Hey there! Super in love with PlatformIO, absolute game changer coming from the Arduino IDE. Stoked to be part of the community!
I’m trying to compile Marlin 2.0 for an STM32F407VGT6. I’ve been able to successfully compile it, and even get it to upload using dfu-util, but try as I might I’m unable to get the serial port talking back over USB. The board is of my own design. I’m pretty confident that this is not a hardware issue because 1) the firmware uploads successfully, and 2) I’m able to use USB Serial without an issue when uploading a simple sketch using the Arduino IDE. This makes me think that it’s almost definitely something to do with my configuration in platformio.ini.
In the Marlin provided platformio.ini, there are multiple boards to select from. I ended up picking STM32F407VE_black and attempting to modify it to match my board. I did my best to identify which build flags I needed to change, but nothing has yet worked. I’m a bit out of my depths, and have been wrestling with this for a couple weeks, so any advice on things to try would be tremendously appreciated!
Some details:
- On Mac, macOS 10.15.7
- Hardware: STM32F407VGT6
- High speed clock at 12MHz
- Low speed clock at 32.768kHz
My platformio.ini file is below (just the common config and the STM32F407VE_black components):
[platformio]
src_dir = Marlin
boards_dir = buildroot/share/PlatformIO/boards
default_envs = STM32F407VE_black
include_dir = Marlin
# The 'common' values are used for most Marlin builds
[common]
default_src_filter = +<src/*> -<src/config> -<src/HAL> +<src/HAL/shared>
-<src/lcd/HD44780> -<src/lcd/dwin> -<src/lcd/dogm> -<src/lcd/tft>
-<src/lcd/menu>
-<src/lcd/menu/game/game.cpp> -<src/lcd/menu/game/brickout.cpp> -<src/lcd/menu/game/invaders.cpp>
-<src/lcd/menu/game/maze.cpp> -<src/lcd/menu/game/snake.cpp>
-<src/lcd/menu/menu_backlash.cpp>
-<src/lcd/menu/menu_bed_corners.cpp>
-<src/lcd/menu/menu_bed_leveling.cpp>
-<src/lcd/menu/menu_cancelobject.cpp>
-<src/lcd/menu/menu_delta_calibrate.cpp>
-<src/lcd/menu/menu_filament.cpp>
-<src/lcd/menu/menu_info.cpp>
-<src/lcd/menu/menu_job_recovery.cpp>
-<src/lcd/menu/menu_led.cpp>
-<src/lcd/menu/menu_media.cpp>
-<src/lcd/menu/menu_mmu2.cpp>
-<src/lcd/menu/menu_password.cpp>
-<src/lcd/menu/menu_power_monitor.cpp>
-<src/lcd/menu/menu_spindle_laser.cpp>
-<src/lcd/menu/menu_temperature.cpp>
-<src/lcd/menu/menu_tmc.cpp>
-<src/lcd/menu/menu_touch_screen.cpp>
-<src/lcd/menu/menu_ubl.cpp>
-<src/lcd/extui/lib/mks_ui>
-<src/lcd/extui/lib/dgus> -<src/lcd/extui/dgus_lcd.cpp>
-<src/lcd/extui/example.cpp>
-<src/lcd/extui/malyan_lcd.cpp>
-<src/lcd/extui/lib/ftdi_eve_touch_ui>
-<src/lcd/extui/lib/anycubic_i3mega>
-<src/lcd/extui/anycubic_tft.cpp>
-<src/lcd/lcdprint.cpp>
-<src/sd/usb_flashdrive>
-<src/feature/backlash.cpp>
-<src/feature/baricuda.cpp> -<src/gcode/feature/baricuda>
