I am using a ESP-WROVER-KIT-VB and the docs say that it " has on-board debug probe and IS READY for debugging. You don’t need to use/buy external debug probe", which is why I bought it.
The docs also say “You will need to install debug tool drivers depending on your system”, so I followed the ESP-WROVER-KIT V4.1 Getting Started Guide and Installation Step by Step.
I saw no error messages during install, but when I build and try to debug, I get
Reading symbols from g:_PlatformIo\ESP-WROVER-KIT-VB\NTP_demo.pio\build\esp-wrover-kit\firmware.elf…
done.
PlatformIO: debug_tool = ftdi
Open On-Chip Debugger v0.10.0-esp32-20190708 (2019-07-08-11:04)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Error: libusb_open() failed with LIBUSB_ERROR_NOT_FOUND
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 6010, description ‘’, serial '’ at bus location ‘*’Warn : Flash driver of esp32.flash does not support free_driver_priv()
Warn : Flash driver of irom does not support free_driver_priv()
Warn : Flash driver of drom does not support free_driver_priv()
Remote communication error. Target disconnected.: No error.
Does anyone know how I can get debuggin working? Thanks in advance
