Hi Max,
Thank you so much for your suggestions. I successfully set it up as you suggested. Now the debug board is detected by GDB. You are so awesome! It almost works right until the first breakpoint. It gets stuck before the first breakpoint. It won’t allow me to continue or step over. I did not get any warning or error messages.
Would you know why it can neither stop correctly to display my counter’s value nor allow me to continue or step over?
**Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400 **
Temporary breakpoint 1 at 0x400d0c00: file src/main.cpp, line 8.
PlatformIO: Resume the execution to debug_init_break = tbreak setup
PlatformIO: More configuration options → Redirecting...
Note: automatically using hardware breakpoints for read-only addresses.
Below is how I used the commands suggested by you to make PIO detect the ESP debug board.
show the output of lsusb
(ttyUSB0 is ESP32 Development board. ttyUSB1 or ttyUSB2 is ESP Debug Board. Arduino IDE is able to detect the presence of the ESP Debug Board)
michael@michael-Inspiron-5551:~/Desktop$ ls -l /dev/ttyUSB*
crw-rw---- 1 root dialout 188, 0 May 21 17:51 /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 1 May 21 18:27 /dev/ttyUSB1
crw-rw---- 1 root dialout 188, 2 May 21 18:27 /dev/ttyUSB2
michael@michael-Inspiron-5551:~/Desktop$ sudo usermod -a -G dialout michael
[sudo] password for michael:
michael@michael-Inspiron-5551:~/Desktop$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 008: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 013: ID 0403:6010 Future Technology Devices International, Ltd FT2232C/D/H Dual UART/FIFO IC
Bus 001 Device 006: ID 8087:07dc Intel Corp. CP2102N USB to UART Bridge Controller
Bus 001 Device 004: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 003: ID 0bda:5683 Realtek Semiconductor Corp. Integrated_Webcam_HD
Bus 001 Device 009: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
Bus 001 Device 007: ID 045e:0040 Microsoft Corp. Wheel Mouse Optical
Bus 001 Device 005: ID 413c:2003 Dell Computer Corp. Keyboard
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device List
Error: unable to open ftdi device with vid 0403, pid 6010,… (It seems that PIO can detect the debug device. The debug device has the correct vid and pid numbers.)
michael@michael-Inspiron-5551:~/Desktop$ platformio device list
/dev/ttyS0
Hardware ID: PNP0501
Description: ttyS0
/dev/ttyUSB2
Hardware ID: USB VID:PID=0403:6010 LOCATION=1-4.3:1.1
Description: Dual RS232-HS
/dev/ttyUSB1
Hardware ID: USB VID:PID=0403:6010 LOCATION=1-4.3:1.0
/dev/ttyUSB0
Hardware ID: USB VID:PID=10C4:EA60 SER=14d7e5c5059de711b342ef4fb5604391 LOCATION=1-2
Description: CP2102N USB to UART Bridge Controller
Installed the udev rules
It installed this driver which seems to match the esp debug board.
