Terminale verrà riutilizzato dalle attività, premere un tasto qualsiasi per chiuderlo.
> Executing task: platformio run <
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR 2.0.0 > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
- framework-arduino-avr 5.0.0
Found 13 compatible libraries
|-- <Adafruit BME280 Library> 2.0.2
| |-- <Adafruit Unified Sensor> 1.1.2
| | |-- <Adafruit ADXL343> 1.3.0
| | | |-- <Adafruit BusIO> 1.2.3
| | | | |-- <SPI> 1.0
| | | | |-- <Wire> 1.0
| | | |-- <Wire> 1.0
| |-- <Wire> 1.0
| |-- <SPI> 1.0
|-- <RTClib> 1.6.0
| |-- <TinyWireM> 1.0.1
| |-- <Wire> 1.0
| | | |-- <SPI> 1.0
| | | |-- <Wire> 1.0
| | |-- <Wire> 1.0
|-- <EEPROM> 2.0
|-- <LiquidCrystal_I2C>
| |-- <Wire> 1.0
|-- <Wire> 1.0
Compiling .pio/build/megaatmega2560/lib382/TinyWireM-master/USI_TWI_Master.cpp.o
Archiving .pio/build/megaatmega2560/lib9ab/libLiquidCrystal_I2C_ID576.a
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp: In function 'void USI_TWI_Master_Initialise()':
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:48:3: error: 'PORT_USI' was not declared in this scope
PORT_USI |= (1<<PIN_USI_SDA); // Enable pullup on SDA, to set high as released state.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:48:19: error: 'PIN_USI_SDA' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:49:19: error: 'PIN_USI_SCL' was not declared in this scope
PORT_USI |= (1<<PIN_USI_SCL); // Enable pullup on SCL, to set high as released state.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:51:3: error: 'DDR_USI' was not declared in this scope
DDR_USI |= (1<<PIN_USI_SCL); // Enable SCL as output.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:54:3: error: 'USIDR' was not declared in this scope
USIDR = 0xFF; // Preload dataregister with "released level" data.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:55:3: error: 'USICR' was not declared in this scope
USICR = (0<<USISIE)|(0<<USIOIE)| // Disable Interrupts.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:55:19: error: 'USISIE' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:55:31: error: 'USIOIE' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:56:19: error: 'USIWM1' was not declared in this scope
Archiving .pio/build/megaatmega2560/libFrameworkArduinoVariant.a
(1<<USIWM1)|(0<<USIWM0)| // Set USI in Two-wire mode.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:56:31: error: 'USIWM0' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:57:19: error: 'USICS1' was not declared in this scope
(1<<USICS1)|(0<<USICS0)|(1<<USICLK)| // Software stobe as counter clock source
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:57:31: error: 'USICS0' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:57:43: error: 'USICLK' was not declared in this scope
Indexing .pio/build/megaatmega2560/libFrameworkArduinoVariant.a
(1<<USICS1)|(0<<USICS0)|(1<<USICLK)| // SoIndexing .pio/build/megaatmega2560/lib9ab/libLiquidCrystal_I2C_ID576.a
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:58:19: error: 'USITC' was not declared in this scope
(0<<USITC);
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:59:3: error: 'USISR' was not declared in this scope
USISR = (1<<USISIF)|(1<<USIOIF)|(1<<USIPF)|(1<<USIDC)| // Clear flags,
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:59:19: error: 'USISIF' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:59:31: error: 'USIOIF' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:59:43: error: 'USIPF' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:59:54: error: 'USIDC' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:60:21: error: 'USICNT0' was not declared in this scope
(0x0<<USICNT0); // and reset counter.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp: In function 'unsigned char USI_TWI_Start_Transceiver_With_Data(unsigned char*, unsigned char)':
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:130:44: error: 'USISIF' was not declared in this scope
unsigned char const tempUSISR_8bit = (1<<USISIF)|(1<<USIOIF)|(1<<USIPF)|(1<<USIDC)| // Prepare register value to: Clear flags, and
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:130:56: error: 'USIOIF' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:130:68: error: 'USIPF' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:130:79: error: 'USIDC' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:131:40: error: 'USICNT0' was not declared in this scope
(0x0<<USICNT0); // set USI to shift 8 bits i.e. count 16 clock edges.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:196:7: error: 'PORT_USI' was not declared in this scope
PORT_USI &= ~(1<<PIN_USI_SCL); // Pull SCL LOW.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USCompiling .pio/build/megaatmega2560/FrameworkArduino/CDC.cpp.o