-<src/feature/bedlevel/abl> -<src/gcode/bedlevel/abl>
-<src/feature/bedlevel/mbl> -<src/gcode/bedlevel/mbl>
-<src/feature/bedlevel/ubl> -<src/gcode/bedlevel/ubl>
-<src/feature/binary_stream.cpp> -<src/libs/heatshrink>
-<src/feature/bltouch.cpp>
-<src/feature/cancel_object.cpp> -<src/gcode/feature/cancel>
-<src/feature/caselight> -<src/gcode/feature/caselight>
-<src/feature/closedloop.cpp>
-<src/feature/controllerfan.cpp> -<src/gcode/feature/controllerfan>
-<src/feature/dac> -<src/feature/digipot>
-<src/feature/direct_stepping.cpp> -<src/gcode/motion/G6.cpp>
-<src/feature/e_parser.cpp>
-<src/feature/encoder_i2c.cpp>
-<src/feature/fanmux.cpp>
-<src/feature/filwidth.cpp> -<src/gcode/feature/filwidth>
-<src/feature/fwretract.cpp> -<src/gcode/feature/fwretract>
-<src/feature/host_actions.cpp>
-<src/feature/hotend_idle.cpp>
-<src/feature/joystick.cpp>
-<src/feature/leds/blinkm.cpp>
-<src/feature/leds/leds.cpp>
-<src/feature/leds/pca9533.cpp>
-<src/feature/leds/pca9632.cpp>
-<src/feature/leds/printer_event_leds.cpp>
-<src/feature/leds/tempstat.cpp>
-<src/feature/max7219.cpp>
-<src/feature/mixing.cpp>
-<src/feature/mmu2> -<src/gcode/feature/prusa_MMU2>
-<src/feature/password> -<src/gcode/feature/password>
-<src/feature/pause.cpp>
-<src/feature/power.cpp>
-<src/feature/power_monitor.cpp> -<src/gcode/feature/power_monitor>
-<src/feature/powerloss.cpp> -<src/gcode/feature/powerloss>
-<src/feature/probe_temp_comp.cpp>
-<src/feature/runout.cpp> -<src/gcode/feature/runout>
-<src/feature/snmm.cpp>
-<src/feature/solenoid.cpp>
-<src/feature/spindle_laser.cpp> -<src/gcode/control/M3-M5.cpp>
-<src/feature/tmc_util.cpp> -<src/module/stepper/trinamic.cpp>
-<src/feature/twibus.cpp>
-<src/feature/z_stepper_align.cpp>
-<src/gcode/bedlevel/G26.cpp>
-<src/gcode/bedlevel/G35.cpp>
-<src/gcode/bedlevel/G42.cpp>
-<src/gcode/bedlevel/M420.cpp>
-<src/gcode/calibrate/G33.cpp>
-<src/gcode/calibrate/G34_M422.cpp>
-<src/gcode/calibrate/G76_M871.cpp>
-<src/gcode/calibrate/G425.cpp>
-<src/gcode/calibrate/M12.cpp>
-<src/gcode/calibrate/M48.cpp>
-<src/gcode/calibrate/M100.cpp>
-<src/gcode/calibrate/M425.cpp>
-<src/gcode/calibrate/M666.cpp>
-<src/gcode/calibrate/M852.cpp>
-<src/gcode/config/M43.cpp>
-<src/gcode/config/M217.cpp>
-<src/gcode/config/M218.cpp>
-<src/gcode/config/M221.cpp>
-<src/gcode/config/M281.cpp>
-<src/gcode/config/M302.cpp>
-<src/gcode/config/M305.cpp>
-<src/gcode/config/M540.cpp>
-<src/gcode/control/M7-M9.cpp>
-<src/gcode/control/M211.cpp>
-<src/gcode/control/M605.cpp>
-<src/gcode/feature/advance>
-<src/gcode/feature/camera>
-<src/gcode/feature/i2c>
-<src/gcode/feature/L6470>
-<src/gcode/feature/leds/M150.cpp>
-<src/gcode/feature/leds/M7219.cpp>
-<src/gcode/feature/macro>
-<src/gcode/feature/mixing/M163-M165.cpp>
-<src/gcode/feature/mixing/M166.cpp>
-<src/gcode/feature/pause/G27.cpp>
