Im trying to switch from the arduino IDE to the PlatformIO extension for Visual Studio Code, but im having issues with libraries. I believe ive found all the libraries i have listed in my program, added them to the “platformio.ini” file but im getting errors related to them. Ive created a new project file and was going to make a simple example to upload but after adding the code to platformio.ini i decided to see if i still get an error and i am, hence why its a bare main.cpp.
Platformio.ini
[env:megaatmega2560]
board = megaatmega2560
lib_deps=
adafruit/Adafruit HX8357 Library @ ^1.1.10
adafruit/MAX6675 library @ ^1.1.0
adafruit/Adafruit GFX Library @ ^1.10.4
adafruit/Adafruit BusIO @ ^1.7.2
This is the main.cpp. I havent actually requested to include the libraries yet
This is the error message im getting in the terminal
> Executing task in folder Test: C:\Users\mannf\.platformio\penv\Scripts\pio.exe run <
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR (3.1.0) > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
- framework-arduino-avr 5.1.0
Library Manager: Installing adafruit/Adafruit HX8357 Library @ ^1.1.10
Library Manager: Adafruit HX8357 Library @ 1.1.10 has been installed!
Library Manager: Installing dependencies...
Library Manager: Installing Adafruit STMPE610
Library Manager: Adafruit STMPE610 @ 1.1.2 has been installed!
Library Manager: Installing Adafruit GFX Library
Library Manager: Adafruit GFX Library @ 1.10.4 has been installed!
Library Manager: Installing Adafruit BusIO
Library Manager: Adafruit BusIO @ 1.7.2 has been installed!
Library Manager: Installing Adafruit TouchScreen
Library Manager: Adafruit TouchScreen @ 1.1.1 has been installed!
Library Manager: Installing SD
Library Manager: Warning! More than one package has been found by SD requirements:
- adafruit/SD @ 0.0.0-alpha+sha.041f788250
- arduino-libraries/SD @ 1.2.4
Library Manager: Please specify detailed REQUIREMENTS using package owner and version (showed above) to avoid name conflicts
Library Manager: SD @ 0.0.0-alpha+sha.041f788250 has been installed!
Library Manager: Installing adafruit/MAX6675 library @ ^1.1.0
Library Manager: MAX6675 library @ 1.1.0 has been installed!
Library Manager: Installing LiquidCrystal
Library Manager: Warning! More than one package has been found by LiquidCrystal requirements:
- bitbucket-fmalpartida/LiquidCrystal @ 1.5.0
- arduino-libraries/LiquidCrystal @ 1.0.7
Library Manager: LiquidCrystal @ 1.5.0 has been installed!
Library Manager: Adafruit GFX Library @ 1.10.4 is already installed
Library Manager: Adafruit BusIO @ 1.7.2 is already installed
Found 13 compatible libraries
|-- <Adafruit HX8357 Library> 1.1.10
| |-- <Adafruit GFX Library> 1.10.4
| | |-- <Adafruit BusIO> 1.7.2
|-- <MAX6675 library> 1.1.0
Compiling .pio\build\megaatmega2560\src\main.cpp.o
Compiling .pio\build\megaatmega2560\lib187\Adafruit BusIO\Adafruit_BusIO_Register.cpp.o
Compiling .pio\build\megaatmega2560\lib187\Adafruit BusIO\Adafruit_I2CDevice.cpp.o
Compiling .pio\build\megaatmega2560\lib187\Adafruit BusIO\Adafruit_SPIDevice.cpp.o
Compiling .pio\build\megaatmega2560\libb95\Adafruit GFX Library\Adafruit_GFX.cpp.o
Compiling .pio\build\megaatmega2560\libb95\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o
Compiling .pio\build\megaatmega2560\libb95\Adafruit GFX Library\Adafruit_SPITFT.cpp.o
In file included from .pio\libdeps\megaatmega2560\Adafruit BusIO/Adafruit_BusIO_Register.h:1:0,
from .pio\libdeps\megaatmega2560\Adafruit BusIO\Adafruit_BusIO_Register.cpp:1:
.pio\libdeps\megaatmega2560\Adafruit BusIO/Adafruit_I2CDevice.h:1:18: fatal error: Wire.h: No such file or directory
* Looking for Wire.h dependency? Check our library registry!
* CLI > platformio lib search "header:Wire.h"
* Web > https://platformio.org/lib/search?query=header:Wire.h
compilation terminated.
In file included from .pio\libdeps\megaatmega2560\Adafruit BusIO\Adafruit_SPIDevice.cpp:1:0:
Compiling .pio\build\megaatmega2560\libb95\Adafruit GFX Library\glcdfont.c.o
.pio\libdeps\megaatmega2560\Adafruit BusIO/Adafruit_SPIDevice.h:1:17: fatal error: SPI.h: No such file or directory
* Looking for SPI.h dependency? Check our library registry!
* CLI > platformio lib search "header:SPI.h"
* Web > https://platformio.org/lib/search?query=header:SPI.h
In file included from .pio\libdeps\megaatmega2560\Adafruit BusIO\Adafruit_I2CDevice.cpp:1:0:
*** [.pio\build\megaatmega2560\lib187\Adafruit BusIO\Adafruit_SPIDevice.cpp.o] Error 1
*** [.pio\build\megaatmega2560\lib187\Adafruit BusIO\Adafruit_BusIO_Register.cpp.o] Error 1
*** [.pio\build\megaatmega2560\lib187\Adafruit BusIO\Adafruit_I2CDevice.cpp.o] Error 1
In file included from .pio\libdeps\megaatmega2560\Adafruit GFX Library\Adafruit_GrayOLED.h:30:0,
from .pio\libdeps\megaatmega2560\Adafruit GFX Library\Adafruit_GrayOLED.cpp:20:
*** [.pio\build\megaatmega2560\libb95\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o] Error 1
In file included from .pio\libdeps\megaatmega2560\Adafruit GFX Library\Adafruit_SPITFT.cpp:36:0:
.pio\libdeps\megaatmega2560\Adafruit GFX Library\Adafruit_SPITFT.h:26:17: fatal error: SPI.h: No such file or directory
*** [.pio\build\megaatmega2560\libb95\Adafruit GFX Library\Adafruit_SPITFT.cpp.o] Error 1
============================================================================================== [FAILED] Took 10.44 seconds ==============================================================================================
The terminal process "C:\Users\mannf\.platformio\penv\Scripts\pio.exe 'run'" terminated with exit code: 1.
Im a little confused with the above. I found the following post
which refers to one of the libraries im having issues with “Wire.h” but when i wrote “Wire” in the platformio.ini file as suggested in the post its still not removing the error. I also cant find one file called “Wire” when i search in the libraries.
