: Installing toolchain-gccarmnoneeabi @ >=1.40803.0,<1.40805.0
Tool Manager: Warning! More than one package has been found by toolchain-gccarmnoneeabi @ >=1.40803.0,<1.40805.0 requirements:
Executing task in folder embsys: platformio run <
CONFIGURATION: Redirecting...
PLATFORM: TI TIVA (3.0.0) > TI LaunchPad (Tiva C) w/ tm4c129 (120MHz)
HARDWARE: LPTM4C1294NCPDT 120MHz, 256KB RAM, 1MB Flash
DEBUG: Current (ti-icdi) On-board (ti-icdi)
arm-none-eabi-gcc is exactly where it should be.
Oh this is interesting. My package (which is for Windows) was picked over a PlatformIO provided lib. So basically the same as in Toolchain-gccarmnoneeabi for aarch64 - #7 by dolfandringa. Try the recommendations there.
Thx for the fast reply!
Before the reinstallation I had v1.40803 installed which resulted in the same error.
Still I’ll try the proposed solution in the evening and let you know how it went
Jup, adding
platform_packages = toolchain-gccarmnoneeabi@~1.90301.0
to platformio.ini did the trick.
Now I’m getting:
arm-none-eabi-as: unrecognized option ‘-x’
but I’ll figure that out.
Thx!
If I remember correctly, this is an error regarding assembler files (.S and .s), I think the files must be named .S so that arm-none-eabi-gcc is invoked instead of as, so check all assembler files for an uppercase S.