-<src/gcode/feature/pause/G60.cpp>
-<src/gcode/feature/pause/G61.cpp>
-<src/gcode/feature/pause/M125.cpp>
-<src/gcode/feature/pause/M600.cpp>
-<src/gcode/feature/pause/M603.cpp>
-<src/gcode/feature/pause/M701_M702.cpp>
-<src/gcode/feature/trinamic/M122.cpp>
-<src/gcode/feature/trinamic/M569.cpp>
-<src/gcode/feature/trinamic/M906.cpp>
-<src/gcode/feature/trinamic/M911-M914.cpp>
-<src/gcode/geometry/G17-G19.cpp>
-<src/gcode/geometry/G53-G59.cpp>
-<src/gcode/geometry/M206_M428.cpp>
-<src/gcode/host/M16.cpp>
-<src/gcode/host/M113.cpp>
-<src/gcode/host/M360.cpp>
-<src/gcode/host/M876.cpp>
-<src/gcode/lcd/M0_M1.cpp>
-<src/gcode/lcd/M145.cpp>
-<src/gcode/lcd/M250.cpp>
-<src/gcode/lcd/M73.cpp>
-<src/gcode/lcd/M995.cpp>
-<src/gcode/motion/G2_G3.cpp>
-<src/gcode/motion/G5.cpp>
-<src/gcode/motion/G80.cpp>
-<src/gcode/motion/M290.cpp>
-<src/gcode/probe/G30.cpp>
-<src/gcode/probe/G31_G32.cpp>
-<src/gcode/probe/G38.cpp>
-<src/gcode/probe/M401_M402.cpp>
-<src/gcode/probe/M851.cpp>
-<src/gcode/probe/M951.cpp>
-<src/gcode/scara>
-<src/gcode/sd>
-<src/gcode/temp/M104_M109.cpp>
-<src/gcode/units/G20_G21.cpp>
-<src/gcode/units/M149.cpp>
-<src/libs/L64XX> -<src/module/stepper/L64xx.cpp>
-<src/libs/hex_print.cpp>
-<src/libs/least_squares_fit.cpp>
-<src/libs/nozzle.cpp> -<src/gcode/feature/clean>
-<src/module/delta.cpp>
-<src/module/planner_bezier.cpp>
-<src/module/printcounter.cpp>
-<src/module/probe.cpp>
-<src/module/scara.cpp> -<src/gcode/calibrate/M665.cpp>
-<src/module/stepper/TMC26X.cpp>
extra_scripts =
pre:buildroot/share/PlatformIO/scripts/common-dependencies.py
pre:buildroot/share/PlatformIO/scripts/common-cxxflags.py
build_flags = -fmax-errors=5 -g -D__MARLIN_FIRMWARE__ -fmerge-all-constants
# Feature Dependencies
[features]
HAS_TFT_LVGL_UI = lvgl=https://github.com/makerbase-mks/MKS-LittlevGL/archive/master.zip
src_filter=+<src/lcd/extui/lib/mks_ui>
extra_scripts=download_mks_assets.py
HAS_TRINAMIC_CONFIG = TMCStepper@~0.7.1
src_filter=+<src/feature/tmc_util.cpp> +<src/module/stepper/trinamic.cpp> +<src/gcode/feature/trinamic/M122.cpp> +<src/gcode/feature/trinamic/M906.cpp> +<src/gcode/feature/trinamic/M911-M914.cpp>
HAS_STEALTHCHOP = src_filter=+<src/gcode/feature/trinamic/M569.cpp>
SR_LCD_3W_NL = SailfishLCD=https://github.com/mikeshub/SailfishLCD/archive/master.zip
HAS_I2C_DIGIPOT = SlowSoftI2CMaster
src_filter=+<src/feature/digipot>
HAS_TMC26X = TMC26XStepper=https://github.com/trinamic/TMC26XStepper/archive/master.zip
src_filter=+<src/module/TMC26X.cpp>
HAS_L64XX = Arduino-L6470@0.8.0
src_filter=+<src/libs/L64XX> +<src/module/stepper/L64xx.cpp> +<src/gcode/feature/L6470>
NEOPIXEL_LED = Adafruit NeoPixel@1.5.0
src_filter=+<src/feature/leds/neopixel.cpp>
MAX6675_IS_MAX31865 = Adafruit MAX31865 library@~1.1.0
HAS_GRAPHICAL_LCD = U8glib-HAL@0.4.1
src_filter=+<src/lcd/dogm>
USES_LIQUIDCRYSTAL = LiquidCrystal@1.5.0
