Thank you very much, @sivar2311 .
I’ve followed that instruction and it has worked very well! It has shown some error messages, but only on the first time.
Thank you!
Just for the record:
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: espidf)
Platform Manager: Installing espressif32
Platform Manager: espressif32@6.5.0 has been installed!
Tool Manager: Installing espressif/toolchain-xtensa-esp32 @ 12.2.0+20230208
Tool Manager: toolchain-xtensa-esp32@12.2.0+20230208 has been installed!
Tool Manager: Installing platformio/toolchain-esp32ulp @ ~1.23500.0
Tool Manager: toolchain-esp32ulp@1.23500.220830 has been installed!
Tool Manager: Installing espressif/tool-xtensa-esp-elf-gdb @ ~12.1.0
Tool Manager: tool-xtensa-esp-elf-gdb@12.1.0+20221002 has been installed!
Tool Manager: Installing espressif/tool-riscv32-esp-elf-gdb @ ~12.1.0
Tool Manager: tool-riscv32-esp-elf-gdb@12.1.0+20221002 has been installed!
Tool Manager: Installing platformio/framework-espidf @ ~3.50102.0
Tool Manager: framework-espidf@3.50102.240122 has been installed!
Tool Manager: Installing platformio/tool-esptoolpy @ ~1.40501.0
Tool Manager: tool-esptoolpy@1.40501.0 has been installed!
PLATFORM: Espressif 32 (6.5.0) > DOIT ESP32 DEVKIT V1
- framework-espidf @ 3.50102.240122 (5.1.2)
- tool-cmake @ 3.16.4
- tool-ninja @ 1.9.0
- tool-riscv32-esp-elf-gdb @ 12.1.0+20221002
- tool-xtensa-esp-elf-gdb @ 12.1.0+20221002
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
- toolchain-xtensa-esp32 @ 12.2.0+20230208
Creating a new virtual environment for IDF Python dependencies
Error: Command '['/Users/cirobruno/.platformio/penv/.espidf-5.1.2/bin/python3', '-m', 'ensurepip', '--upgrade', '--default-pip']' returned non-zero exit status 1.
*** Error 1
AssertionError: Error: Failed to create a proper virtual environment. Missing the `pip` binary!:
File "/Users/cirobruno/.platformio/penv/lib/python3.11/site-packages/platformio/builder/main.py", line 173:
File "/Users/cirobruno/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Script/SConscript.py", line 612:
File "/Users/cirobruno/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Script/SConscript.py", line 279:
File "/Users/cirobruno/.platformio/platforms/espressif32/builder/main.py", line 346:
File "/Users/cirobruno/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Util/envs.py", line 251:
File "/Users/cirobruno/.platformio/penv/lib/python3.11/site-packages/platformio/builder/tools/piobuild.py", line 61:
env.ProcessProgramDeps()
File "/Users/cirobruno/.platformio/penv/lib/python3.11/site-packages/platformio/builder/tools/piobuild.py", line 121:
File "/Users/cirobruno/.platformio/penv/lib/python3.11/site-packages/platformio/builder/tools/piobuild.py", line 347:
SConscript(env.GetFrameworkScript(name), exports="env")
File "/Users/cirobruno/.platformio/packages/tool-scons/scons-local-4.7.0/SCons/Script/SConscript.py", line 676:
return method(*args, **kw)
File "/Users/cirobruno/.platformio/platforms/espressif32/builder/frameworks/espidf.py", line 1251:
ensure_python_venv_available()
File "/Users/cirobruno/.platformio/platforms/espressif32/builder/frameworks/espidf.py", line 1227:
_create_venv(venv_dir)
File "/Users/cirobruno/.platformio/platforms/espressif32/builder/frameworks/espidf.py", line 1219:
assert os.path.isfile(
===================================================== [FAILED] Took 426.49 seconds =====================================================