Original FT2232 VID:PID
ATTRS{idVendor}==“0403”, ATTRS{idProduct}==“6010”, MODE=“0666”, ENV{ID_MM_DEVICE_IGNORE}=“1”, ENV{ID_MM_PORT_IGNORE}=“1”
michael@michael-Inspiron-5551:~/Desktop$ curl -fsSL https://raw.githubusercontent.com/platformio/platformio-core/master/scripts/99-platformio-udev.rules | sudo tee /etc/udev/rules.d/99-platformio-udev.rules
# Copyright (c) 2014-present PlatformIO <contact@platformio.org>
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
# INSTALLATION
# Please visit > https://docs.platformio.org/en/latest/faq.html#platformio-udev-rules
# Boards
# CP210X USB UART
ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea60", MODE:="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# FT231XS USB UART
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6015", MODE:="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Prolific Technology, Inc. PL2303 Serial Port
ATTRS{idVendor}=="067b", ATTRS{idProduct}=="2303", MODE:="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# QinHeng Electronics HL-340 USB-Serial adapter
ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", MODE:="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Arduino boards
ATTRS{idVendor}=="2341", ATTRS{idProduct}=="[08][02]*", MODE:="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
ATTRS{idVendor}=="2a03", ATTRS{idProduct}=="[08][02]*", MODE:="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Arduino SAM-BA
ATTRS{idVendor}=="03eb", ATTRS{idProduct}=="6124", MODE:="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{MTP_NO_PROBE}="1"
# Digistump boards
ATTRS{idVendor}=="16d0", ATTRS{idProduct}=="0753", MODE:="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Maple with DFU
ATTRS{idVendor}=="1eaf", ATTRS{idProduct}=="000[34]", MODE:="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# USBtiny
ATTRS{idProduct}=="0c9f", ATTRS{idVendor}=="1781", MODE:="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# USBasp V2.0
ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="05dc", MODE:="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Teensy boards
ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789B]?", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789A]?", ENV{MTP_NO_PROBE}="1"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789ABCD]?", MODE:="0666"
KERNEL=="ttyACM*", ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789B]?", MODE:="0666"
#TI Stellaris Launchpad
ATTRS{idVendor}=="1cbe", ATTRS{idProduct}=="00fd", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
#TI MSP430 Launchpad
ATTRS{idVendor}=="0451", ATTRS{idProduct}=="f432", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
#GD32V DFU Bootloader
ATTRS{idVendor}=="28e9", ATTRS{idProduct}=="0189", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Debuggers
# Black Magic Probe
SUBSYSTEM=="tty", ATTRS{interface}=="Black Magic GDB Server", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
SUBSYSTEM=="tty", ATTRS{interface}=="Black Magic UART Port", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# opendous and estick
ATTRS{idVendor}=="03eb", ATTRS{idProduct}=="204f", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Original FT232/FT245 VID:PID
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Original FT2232 VID:PID
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6010", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Original FT4232 VID:PID
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6011", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Original FT232H VID:PID
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6014", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# DISTORTEC JTAG-lock-pick Tiny 2
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="8220", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# TUMPA, TUMPA Lite
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="8a98", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="8a99", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# XDS100v2
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="a6d0", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Xverve Signalyzer Tool (DT-USB-ST), Signalyzer LITE (DT-USB-SLITE)
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="bca0", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="bca1", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# TI/Luminary Stellaris Evaluation Board FTDI (several)
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="bcd9", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# TI/Luminary Stellaris In-Circuit Debug Interface FTDI (ICDI) Board
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="bcda", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# egnite Turtelizer 2
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="bdc8", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Section5 ICEbear
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="c140", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="c141", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Amontec JTAGkey and JTAGkey-tiny
ATTRS{idVendor}=="0403", ATTRS{idProduct}=="cff8", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# TI ICDI
ATTRS{idVendor}=="0451", ATTRS{idProduct}=="c32a", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# STLink probes
ATTRS{idVendor}=="0483", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Hilscher NXHX Boards
ATTRS{idVendor}=="0640", ATTRS{idProduct}=="0028", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Hitex probes
ATTRS{idVendor}=="0640", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Altera USB Blaster
ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6001", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Amontec JTAGkey-HiSpeed
ATTRS{idVendor}=="0fbb", ATTRS{idProduct}=="1000", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# SEGGER J-Link
ATTRS{idVendor}=="1366", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Raisonance RLink
ATTRS{idVendor}=="138e", ATTRS{idProduct}=="9000", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Debug Board for Neo1973
ATTRS{idVendor}=="1457", ATTRS{idProduct}=="5118", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Olimex probes
ATTRS{idVendor}=="15ba", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# USBprog with OpenOCD firmware
ATTRS{idVendor}=="1781", ATTRS{idProduct}=="0c63", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# TI/Luminary Stellaris In-Circuit Debug Interface (ICDI) Board
# Marvell Sheevaplug
ATTRS{idVendor}=="9e88", ATTRS{idProduct}=="9e8f", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# Keil Software, Inc. ULink
ATTRS{idVendor}=="c251", ATTRS{idProduct}=="2710", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
# CMSIS-DAP compatible adapters
ATTRS{product}=="*CMSIS-DAP*", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1", ENV{ID_MM_PORT_IGNORE}="1"
add own “username” to the “dialout” group (It works for Arduino IDE)
michael@michael-Inspiron-5551:~/Desktop$ sudo service udev restart
michael@michael-Inspiron-5551:~/Desktop$ sudo usermod -a -G plugdev michael
Close the VS Code. Unplug and plug back the ESP32 Debug Board (required to be detected). Re-open the VS Code. This time Platform IO found the correct device.