USES_LIQUIDTWI2 = LiquidTWI2@1.2.7
DWIN_CREALITY_LCD = src_filter=+<src/lcd/dwin>
HAS_CHARACTER_LCD = src_filter=+<src/lcd/HD44780>
HAS_GRAPHICAL_TFT = src_filter=+<src/lcd/tft>
HAS_LCD_MENU = src_filter=+<src/lcd/menu>
HAS_GAMES = src_filter=+<src/lcd/menu/game/game.cpp>
MARLIN_BRICKOUT = src_filter=+<src/lcd/menu/game/brickout.cpp>
MARLIN_INVADERS = src_filter=+<src/lcd/menu/game/invaders.cpp>
MARLIN_MAZE = src_filter=+<src/lcd/menu/game/maze.cpp>
MARLIN_SNAKE = src_filter=+<src/lcd/menu/game/snake.cpp>
HAS_MENU_BACKLASH = src_filter=+<src/lcd/menu/menu_backlash.cpp>
HAS_MENU_BED_CORNERS = src_filter=+<src/lcd/menu/menu_bed_corners.cpp>
LCD_BED_LEVELING = src_filter=+<src/lcd/menu/menu_bed_leveling.cpp>
HAS_MENU_CANCELOBJECT = src_filter=+<src/lcd/menu/menu_cancelobject.cpp>
HAS_MENU_DELTA_CALIBRATE = src_filter=+<src/lcd/menu/menu_delta_calibrate.cpp>
HAS_MENU_FILAMENT = src_filter=+<src/lcd/menu/menu_filament.cpp>
LCD_INFO_MENU = src_filter=+<src/lcd/menu/menu_info.cpp>
HAS_MENU_JOB_RECOVERY = src_filter=+<src/lcd/menu/menu_job_recovery.cpp>
HAS_MENU_LED = src_filter=+<src/lcd/menu/menu_led.cpp>
HAS_MENU_MEDIA = src_filter=+<src/lcd/menu/menu_media.cpp>
HAS_MENU_MIXER = src_filter=+<src/lcd/menu/menu_mixer.cpp>
HAS_MENU_MMU2 = src_filter=+<src/lcd/menu/menu_mmu2.cpp>
HAS_MENU_PASSWORD = src_filter=+<src/lcd/menu/menu_password.cpp>
HAS_MENU_POWER_MONITOR = src_filter=+<src/lcd/menu/menu_power_monitor.cpp>
HAS_MENU_CUTTER = src_filter=+<src/lcd/menu/menu_spindle_laser.cpp>
HAS_MENU_TEMPERATURE = src_filter=+<src/lcd/menu/menu_temperature.cpp>
HAS_MENU_TMC = src_filter=+<src/lcd/menu/menu_tmc.cpp>
HAS_MENU_TOUCH_SCREEN = src_filter=+<src/lcd/menu/menu_touch_screen.cpp>
HAS_MENU_UBL = src_filter=+<src/lcd/menu/menu_ubl.cpp>
ANYCUBIC_LCD_I3MEGA = src_filter=+<src/lcd/extui/lib/anycubic_i3mega>
HAS_DGUS_LCD = src_filter=+<src/lcd/extui/lib/dgus> +<src/lcd/extui/dgus_lcd.cpp>
TOUCH_UI_FTDI_EVE = src_filter=+<src/lcd/extui/lib/ftdi_eve_touch_ui>
HAS_ANYCUBIC_TFT_EXTUI = src_filter=+<src/lcd/extui/anycubic_tft.cpp>
EXTUI_EXAMPLE = src_filter=+<src/lcd/extui/example.cpp>
MALYAN_LCD = src_filter=+<src/lcd/extui/malyan_lcd.cpp>
HAS_SPI_LCD = src_filter=+<src/lcd/lcdprint.cpp>
USB_FLASH_DRIVE_SUPPORT = src_filter=+<src/sd/usb_flashdrive>
AUTO_BED_LEVELING_BILINEAR = src_filter=+<src/feature/bedlevel/abl>
AUTO_BED_LEVELING_(3POINT|(BI)?LINEAR) = src_filter=+<src/gcode/bedlevel/abl>
MESH_BED_LEVELING = src_filter=+<src/feature/bedlevel/mbl> +<src/gcode/bedlevel/mbl>
AUTO_BED_LEVELING_UBL = src_filter=+<src/feature/bedlevel/ubl> +<src/gcode/bedlevel/ubl>
BACKLASH_COMPENSATION = src_filter=+<src/feature/backlash.cpp>
BARICUDA = src_filter=+<src/feature/baricuda.cpp> +<src/gcode/feature/baricuda>
BINARY_FILE_TRANSFER = src_filter=+<src/feature/binary_stream.cpp> +<src/libs/heatshrink>
