I was using VSCode for my Platformio IDE, but it was not performing nicely and I wanted to try something different.
I found out that CLion works quite nice, but I got one small problem. I can’t view the standard Arduino Classes, methods and Headers. It compiles but it doesn’t show up right in CLion.
I’m on Windows 10 Version 2004
It neither works with my complex code nor with a simple empty starting sketch.
If any of you knows how to combat this problem, it would be nice if you could help me
What does it look like (screenshot)?
Have you installed the “PlatformIO for CLion” extension as per CLion — PlatformIO latest documentation ?
It looks like that. Normal Squiggle line…
And yes I have the Extension installed. It neither works when using the cli nor when I create it using the extension.
Whats your platformio.ini, code as text (markdown ) and CLion version?
arduhe
July 17, 2020, 3:35pm
5
It’s no general problem as you can see in the following screenshot
if your file is located under src - as I assume - and not under test. If the later is true, there is an open issue as you can see here:
A few months ago @ivankravets announced in
a 1st release of a platformio plugin for clion and asked for some feedback. I am so free to start here a new thread as I couldn’t find an appropriate one .
At a 1st glance it looks very well. Most of the features I need are included. IMHO the GUI is much clearer than vscode, but that may be due to the fact that I use the older sister (or should I call it mother ) idea/intellij since a few years. Integration of git is much smoother - n…
resp.
https://youtrack.jetbrains.com/issue/CPP-21173
Nevertheless you could try to re-init your project (located under Tools → PlatformIO → Re-Init)
Thank’s for that.
I’m also getting this problem. I’m not very familiar with CMake, so I don’t know what it wants to do…
Cannot get compiler information:
Compiler exited with error code 1: C:\Users\user\.platformio\packages\toolchain-atmelavr\bin\avr-gcc.exe @C:\Users\user\AppData\Local\Temp\response-file10290307188185867260 C:\Users\user\AppData\Local\Temp\compiler-file596410696221276006 | @response-file10290307188185867260=/TC -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\include -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\Base -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\.pio\libdeps\uno\SD -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\.pio\libdeps\uno\Sleep_n0m1 -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\.pio\libdeps\uno\TroykaMQ\src -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\.pio\libdeps\uno\NRFLite\src -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\.pio\libdeps\uno\RF24 -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\.pio\libdeps\uno\RF24\utility "-IC:\Users\user\GitStuff\NEW_SAM\BETTER~1\PIO~1\libdeps\uno\ADAFRU~2" -IC:\Users\user\.platformio\packages\framework-arduino-avr\libraries\Wire\src -IC:\Users\user\.platformio\packages\framework-arduino-avr\libraries\SPI\src "-IC:\Users\user\GitStuff\NEW_SAM\BETTER~1\PIO~1\libdeps\uno\DHTSEN~1" "-IC:\Users\user\GitStuff\NEW_SAM\BETTER~1\PIO~1\libdeps\uno\ADAFRU~1" -IC:\Users\user\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\user\.platformio\packages\framework-arduino-avr\variants\standard -IC:\Users\user\.platformio\packages\framework-arduino-avr\libraries\EEPROM\src -IC:\Users\user\.platformio\packages\framework-arduino-avr\libraries\HID\src -IC:\Users\user\.platformio\packages\framework-arduino-avr\libraries\SoftwareSerial\src -IC:\Users\user\.platformio\packages\toolchain-atmelavr\lib\gcc\avr\5.4.0\include -IC:\Users\user\.platformio\packages\toolchain-atmelavr\lib\gcc\avr\5.4.0\include-fixed -IC:\Users\user\.platformio\packages\toolchain-atmelavr\avr\include -IC:\Users\user\.platformio\packages\tool-unity -std=gnu11 -fno-fat-lto-objects -fmax-errors=5 -g -fmerge-all-constants -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p "-D'PLATFORMIO=40304'" "-D'ARDUINO_AVR_UNO'" "-D'__BASE_FIRMWARE__'" "-D'F_CPU=16000000L'" "-D'ARDUINO_ARCH_AVR'" "-D'ARDUINO=10808'" "-D'__AVR_ATmega328P__'" /Be /Bd /EP