Problem: It could not reach the first breakpoint.
Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
Yes, I have the tbreak setup in my platform.ini file. I don’t know why it halts. I cannot continue to run or step over.
upload_port = /dev/ttyUSB0
monitor_port = /dev/ttyUSB0
monitor_speed = 9600
debug_tool = esp-prog
PLATFORM: Espressif 32 1.12.1 > Espressif ESP32 Dev Module
Found 26 compatible libraries
Building in debug mode
Retrieving maximum program size .pio/build/esp32dev/firmware.elf
Checking size .pio/build/esp32dev/firmware.elf
RAM: [ ] 4.7% (used 15436 bytes from 327680 bytes)
Flash: [== ] 16.5% (used 216777 bytes from 1310720 bytes)
========================= [SUCCESS] Took 3.27 seconds =========================
Reading symbols from /home/michael/Documents/PlatformIO/Projects/Serial_Monitor_test/.pio/build/esp32dev/firmware.elf...
done.
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.10.0-esp32-20190708 (2019-07-08-11:03)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Error: No symbols for FreeRTOS
Info : Target halted. PRO_CPU: PC=0x400093BA (active) APP_CPU: PC=0x400076DD
Info : Target halted. PRO_CPU: PC=0x400916EE (active) APP_CPU: PC=0x400076DD
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 45 KB
Info : Flash mapping 1: 0x20018 -> 0x400d0018, 100 KB
Info : Auto-detected flash size 4096 KB
Info : Using flash size 4096 KB
Info : Using flash size 104 KB
Info : Using flash size 48 KB
0x400093ba in ?? ()
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x5F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x5F).
Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
Info : esp32: Core 0 was reset (pwrstat=0x1F, after clear 0x0F).
** Programming Started **
auto erase enabled
auto erase enabled
Info : Target halted. PRO_CPU: PC=0x400916EE (active) APP_CPU: PC=0x40000400
wrote 16384 bytes from file /home/michael/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin in 0.873921s (18.308 KiB/s)
** Programming Finished **
** Verify Started **
read 15872 bytes from file /home/michael/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin and flash bank 0 at offset 0x00001000 in 0.317131s (48.876 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 4096 bytes from file /home/michael/Documents/PlatformIO/Projects/Serial_Monitor_test/.pio/build/esp32dev/partitions.bin in 0.683615s (5.851 KiB/s)
read 3072 bytes from file /home/michael/Documents/PlatformIO/Projects/Serial_Monitor_test/.pio/build/esp32dev/partitions.bin and flash bank 0 at offset 0x00008000 in 0.288191s (10.410 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F).
auto erase enabled
auto erase enabled
wrote 8192 bytes from file /home/michael/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin in 0.719366s (11.121 KiB/s)
read 8192 bytes from file /home/michael/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin and flash bank 0 at offset 0x0000e000 in 0.301490s (26.535 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 217088 bytes from file /home/michael/Documents/PlatformIO/Projects/Serial_Monitor_test/.pio/build/esp32dev/firmware.bin in 2.645566s (80.134 KiB/s)
read 216896 bytes from file /home/michael/Documents/PlatformIO/Projects/Serial_Monitor_test/.pio/build/esp32dev/firmware.bin and flash bank 0 at offset 0x00010000 in 1.191141s (177.823 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
PlatformIO: Resume the execution to `debug_init_break = tbreak setup`
PlatformIO: More configuration options -> http://bit.ly/pio-debug
I am running VSCode as snap package.
After everything is done, I am stopped with not working break point. Maybe I will wait to install with the .deb version of VSCode. I am pretty close. Maybe I don’t need to re-install VS Code.