BLTOUCH = src_filter=+<src/feature/bltouch.cpp>
CANCEL_OBJECTS = src_filter=+<src/feature/cancel_object.cpp> +<src/gcode/feature/cancel>
CASE_LIGHT_ENABLE = src_filter=+<src/feature/caselight> +<src/gcode/feature/caselight>
EXTERNAL_CLOSED_LOOP_CONTROLLER = src_filter=+<src/feature/closedloop.cpp> +<src/gcode/calibrate/M12.cpp>
USE_CONTROLLER_FAN = src_filter=+<src/feature/controllerfan.cpp>
DAC_STEPPER_CURRENT = src_filter=+<src/feature/dac>
DIRECT_STEPPING = src_filter=+<src/feature/direct_stepping.cpp> +<src/gcode/motion/G6.cpp>
EMERGENCY_PARSER = src_filter=+<src/feature/e_parser.cpp> -<src/gcode/control/M108_*.cpp>
I2C_POSITION_ENCODERS = src_filter=+<src/feature/encoder_i2c.cpp>
HAS_FANMUX = src_filter=+<src/feature/fanmux.cpp>
FILAMENT_WIDTH_SENSOR = src_filter=+<src/feature/filwidth.cpp> +<src/gcode/feature/filwidth>
FWRETRACT = src_filter=+<src/feature/fwretract.cpp> +<src/gcode/feature/fwretract>
HOST_ACTION_COMMANDS = src_filter=+<src/feature/host_actions.cpp>
HOTEND_IDLE_TIMEOUT = src_filter=+<src/feature/hotend_idle.cpp>
JOYSTICK = src_filter=+<src/feature/joystick.cpp>
BLINKM = src_filter=+<src/feature/leds/blinkm.cpp>
HAS_COLOR_LEDS = src_filter=+<src/feature/leds/leds.cpp> +<src/gcode/feature/leds/M150.cpp>
PCA9533 = src_filter=+<src/feature/leds/pca9533.cpp>
PCA9632 = src_filter=+<src/feature/leds/pca9632.cpp>
PRINTER_EVENT_LEDS = src_filter=+<src/feature/leds/printer_event_leds.cpp>
TEMP_STAT_LEDS = src_filter=+<src/feature/leds/tempstat.cpp>
MAX7219_DEBUG = src_filter=+<src/feature/max7219.cpp> +<src/gcode/feature/leds/M7219.cpp>
MIXING_EXTRUDER = src_filter=+<src/feature/mixing.cpp> +<src/gcode/feature/mixing/M163-M165.cpp>
PRUSA_MMU2 = src_filter=+<src/feature/mmu2> +<src/gcode/feature/prusa_MMU2>
PASSWORD_FEATURE = src_filter=+<src/feature/password> +<src/gcode/feature/password>
ADVANCED_PAUSE_FEATURE = src_filter=+<src/feature/pause.cpp> +<src/gcode/feature/pause/M600.cpp> +<src/gcode/feature/pause/M603.cpp>
AUTO_POWER_CONTROL = src_filter=+<src/feature/power.cpp>
HAS_POWER_MONITOR = src_filter=+<src/feature/power_monitor.cpp> +<src/gcode/feature/power_monitor>
POWER_LOSS_RECOVERY = src_filter=+<src/feature/powerloss.cpp> +<src/gcode/feature/powerloss>
PROBE_TEMP_COMPENSATION = src_filter=+<src/feature/probe_temp_comp.cpp> +<src/gcode/calibrate/G76_M871.cpp>
HAS_FILAMENT_SENSOR = src_filter=+<src/feature/runout.cpp> +<src/gcode/feature/runout>
MK2_MULTIPLEXER = src_filter=+<src/feature/snmm.cpp>
EXT_SOLENOID|MANUAL_SOLENOID_CONTROL = src_filter=+<src/feature/solenoid.cpp>
HAS_CUTTER = src_filter=+<src/feature/spindle_laser.cpp> +<src/gcode/control/M3-M5.cpp>
EXPERIMENTAL_I2CBUS = src_filter=+<src/feature/twibus.cpp> +<src/gcode/feature/i2c>
Z_STEPPER_AUTO_ALIGN = src_filter=+<src/feature/z_stepper_align.cpp> +<src/gcode/calibrate/G34_M422.cpp>