avr-gcc.exe: error: /TC: No such file or directory
avr-gcc.exe: error: /Be: No such file or directory
avr-gcc.exe: error: /Bd: No such file or directory
avr-gcc.exe: error: /EP: No such file or directory
Compiler exited with error code 1: C:\Users\user\.platformio\packages\toolchain-atmelavr\bin\avr-g++.exe @C:\Users\user\AppData\Local\Temp\response-file4191781524868230156 C:\Users\user\AppData\Local\Temp\compiler-file596410696221276006 | @response-file4191781524868230156=/TP -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\include -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\Base -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\.pio\libdeps\uno\SD -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\.pio\libdeps\uno\Sleep_n0m1 -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\.pio\libdeps\uno\TroykaMQ\src -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\.pio\libdeps\uno\NRFLite\src -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\.pio\libdeps\uno\RF24 -IC:\Users\user\GitStuff\NEW_SAM\BetterBase\.pio\libdeps\uno\RF24\utility "-IC:\Users\user\GitStuff\NEW_SAM\BETTER~1\PIO~1\libdeps\uno\ADAFRU~2" -IC:\Users\user\.platformio\packages\framework-arduino-avr\libraries\Wire\src -IC:\Users\user\.platformio\packages\framework-arduino-avr\libraries\SPI\src "-IC:\Users\user\GitStuff\NEW_SAM\BETTER~1\PIO~1\libdeps\uno\DHTSEN~1" "-IC:\Users\user\GitStuff\NEW_SAM\BETTER~1\PIO~1\libdeps\uno\ADAFRU~1" -IC:\Users\user\.platformio\packages\framework-arduino-avr\cores\arduino -IC:\Users\user\.platformio\packages\framework-arduino-avr\variants\standard -IC:\Users\user\.platformio\packages\framework-arduino-avr\libraries\EEPROM\src -IC:\Users\user\.platformio\packages\framework-arduino-avr\libraries\HID\src -IC:\Users\user\.platformio\packages\framework-arduino-avr\libraries\SoftwareSerial\src -IC:\Users\user\.platformio\packages\toolchain-atmelavr\lib\gcc\avr\5.4.0\include -IC:\Users\user\.platformio\packages\toolchain-atmelavr\lib\gcc\avr\5.4.0\include-fixed -IC:\Users\user\.platformio\packages\toolchain-atmelavr\avr\include -IC:\Users\user\.platformio\packages\tool-unity -fno-exceptions -fno-threadsafe-statics -fpermissive -std=gnu++11 -fmax-errors=5 -g -fmerge-all-constants -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=atmega328p "-D'PLATFORMIO=40304'" "-D'ARDUINO_AVR_UNO'" "-D'__BASE_FIRMWARE__'" "-D'F_CPU=16000000L'" "-D'ARDUINO_ARCH_AVR'" "-D'ARDUINO=10808'" "-D'__AVR_ATmega328P__'" /Be /Bd /EP
avr-g++.exe: error: /TP: No such file or directory
avr-g++.exe: error: /Be: No such file or directory
avr-g++.exe: error: /Bd: No such file or directory
avr-g++.exe: error: /EP: No such file or directory
[Failed to reload]
Seems like compiler discovery fails fatally.
The config is the following
[platformio]
src_dir = Base
default_envs = uno
[common]
default_src_filter = +<src/*>
build_flags = -fmax-errors=5
-g -D__BASE_FIRMWARE__
lib_deps = DHT sensor library
Adafruit BMP280 Library
RF24
NRFLite
TroykaMQ
# Globally defined properties
# inherited by all environments
[env]
build_flags = ${common.build_flags}
lib_deps = ${common.lib_deps}
lib_ldf_mode = chain+
[env:uno]
board = uno
Sleep_n0m1
161 # SD Lib
Wire
elmot
July 20, 2020, 9:09pm
9
Try to rename your source file from .c to .cpp extension.
Next version of the plugin is going to fix Arduino.h problem.
About compiler exited with error - a toolchain with gcc for the desktop should be set up.
This is a workaround for now, we’re working on the problem.
I only use cpp source files. The fact that this error is fixed in the next version would be nice.
I have a gcc toolchain (C++ Build Tools and mingw). Is that enough?
elmot
July 21, 2020, 12:14pm
11
Should be enough.
If your toolchain is in order, then autocomplete(Arduino.h) inside .cpp files should work.
Still can’t find anything as of now
What exact CLion version are you using? Does compiling work from the CLI?
I’m using 202.6397.12 (So the latest beta) which should be compatible. Latest PlatformIO also installed.
Solved by using MinGW64 compiler.
