Dear all,
I am struggling to get SerialUSB to work in a custom board I’ve developed using STM32F407VE. I have read a few topics here on similar issue, such as Configuring USB Serial For Marlin 2.0 and STM32F4, Difficulty with getting USB serial [USB CDC] working, among others, but none brought me to a solution. Even more intriguing, a colleague could use the SerialUSB with the same board. ![]()
I am using up-to-date Platform IO in a Windows 10 PC. I wrote a simple project, just to begin the SerialUSB and toggle a pin to check that the clock settings are fine. The board has a 25MHz HSE crystal and uses the USB HS peripheral. I am using the black_f407ve board configuration as basis for my setup.
Below are the code and platformio.ini.
Main.c:
SerialUSB.begin();
// Serial.begin(115200);
pinMode(PC10, OUTPUT);
SerialUSB.println("Hello world");
digitalToggle(PC10);
delay(1000);
SystemClock_Config():
// Override default clock source configuration
extern "C" void SystemClock_Config() {
RCC_OscInitTypeDef RCC_OscInitStruct = {};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {};
/**Configure the main internal regulator output voltage
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
/**Initializes the CPU, AHB and APB busses clocks
* VCO CLOCK = 25MHz * PLLN / PLLM
* PLL General Clock = VCO CLOCK / PLLP
* USB CLOCK = VCO CLOCK / PLLQ
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 25; // 25MHz Crystal frequency
RCC_OscInitStruct.PLL.PLLN = 336;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 7;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) {
Error_Handler();
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
| RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK) {
Error_Handler();
/* Ensure CCM RAM clock is enabled */
__HAL_RCC_CCMDATARAMEN_CLK_ENABLE();
I have modified the the HSE define in .platformio\packages\framework-arduinoststm32\system\STM32F4xx\stm32f4xx_hal_conf_default.h:
/* ################# ######### HSE/HSI Values adaptation ##################### */
* @brief Adjust the value of External High Speed oscillator (HSE) used in your application.
* This value is used by the RCC HAL module to compute the system frequency
* (when HSE is used as system clock source, directly or through the PLL).
#if !defined (HSE_VALUE)
#define HSE_VALUE 25000000U /*!< Value of the External oscillator in Hz */
// #define HSE_VALUE 8000000U /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
And this is my platformio.ini:
[env:black_f407ve]
platform = ststm32
board = black_f407ve
; uncomment to change upload protocol from stlink to dfu if needed
;upload_protocol = dfu
monitor_port = /dev/ttyACM0
-D PIO_FRAMEWORK_ARDUINO_ENABLE_CDC
-D USBCON
monitor_dtr = 1
I get a correct toggle period at the pin, but my PC doesn’t recognize the USB COMM port.
I also tried more detailed build_flags, the same my colleague uses, without any result:
board_build.mcu = stm32f407vet6
board_build.f_cpu = 168000000L
monitor_port = COM19
upload_protocol = stlink
-D USBCON
-D PIO_FRAMEWORK_ARDUINO_NANOLIB_FLOAT_PRINTF
-D PIO_FRAMEWORK_ARDUINO_USB_HIGHSPEED_FULLMODE
-D USBD_USE_CDC
-D HAL_PCD_MODULE_ENABLED
-D USE_USB_HS
-D USB_MANUFACTURER_STRING="\"Datalogger_8\""
-D USB_PRODUCT_STRING="\"Datalogger_8_v0.6\""
Does anyone has a clue where could be the problem?