G26_MESH_VALIDATION = src_filter=+<src/gcode/bedlevel/G26.cpp>
ASSISTED_TRAMMING = src_filter=+<src/gcode/bedlevel/G35.cpp>
HAS_MESH = src_filter=+<src/gcode/bedlevel/G42.cpp>
HAS_LEVELING = src_filter=+<src/gcode/bedlevel/M420.cpp>
DELTA_AUTO_CALIBRATION = src_filter=+<src/gcode/calibrate/G33.cpp>
CALIBRATION_GCODE = src_filter=+<src/gcode/calibrate/G425.cpp>
Z_MIN_PROBE_REPEATABILITY_TEST = src_filter=+<src/gcode/calibrate/M48.cpp>
M100_FREE_MEMORY_WATCHER = src_filter=+<src/gcode/calibrate/M100.cpp>
BACKLASH_GCODE = src_filter=+<src/gcode/calibrate/M425.cpp>
IS_KINEMATIC = src_filter=+<src/gcode/calibrate/M665.cpp>
HAS_EXTRA_ENDSTOPS = src_filter=+<src/gcode/calibrate/M666.cpp>
SKEW_CORRECTION_GCODE = src_filter=+<src/gcode/calibrate/M852.cpp>
PINS_DEBUGGING = src_filter=-<src/gcode/config/M43.cpp>
NO_VOLUMETRICS = src_filter=-<src/gcode/config/M200-M205.cpp>
HAS_MULTI_EXTRUDER = src_filter=+<src/gcode/config/M217.cpp>
HAS_HOTEND_OFFSET = src_filter=+<src/gcode/config/M218.cpp>
EDITABLE_SERVO_ANGLES = src_filter=+<src/gcode/config/M281.cpp>
PREVENT_COLD_EXTRUSION = src_filter=+<src/gcode/config/M302.cpp>
HAS_USER_THERMISTORS = src_filter=+<src/gcode/config/M305.cpp>
SD_ABORT_ON_ENDSTOP_HIT = src_filter=+<src/gcode/config/M540.cpp>
COOLANT_CONTROL = src_filter=+<src/gcode/control/M7-M9.cpp>
HAS_SOFTWARE_ENDSTOPS = src_filter=+<src/gcode/control/M211.cpp>
HAS_DUPLICATION_MODE = src_filter=+<src/gcode/control/M605.cpp>
LIN_ADVANCE = src_filter=+<src/gcode/feature/advance>
PHOTO_GCODE = src_filter=+<src/gcode/feature/camera>
CONTROLLER_FAN_EDITABLE = src_filter=+<src/gcode/feature/controllerfan>
GCODE_MACROS = src_filter=+<src/gcode/feature/macro>
GRADIENT_MIX = src_filter=+<src/gcode/feature/mixing/M166.cpp>
HAS_SAVED_POSITIONS = src_filter=+<src/gcode/feature/pause/G60.cpp> +<src/gcode/feature/pause/G61.cpp>
PARK_HEAD_ON_PAUSE = src_filter=+<src/gcode/feature/pause/M125.cpp>
FILAMENT_LOAD_UNLOAD_GCODES = src_filter=+<src/gcode/feature/pause/M701_M702.cpp>
CNC_WORKSPACE_PLANES = src_filter=+<src/gcode/geometry/G17-G19.cpp>
CNC_COORDINATE_SYSTEMS = src_filter=+<src/gcode/geometry/G53-G59.cpp>
HAS_M206_COMMAND = src_filter=+<src/gcode/geometry/M206_M428.cpp>
EXPECTED_PRINTER_CHECK = src_filter=+<src/gcode/host/M16.cpp>
HOST_KEEPALIVE_FEATURE = src_filter=+<src/gcode/host/M113.cpp>
REPETIER_GCODE_M360 = src_filter=+<src/gcode/host/M360.cpp>
HAS_GCODE_M876 = src_filter=+<src/gcode/host/M876.cpp>
HAS_RESUME_CONTINUE = src_filter=+<src/gcode/lcd/M0_M1.cpp>
HAS_PREHEAT_COUNT = src_filter=+<src/gcode/lcd/M145.cpp>
HAS_LCD_CONTRAST = src_filter=+<src/gcode/lcd/M250.cpp>
LCD_SET_PROGRESS_MANUALLY = src_filter=+<src/gcode/lcd/M73.cpp>
TOUCH_SCREEN_CALIBRATION = src_filter=+<src/gcode/lcd/M995.cpp>
ARC_SUPPORT = src_filter=+<src/gcode/motion/G2_G3.cpp>
GCODE_MOTION_MODES = src_filter=+<src/gcode/motion/G80.cpp>