I_TWI_Master.cpp:196:24: error: 'PIN_USI_SCL' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:197:7: error: 'USIDR' was not declared in this scope
USIDR = *(msg++); // Setup data.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:201:7: error: 'DDR_USI' was not declared in this scope
DDR_USI &= ~(1<<PIN_USI_SDA); // Enable SDA as input.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:201:24: error: 'PIN_USI_SDA' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:234:7: error: 'DDR_USI' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:234:25: error: 'PIN_USI_SDA' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:240:9: error: 'USIDR' was not declared in this scope
USIDR = 0xFF; // Load NACK to confirm End Of Transmission.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:244:9: error: 'USIDR' was not declared in this scope
USIDR = 0x00; // Load ACK. Set data register bit 7 (output for SDA) low.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp: In function 'unsigned char USI_TWI_Master_Transfer(unsigned char)':
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:263:3: error: 'USISR' was not declared in this scope
USISR = temp; // Set USISR according to temp.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:265:16: error: 'USISIE' was not declared in this scope
temp = (0<<USISIE)|(0<<USIOIE)| // Interrupts disabled
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:265:28: error: 'USIOIE' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:266:16: error: 'USIWM1' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:266:28: error: 'USIWM0' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:267:16: error: 'USICS1' was not declared in this scope
(1<<USICS1)|(0<<USICS0)|(1<<USICLK)| // Software clock strobe as source.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:267:28: error: 'USICS0' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:267:40: error: 'USICLK' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:268:16: error: 'USITC' was not declared in this scope
(1<<USITC); // Toggle Clock Port.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:272:5: error: 'USICR' was not declared in this scope
USICR = temp; // Generate positve SCL edge.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:273:14: error: 'PIN_USI' was not declared in this scope
while( !(PIN_USI & (1<<PIN_USI_SCL)) );// Wait for SCL to go high.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:273:28: error: 'PIN_USI_SCL' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:276:25: error: 'USIOIF' was not declared in this scope
}while( !(USISR & (1<<USIOIF)) ); // Check for transfer complete.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:279:11: error: 'USIDR' was not declared in this scope
temp = USIDR; // Read out data.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:281:3: error: 'DDR_USI' was not declared in this scope
DDR_USI |= (1<<PIN_USI_SDA); // Enable SDA as output.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:281:18: error: 'PIN_USI_SDA' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp: In function 'unsigned char USI_TWI_Master_Start()':
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:291:3: error: 'PORT_USI' was not declared in this scope
PORT_USI |= (1<<PIN_USI_SCL); // Release SCL.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:291:19: error: 'PIN_USI_SCL' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:296:20: error: 'PIN_USI_SDA' was not declared in this scope
PORT_USI &= ~(1<<PIN_USI_SDA); // Force SDA LOW.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:302:9: error: 'USISR' was not declared in this scope
if( !(USISR & (1<<USISIF)) )
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:302:21: error: 'USISIF' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp: In function 'unsigned char USI_TWI_Master_Stop()':
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:316:3: error: 'PORT_USI' was not declared in this scope
PORT_USI &= ~(1<<PIN_USI_SDA); // Pull SDA low.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:316:20: error: 'PIN_USI_SDA' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:317:19: error: 'PIN_USI_SCL' was not declared in this scope
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:318:12: error: 'PIN_USI' was not declared in this scope
while( !(PIN_USI & (1<<PIN_USI_SCL)) ); // Wait for SCL to go high.
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:324:9: error: 'USISR' was not declared in this scope
if( !(USISR & (1<<USIPF)) )
/Users/giacomofidanza/.platformio/lib/TinyWireM-master/USI_TWI_Master.cpp:324:21: error: 'USIPF' was not declared in this scope
*** [.pio/build/megaatmega2560/lib382/TinyWireM-master/USI_TWI_Master.cpp.o] Error 1
============================================================== [FAILED] Took 2.29 seconds ===
