I like to develop code for my rasperry pi. I normally develop arduino code with platformio on my iMAC what is fine. Now triying to open a project for the raspberry pi but get a message cross development not supportet. So i installed platformio on the raspberry successful. But the seams to be only a CLI. An other suggested solution was remote development. Can anyone give me hint how to manage this or a link to the doc where this is discribed. I also have I Linux box would there be a cross development possible,
Thanks a lot for help
Here Raspberry Pi 2 Model B — PlatformIO latest documentation ist noted that it should work. Installing the remote agent on my PI latest OS fails
I was able to run the VSCode GUI on my Rasbpi with no problems at all. Also CodeBlocks runs on it which is supported as an IDE.
Documentation on PIO Remote Development is there.
Though you might also be interested in other solutions like CLion + Remote Development with Pi, might get better performance in this case…
Thanks
to the first answer: I do not have a gui on the PI nor a monitor. I work remote via SSH, I used Geany till now, which works fine in an X-Window on my MAC
to the second answer: I found that but as I wrote “platformio remote agent start” fails to install. Rasbian Buster with latest updates, platformio latest version.
Will checj CLion
Thanks Rainer
Do you have an exact error message?
yes here it si
Command "/usr/bin/python3 -m pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-7_it1qok --no-warn-script-location --no-binary :all: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- setuptools>=40.6.0 wheel "cffi>=1.8,!=1.11.3; platform_python_implementation != 'PyPy'"" failed with error code 1 in None
File "/usr/local/lib/python3.7/dist-packages/platformio/package/manager/core.py", line 88, in inject_contrib_pysite
from OpenSSL import SSL
File "/root/.platformio/packages/contrib-pysite/OpenSSL/__init__.py", line 8, in <module>
File "/root/.platformio/packages/contrib-pysite/OpenSSL/crypto.py", line 12, in <module>
File "/root/.platformio/packages/contrib-pysite/cryptography/x509/__init__.py", line 8, in <module>
File "/root/.platformio/packages/contrib-pysite/cryptography/x509/base.py", line 18, in <module>
File "/root/.platformio/packages/contrib-pysite/cryptography/x509/extensions.py", line 20, in <module>
File "/root/.platformio/packages/contrib-pysite/cryptography/hazmat/primitives/constant_time.py", line 11, in <module>
ImportError: /root/.platformio/packages/contrib-pysite/cryptography/hazmat/bindings/_constant_time.abi3.so: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.7/dist-packages/platformio/__main__.py", line 109, in main
File "/usr/local/lib/python3.7/dist-packages/click/core.py", line 829, in __call__
File "/usr/local/lib/python3.7/dist-packages/click/core.py", line 782, in main
rv = self.invoke(ctx)
File "/usr/local/lib/python3.7/dist-packages/platformio/commands/__init__.py", line 44, in invoke
return super(PlatformioCLI, self).invoke(ctx)
File "/usr/local/lib/python3.7/dist-packages/click/core.py", line 1259, in invoke
File "/usr/local/lib/python3.7/dist-packages/click/core.py", line 1256, in invoke
Command.invoke(self, ctx)
File "/usr/local/lib/python3.7/dist-packages/click/core.py", line 1066, in invoke
File "/usr/local/lib/python3.7/dist-packages/click/core.py", line 610, in invoke
return callback(*args, **kwargs)
File "/usr/local/lib/python3.7/dist-packages/click/decorators.py", line 21, in new_func
File "/usr/local/lib/python3.7/dist-packages/platformio/commands/remote/command.py", line 48, in cli
inject_contrib_pysite(verify_openssl=True)
File "/usr/local/lib/python3.7/dist-packages/platformio/package/manager/core.py", line 90, in inject_contrib_pysite
build_contrib_pysite_deps(get_core_package_dir("contrib-pysite"))
File "/usr/local/lib/python3.7/dist-packages/platformio/package/manager/core.py", line 115, in build_contrib_pysite_deps
dep,
File "/usr/lib/python3.7/subprocess.py", line 347, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/usr/bin/python3', '-m', 'pip', 'install', '--no-compile', '--no-binary', ':all:', '-t', '/root/.platformio/packages/contrib-pysite', 'autobahn == 20.4.3']' returned non-zero exit status 1.
`pip install -U platformio` command
https://docs.platformio.org/page/faq.html
pi@CAN-B:~ $
Your Pi is missing a library. Please upgrade the core (pio upgrade --dev) and install libssl-dev as per Remote agent doesn't start because of native library problems with cryptography library on raspberry pi1 · Issue #3482 · platformio/platformio-core · GitHub.
Thanks for help
Did recomended actions
Double checked
pi@CAN-B:~ $ sudo pio upgrade --dev
Please wait while upgrading PlatformIO …
PlatformIO has been successfully upgraded to 5.0.2b2
Release notes: Redirecting...
pi@CAN-B:~ $ sudo apt install libssl-dev
Reading package lists… Done
Building dependency tree
Reading state information… Done
libssl-dev is already the newest version (1.1.1d-0+deb10u3+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Still Error
compilation terminated.
error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
Command “/usr/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-install-91n11jin/cffi/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-record-hpv2e8r1/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-pqtwuhkh --compile” failed with error code 1 in /tmp/pip-install-91n11jin/cffi/
Right, there are still libs missing. I’ve just seen the tutorial HowTo: Raspberry Pi 3 as remote agent (Oct. 2020) being posted, which should be exactly what you need. Let me know if there are errors.
Thank you very much, that was the trick.
I followed the linked tutorial, the only thing additionally installed was “libffi-dev”
Now the installation runs through without errors
Rainer
