The Device (ESP-32 Devboard) is listed in the online interface as
COM3 Silicon Labs CP210x USB to UART Bridge (COM3) USB VID:PID=10C4:EA60 SER=0001 LOCATION=1-1.1.2
After manually setting up a (MinGW) Toolchain (Couldn’t create a CMake Profile without)
CLions IntelliSense does not find Arduino.h or a file on the same level.
The only issue that sounds anything similar is this, but I do not see a solution there.
The current working directory C:\Users\User\CLionProjects\FixtureProject will be used for the project.
The next files/directories have been created in C:\Users\User\CLionProjects\FixtureProject
Project has been successfully updated including configuration files for clion IDE.
Process finished with exit code 0
CMake Debug Output:
C:\Users\User\AppData\Local\JetBrains\Toolbox\apps\CLion\ch-0\203.6682.181\bin\cmake\win\bin\cmake.exe -DCMAKE_BUILD_TYPE=Debug -G “CodeBlocks - MinGW Makefiles” C:\Users\User\CLionProjects\FixtureProject
– Configuring done
– Generating done
– Build files have been written to: C:/Users/User/CLionProjects/FixtureProject/cmake-build-debug
There is no error message (where should one be?). It just doesn’t offer me to upload (or use any configuration) to the device.
configurations:
Debug
Production
Z_DUMMY_TARGET
PlattformIO Debug | Nothing to run on
PlattformIO Test | Nothing to run on
PlattformIO Upload | Nothing to run on
Can you change the configuration to “PlatformIO Upload”?
Also it’s kinda wrong that “Debug” and “Production” are still there as targets, they should have been esp32dev. What does your CMake Profile menu look like now?
What does your Settings -> Build --> Toolchains menu look like?
I suspect this is the right place to search for the problem (since its just the MinGW default) but I do certainly not know how to get this right. (Already tried the “delete and add” thingy)
Thanks for your help
CMake Profile is some posts above, upload doesn’t change a thing
Is there a manual step to link the project to the device aside from specifying the port and the kind of device in the ini or something?
For good measurement here is the device info the web interface gives me:
COM3
Having the microcontroller / USB device connected or not should not influence CLion showing “Nothing to run on” in any way whatsoever.
Well except for the fact that there’s an icon before the profile name I don’t see anything wrong with it. If the toolchain is alright (MinGW at the top and all compilers etc detected), it should just work.
Have you tried right-clicking on the project folder in CLion and doing “Reload CMake project”? What does that output?
Okay, this is weird, because for a moment I had exactly the same issue with an espressif32 based project. I can’t understand how (“nothing to run” appeared when I re-open the project), because “esp32dev” was on my Cmake profile too.
This is a long shot (because I don’t understand how I resolve the issue on my side, and I can’t reproduce it for some mysterious reasons), but could you try to clean the configurations, and add again the PIO ones again?
CMake Rebuild Output:
C:\Users\User\AppData\Local\JetBrains\Toolbox\apps\CLion\ch-0\203.6682.181\bin\cmake\win\bin\cmake.exe -DCMAKE_BUILD_TYPE=esp32dev -G “CodeBlocks - MinGW Makefiles” C:\Users\User\CLionProjects\FixtureProject
– Configuring done
– Generating done
– Build files have been written to: C:/Users/User/CLionProjects/FixtureProject/cmake-build-esp32dev
[Finished]
@copperbot-d How Why What??? Why does this do anything? I had changed the templetes, so I didn’t need to remove the Build again, but how why what? why does this work? Thank you!
Thank you all very much for your efforts!
I marked @copperbot-d s Message as Solution because I believe this will be more useful to others. Thank you, @maxgerhardt, for the info about the re-adding of the CMake Profile though.
I suspect it comes from Clion, maybe he didn’t detect a change in certain files (.idea/workspace.xml ?), but I don’t understand why I can’t reproduce this bug anymore… and especially why an espressif32 based project, I never (ever) bump into this kind of issue with other frameworks… weird bug