BABYSTEPPING = src_filter=+<src/gcode/motion/M290.cpp>
Z_PROBE_SLED = src_filter=+<src/gcode/probe/G31_G32.cpp>
G38_PROBE_TARGET = src_filter=+<src/gcode/probe/G38.cpp>
MAGNETIC_PARKING_EXTRUDER = src_filter=+<src/gcode/probe/M951.cpp>
SDSUPPORT = src_filter=+<src/gcode/sd>
HAS_EXTRUDERS = src_filter=+<src/gcode/temp/M104_M109.cpp> +<src/gcode/config/M221.cpp>
INCH_MODE_SUPPORT = src_filter=+<src/gcode/units/G20_G21.cpp>
TEMPERATURE_UNITS_SUPPORT = src_filter=+<src/gcode/units/M149.cpp>
NEED_HEX_PRINT = src_filter=+<src/libs/hex_print.cpp>
NEED_LSF = src_filter=+<src/libs/least_squares_fit.cpp>
NOZZLE_PARK_FEATURE = src_filter=+<src/libs/nozzle.cpp> +<src/gcode/feature/pause/G27.cpp>
NOZZLE_CLEAN_FEATURE = src_filter=+<src/libs/nozzle.cpp> +<src/gcode/feature/clean>
DELTA = src_filter=+<src/module/delta.cpp> +<src/gcode/calibrate/M666.cpp>
BEZIER_CURVE_SUPPORT = src_filter=+<src/module/planner_bezier.cpp> +<src/gcode/motion/G5.cpp>
PRINTCOUNTER = src_filter=+<src/module/printcounter.cpp>
HAS_BED_PROBE = src_filter=+<src/module/probe.cpp> +<src/gcode/probe/G30.cpp> +<src/gcode/probe/M401_M402.cpp> +<src/gcode/probe/M851.cpp>
IS_SCARA = src_filter=+<src/module/scara.cpp>
MORGAN_SCARA = src_filter=+<src/gcode/scara>
(ESP3D_)?WIFISUPPORT = AsyncTCP, ESP Async WebServer
ESP3DLib=https://github.com/luc-github/ESP3DLib.git
arduinoWebSockets=https://github.com/Links2004/arduinoWebSockets.git
ESP32SSDP=https://github.com/luc-github/ESP32SSDP.git
lib_ignore=ESPAsyncTCP
# Default values apply to all 'env:' prefixed environments
[env]
extra_scripts = ${common.extra_scripts}
build_flags = ${common.build_flags}
lib_deps = ${common.lib_deps}
monitor_speed = 250000
monitor_flags =
--quiet
--echo
--eol
LF
--filter
colorize
--filter
time
# STM32F407VET6 with RAMPS-like shield
# 'Black' STM32F407VET6 board - https://wiki.stm32duino.com/index.php?title=STM32F407
# Shield - https://github.com/jmz52/Hardware
[env:STM32F407VE_black]
platform = ${common_stm32.platform}
extends = common_stm32
board = blackSTM32F407VET6
upload_port = 0483:df11
upload_protocol = dfu
board_build.f_cpu = 12000000L
build_flags = ${common_stm32.build_flags}
-D ARDUINO_BLACK_F407VE
; -D PIO_FRAMEWORK_ARDUINO_ENABLE_CDC
; -D USBD_USE_CDC_COMPOSITE
; -D MENU_USB_SERIAL
; -D MENU_SERIAL=SerialUSB
; -D USBCON
-D USBD_VID=0x0483
-D USBD_PID=0x5740
-DLSE_VALUE=32768U
-DHSE_VALUE=12000000U
; -D USB_MANUFACTURER="Unknown"
-D USB_PRODUCT=\"BLACK_F407VE\"
; -D HAL_PCD_MODULE_ENABLED
;-D PIO_FRAMEWORK_ARDUINO_SERIAL_WITHOUT_GENERIC
;-D PIO_FRAMEWORK_ARDUINO_NANOLIB_FLOAT_PRINTF
;-D PIO_FRAMEWORK_ARDUINO_USB_HIGHSPEED_FULLMODE
pre:buildroot/share/PlatformIO/scripts/generic_create_variant.py
lib_ignore = SoftwareSerial
Either way, not a PIO issue. Thank you so much for your help, I appreciate it tremendously!
