@maxgerhardt helped me resolve a similar issue in this thread. Also I noticed there was a similar issue link posted earlier and resolved similarly.
I tried the same technique for the uTensor libraries but it has not worked, what could I be doing wrong please? uTensor link
Image below shows where I copied the libraries into and the error I get on compilation.
Two ways:
- Resturcture the library so that
uTensor has two folders: include/ (all .h/.hpp files) and src/ (all .cpp files)
- add the appropiate include flags to the
platformio.ini, e.g.
-I lib/uTensor/core
-I lib/uTensor/loaders
-I lib/uTensor/ops
-I lib/uTensor/util
-I lib/
Hi Max,
Thanks for jumping in again to help. I should have mentioned that I did try that structure /include and /src and moving the files but it gave the same error. Let me try the second method and report here.
Meanwhile I am trying this and will report on that too:
lib_extra_dirs = /Libraries/uTensor/uTensor
Since the cpp files include the file as uTensor/core/tensor.hpp, i.e the full path starting from uTensor, actually the method build_flags = -I lib/ should work.
Hi Max,
I think the build_flags = -I lib/ worked. The âheaders not foundâ type errors donât show up. The image below shows the host of other errors that came up - but I think they are code issues of the original uTensor library?
Thanks for helping. Also if you think this is now a issue with the library is there something you can suggest please
Can you upload your current project so that I can take a look at it? (and execute the âClean Projectâ target so that you donât upload the .pioenvs folder)
Dear Max,
Sorry it took me some time to understand what you meant by âClean Projectâ, .pioenvs folder etc. I couldnât find where to run that command - so Iâve uploaded the project to a git repo but made sure .pioenvs was in the .gitignore file
I hope you are able to access the repo. here> git repo
It was using the an old C++ language version for compiling which doesnât have the features needed by uTensor. Finally it needs -D TARGET_MBED to prevent uTensor_util.cpp from trying to use filesystem function on a microcontroller with no filesystem (though you can add one using e.g. LittleFS). I canât pull-request on your custom-domain github, so see my repository GitHub - maxgerhardt/pio-utensor: Example with PlatformIO and uTensor on an mbed-enabled board..
arm-none-eabi-objcopy -O binary .pioenvs\disco_l476vg\firmware.elf .pioenvs\disco_l476vg\firmware.bin
DATA: [= ] 12.9% (used 16920 bytes from 131072 bytes)
PROGRAM: [=== ] 27.0% (used 282944 bytes from 1048576 bytes)
[SUCCESS] Took 128.48 seconds
Dear Max
This solved it! Thank you so much.
Much to learn from you. I need to understand some of what you did â but I will save the questions for some other time.
Rajesh
